Продам рабочие б/у сервера и комплектующие
Машины:
1. Intel s1400sp2 / 1 x Xeon e5-2440 6/12 core/flow 2.4-2.9Ghz 15mb cache / 8gb 2x4gb pc3 10600r samsung / 2x 1gb/s onboard lan / 2x250gb dell 7200rpm  / power unit 1x350w /  1 unit  - 250$
2. Intel s1400sp2 / 1 x Xeon e5-2450 8/16 core/flow 2.1-2.9Ghz 20mb cache / 8gb 1x8gb pc3l 12800r hynix / 2x 1gb/s onboard lan / 2x500gb seagate 7200rpm / power unit 1x350w / 1 unit - 260$
3. Intel s1400sp2 / 1 x Xeon e5-2428l 6/12 core/flow 1.8-2.0 15mb cache / 8gb 2x4gb 2rx4 pc3 10600r samsung / 2x 1gb/s onboard lan / 2x250gb seagate / power unit 1x350w  / 1 unit - 240$
4. Intel s1400sp2 / 1 x Xeon e5-2470 8/16 core/flow 2.3-3.1 20mb cache / 12gb 3x4gb 2rx4 pc3 10600r hynix / 2x 1gb/s onboard lan / 2x500gb wd / power unit 1x350w / 1 unit  - 280$
5. Dell DCS CS24-SC / 2 x Intel Xeon L5420 4 core 2.5ghz 12mb cache / 16gb 4x4gb 2rx4 pc2 5300p samsung / 3x 1gb/s onboard lan / 2x250gb seagate / power unit 1x400w  / 1 unit   - 200$
6. Supermicro X8DTU-F / 2 x Intel Xeon E5530 4/8 core/flow  2.40-2.66ghz 8mb cache / 8gb 4x2gb 2rx8 pc3-10600r / 3x 1gb/s onboard / 1x1000gb hitachi 7200rpm / power unit 1x600w / 1 unit  - 220$
7. Supermicro X9SCL-F / 1 x Intel Xeon E3-1230v2 4/8 core/flow 3.3-3.7ghz 8mb cache / 8gb 2x4gb kvr16e11/4 kingston / 3x 1gb/s onboard lan / 1x500gb seagate 7200rpm / power unit 1x350w / 1 unit  - 220$
8. Supermicro X9SCL-LN4F / 1 x Intel Xeon E3-1230 4/8 core/flow 3.2-3.6ghz 8mb cache/ 16gb 4x4gb ktd-pe313e/4g kingston / 5x 1gb/s onboard lan / 2x1000gb seagate / power unit 1x560w / 1 unit  - 170$
9. Supermicro X7SBJ / 1 x Intel Xeon 3065 2 core 2,33ghz 4mb cache / 2gb 2x1g kbr667d2e5/1g kingston / 2x 1gb/s onboard lan / 1x500gb toshiba / 1x300w1 / DVD-RW / 1 unit - 200$
11. Supermicro X7DBR-E / 2x Intel Xeon L5420 4 core  2.5ghz 12mb cache / 16gb 8x2gb 2rx8 pc2-5300f / 3x 1gb/s onboard lan / 1x250gb seagate / power unit 1x560w / 1 unit  - 200$
12. Dell PowerEdge 1950 / 2x Intel Xeon E5420 4 core 2.5GHz 12mb cache / 6gb 6x1gb 2rx8 pc2-5300f / 2x 1gb/s onboard lan / 2x500gb hgst 7200rpm / power unit 2x670w / 1 unit  - 170$
Все сервера полностью рабочие, решали задачи NAS,Firewall,NAT,BGP под Linux/FreeBSD, но после переезда на Juniper были выведены из эксплуатации.
Все сервера почищены-обслужены, заменена термопаста и произведена проверка, стоечные рельсы в комплекте.
Может быть переукомплектовано/доукомплектовано согласно вашим пожеланиям.
