Posted
  Всем доброго дня!
  После "переезда" на новый сервер не работает подсчет трафика у абонов, графики рисует исправно.
  softflowd запущен:
  nobody  26980    0.0  0.0   13488   3148  -  Is   05:40       0:00.00 /usr/local/bin/softflowd -i bridge0 -n 127.0.0.1:42111 -m 16000 -p /var/run/softflowd.br
  при проверке  tcpdump -i lo0 port 42111 - тишина...
  Подскажите, куда копать?
Posted
2 минуты назад, nightfly сказал:
А softflowctl statistics що взагалі каже?
ctl connect("/var/run/softflowd.ctl") error: No such file or directory
Posted
годину тому, a_n_h сказав:
Ну в очевидь з ним шось не так. Спробуйте його нормально собі ручками запустити, типу
після чого подивитись в softflowctl  -c /var/run/softflowd.ctl statistics
Posted
1 час назад, nightfly сказал:
softflowd[16138]: Accumulated statistics since 2023-11-23T10:46:28 UTC:
Number of active flows: 0
Packets processed: 0
Fragments: 0
Ignored packets: 0 (0 non-IP, 0 too short)
Flows expired: 0 (0 forced)
Flows exported: 0 (0 records) in 0 packets (0 failures)
Packets received by libpcap: 0
Packets dropped by libpcap: 0
Packets dropped by interface: 0
Posted
4 минуты назад, a_n_h сказав:
Fragments: 0
А крізь bridge0, там взагалі, хоч якийсь трафік бігає?
Бо як би... екхм...
softflowd[32688]: Accumulated statistics since 2023-04-06T13:25:27 UTC:
Number of active flows: 8192
Packets processed: 3530177648835
Fragments: 572607720
Ignored packets: 6952774216 (6952774140 non-IP, 76 too short)
Flows expired: 150312963165 (150312806102 forced)
Flows exported: 219916343154 (219916343154 records) in 7895763590 packets (0 failures)
Packets received by libpcap: 2372778839
Packets dropped by libpcap: 440110
Expired flow statistics:  minimum       average       maximum
  Flow bytes:                  24         22095    4172133546
  Flow packets:                 1            23      32243292
  Duration:                  0.00s         0.37s    601284.37s
Expired flow reasons:
       tcp =         0   tcp.rst =         2   tcp.fin =         1
       udp =       126      icmp =         5   general =         0
   maxlife =         0
over 2 GiB =    156929
  maxflows = 150312806102
   flushed =         0
Per-protocol statistics:     Octets      Packets   Avg Life    Max Life
             ip (0):             46            1       0.00s       0.00s
           icmp (1):   453151103729   4720677050       0.00s       5.37s
           igmp (2):    11337073402    246292603       7.92s  601212.54s
        ipencap (4):       38375800        27775       1.19s       1.29s
            tcp (6): 1992017093270005 2087638966524       4.81s  601284.37s
            cbt (7):             52            1       0.00s       0.00s
           udp (17): 1328382047351705 1436487099175       0.01s    2048.69s
       trunk-2 (24):           1500            1       0.00s       0.00s
           xtp (36):           1278            1       0.00s       0.00s
     idpr-cmtp (38):           1500            1       0.00s       0.00s
          ipv6 (41):          12852          189      12.74s      17.51s
           gre (47):    72322658431    267386952      61.19s  601214.79s
           esp (50):   169089139730    715474884     115.56s  601212.83s
           rvd (66):           5844            4       0.00s       0.00s
           dgp (86):             52            1       0.00s       0.00s
          larp (91):             61            1       0.00s       0.00s
        crudp (127):           1500            1       0.00s       0.00s
         sctp (132):          12637            9       0.00s       0.00s
      Unknown (148):            216            1       0.00s       0.00s
      Unknown (150):             46            1       0.00s       0.00s
      Unknown (177):           1500            1       0.