Комплектующие:
Сетевушки:
Intel Ethernet Server Adapter I350-T4 I350T4BLK / PCI Express x1 / 4 Gigabit Ethernet / 5шт. - 125$
Intel PRO/1000 ET Quad Port Server Adapter (0HM9JY) / PCI Express x1 / 4 Gigabit Ethernet / 1шт. - 50$
Intel PRO/1000 PT EXPI9404PTBLK 882125 / PCI Express x16 / 4 Gigabit Ethernet / 2шт. - 50$
Intel PRO/1000 GT Quad Port Server Adapter (PWLA8494GT) / PCI Express x16 / 4 Gigabit Ethernet / 1шт. - 30$
Intel Gigabit ET2 Quad Port Server Adapter(E1G44ET2BLK) / PCI Express x1 / 4 Gigabit Ethernet / 1шт. - 125$
Intel PRO/1000 PT (EXPI9404PTLBLK) 884311 / PCI Express x1 / 4 Gigabit Ethernet / 1шт. - 50$
Intel X520-DA2(E10G42BTDAG1P5) / PCI Express x2 / 2 SFP+ 10Gb/s / 2шт. - 120$
Intel X520-DA2(0XYT17) / PCI Express x2 / 2 SFP+ 10Gb/s / 1шт. - 120$
Intel X520-DA2(942V6) / PCI Express x2 / 2 SFP+ 10Gb/s / 1шт.  - 120$
Процессоры:
Intel Xeon E5-2428l 6/12 core/flow 1.8-2.0 15mb cache - 20$
Intel Xeon e5-2440 6/12 core/flow 2.4-2.9Ghz 15mb cache - 15$
Intel Xeon E5-2696v2 12/24 core/flow 2.7-3.5 30mb cache - 100$
Intel Xeon E5-2687Wv2 8/16 core/flow 3.4-4.0 25mb cache - 125$
 Intel Core i7-4770 4/8 core/flow 3.4-3.9 8mb cache - 50$
Жесткие диски:
HDD 2.5 Seagate / Sata / 320gb / 7200rpm / 2шт. - 10$
HDD 2.5 Seagate / Sata / 500gb / 5400rpm / 1шт. - 15$
SSD 2.5 Intel 320 Series / Sata / 40gb / 1шт. - 8$
HDD 3.5 Seagate / Sata / 80gb / 7200 / 1шт. - 8$
HDD 3.5 WD Enterprise / Sata / 500gb / 1шт. - 15$
HDD 3.5 Toshiba / Sata / 1000gb / 1шт. - 20$
HDD 3.5 WD Blue / Sata / 500gb / 1шт.  - 15$
Адекватный торг уместен.
Живёт добро в г.Одесса, самовывоз или может быть отправлено везде куда нужно, любым удобным способом.
Обращайтесь в ЛС, или по т.0638944598 Дмитрий
Відредаговано corssair
Продано
Остальное всё в наличии
  • 4 months later...
  • 1 year later...
    • Від trn457
      Продам 4х портовую серверную сетевую карты Broadcom 4-ports 1gb PCI Express X4  --  2800 грн
      Состояние новой, устанавливалась для проверки, в работе не была. Покупалась под сервер Dell PowerEdge.
      Описание есть в интернете.
      www.serversupply.com/NETWORKING/NETWORK%20INTERFACE%20CARD/4%20PORT/BROADCOM/BCM95719A1904G_317108.htm
    • Від semden
      Продаем старые сервера 1U формата с процессорами и памятью.
      Корпус: Supermicro
      CPU: 2x Intel® Xeon® E5420 (12M Cache, 2.50 GHz, 1333 MHz FSB)
      MB: Supermicro X7DBR-3
      6015B-3B 1U, 1xPSU, Intel 5000P, 2xCPUs LGA771
      RAM: 8x FB-DIMM 4096MB PC2-5300F-555-11 ECC Kingston {4*KVR667D2D4F5/4G+4*HYMP151F72CP4D3-Y5 AB-C} всего 8 слотов
      Цена: 2000 грн. (торг)
      hv2
      Корпус: Supermicro
      CPU: 2x Intel® Xeon® E5410 (12M Cache, 2.33 GHz, 1333 MHz FSB)
      6015B-3B - 1U, 1xPSU, Intel 5000P, 2xCPUs LGA771
      RAM: 8xFB-DIMM 4096MB PC2-5300 ECC Kingston {KVR667D2D4F5/4G} всего 8 слотов
      s20
      Корпус: Supermicro
      Supermicro X7DVL-E (2 HDD)
      RAM: (16 Gb) 4*2Gb FBDIMM Kingston KVR667D2D4F5/2G + 2*4Gb FBDIMM Kingston KVR667D2D4F5/4G
      s40
      Корпус: Supermicro
      CPU: 2x Intel® Xeon® X5450 (12M Cache, 3.00 GHz, 1333 MHz FSB)
      MB: Supermicro X7DCA-L
      RAM: 6x4GB 2Rx4 PC2-5300P-555-12 HYMP151P72CP4-Y5 AB-C всего 6 слотов
      s15
      MB: Tyan Tempest i5100X
      RAM: (32Gb) 4x 8GB 2Rx4 PC2-5300P-555-12 DDR2-667MHz Samsung (full)
      Case: 1U Chenbro RM12404 400W
      s19
      Корпус: Xserver
      CPU: 2x Intel® Xeon® E5405 (12M Cache, 2.00 GHz, 1333 MHz FSB)
      RAM: (16Gb) 4x DDR2 ECC 4GB 5300 HYMP151P72CP4-Y5 AB (full)
      CASE: 1U F430S;
      s19-old
      Корпус: HP PROLIANT SE1101
      CPU: 2 x L5420 QUAD CORE
      MEM: 8 GB (2*4 Gb Hynix Hymp151P72CP4 PC2-5300P-555-12 )
      tuthost-s0
      Корпус: HP Proliant DL360
      CPU: Xeon 2.4 Dual
      HDD: 2x18 Gb HP BF01885A4
      RAM: 2х512 Mb Samsung DDR pc2100r-25331-z
      Цена: 500 грн.
      s22
      Корпус: Supermicro
      CPU: 2x Intel® Xeon® L5420 (12M Cache, 2.50 GHz, 1333 MHz FSB)
      RAM: 4x4GB 2Rx4 PC2-5300P-555-12-ZZ HYS72T512920EP-3S-C2 (всего 6 слотов) PSU: PWS-281-1H, 280 Вт
      Если будете брать 2 или больше, то отдадим по 1500 грн.
      По необходимости каждый сервер можно доукомплектовать б\у HDD есть много вариантов от 100-200 грн.
      Также продаем корпуса по отдельности
      https://local.com.ua/forum/topic/120119-серверные-корпуса-бу-производство-харьков-xserver-200-грн/
      Самовывоз м. КПИ
      +380663005959 Денис
    • Від prodavani
      В кладовке лежит такое чудо. Что-то связаное с видеонаблюдением. Ибо раньше дома оно было.  Гугл не помог. Отдам в добрые руки за пару сотен украинских гривен.
    • Від j0k3r0k
      Весь товар рабочий.
      Жёсткие диски - 35 шт. Все разные, фото скину. 250 грн за шт.
      Хранилище hp storageworks msa 30 db не открывалось. Цена - 2000 грн.
      Сервера - 15 шт. Фото могу скинуть. 1500 грн. за один.
    • Від PrintIP
      Здравствуйте уважаемые форумчане!
      Компания S.R.L. AlexHost рада предложить вашему вниманию такие услуги как: Хостинг, Виртуальные серверы (VPS/VDS), Аренда Выделенных серверов.
      Все оборудование находится в нашем собственном дата-центре AlexHost.
      Дата-центр AlexHost размещен в Республике Молдова (Кишинев) на территории бывшего военного завода в бомбоубежище в 5-и метрах под землей.
      --------------- > SSD Хостинг в Молдове < ---------------
      1GB SSD диска / 2 сайта / 2 базы MySQL - 10€ /год
      5GB SSD диска / 20 сайтов / 20 баз MySQL  - 39€ /год
      10GB SSD диска / Сайтов неограничено /  MySQL баз - неограничено  - 79€ /год
      20GB SSD диска / Сайтов неограничено /  MySQL баз - неограничено  - 115€ /год
      Все тарифные планы включают в себя:
      Ежедневные бэкапы Бесплатный перенос сайта Безлимитный трафик Anti-DDoS защита от Voxility Неограниченное кол-во email аккаунтов Базовую техподдержку Панель управления ISPmanager --------------- > VPS серверы в Молдове < ---------------
      512MB RAM / 1 Ядро / 10GB SSD диска / Порт: 100 Мегабит - от 8,5€ /месяц *
      1GB RAM / 1 Ядро / 25GB SSD диска / Порт: 100 Мегабит - от 21,25€ /месяц *
      2GB RAM / 2 Ядра / 40GB SSD диска / Порт: 100 Мегабит - от 29,75€ /месяц *
      4GB RAM / 4 Ядра / 60GB SSD диска / Порт: 100 Мегабит - от 42,5€ /месяц *
      6GB RAM / 6 Ядер / 100GB SSD диска / Порт: 100 Мегабит - от 59,5€ /месяц *
      * Цены указаны при оплате за год
      Еженедельный бэкап всего сервера Anti-DDoS защита от Voxility Неограниченный 100 мегабитный канал Тип виртуализации: KVM VNC консоль Базовую техподдержку -------------------- > Выделенные серверы в Молдове < --------------------
      Dual-core / 2 Ядра / 4GB RAM / 1TB Жесткого диска / Порт: 100 Мегабит - от 24,65€ /месяц *
      Intel Core i3 / 4 Ядра / 4GB RAM / 1TB Жесткого диска / Порт: 100 Мегабит - от 33,15€ /месяц *
      Intel Core i7 / 8 Ядер / 8GB RAM / 1TB Жесткого диска / Порт: 100 Мегабит - от 58,65€ /месяц *
      Базовая техподдержка KVM консоль (по запросу) Anti-DDoS защита от Voxility Неограниченный 100 мегабитный канал * Бесплатный анонс ваших сетей (сумма ежемесячных платежей должна быть больше 200 евро)
      _________________________________________
      Немного о дата-центре
      ► Электричество:
      Дата-центр питают 2 прямых независимых ввода (с разных подстанций). Переключение между вводами обеспечивает собственный АВР. Суммарная пропускная способность фидеров 1,6 мегаватт.
      Бесперебойность эллектроснабжения обеспечивают UPS-ы и собственный дизель генератор марки SDMO.
      ► Интернет:
      2 независимых ввода от 2-ух компаний. Каждый ввод по 10 Гбит/с. Суммарная ширина каналов  на данный момент - 20 Гбит/с. Каналы постоянно расширяются при необходимости и/или под нужды крупных заказчиков.
      ► Сеть:
      Каждый кабель был с любовью обжат и проверен на работоспособность. Сеть построена исключительно на кабелях 6-ой категории. Маршрутизацию внутри сети обспечивают Cisco.
      ► Охлаждение:
      Постоянная температура в дата-центре 24-27 градусов. Охлаждение зарезервировано по схеме N+1. Среднегодовой PUE 1.2.
      ► Охрана:
      Дата-центр охраняет 2 независимых охранных агенства. На всей площади до дата-центра установлены камеры видеонаблюдения и охранники по периметру.
      ► Защита от DDos атак мощностью до 500 гигабит в секунду:
      Защита предоставлена компанией Voxility. Прямой оптический канал на Румынию к дата-центру Voxility предоставлен нашими партнерами.
      Контакты:
      Jabber: alexmd@jabber.ru
      ICQ: 692929123
      Skype: alexhost.md
      E-mail: info@alexhost.md
      -------------------- > Принимаем к оплате: < --------------------
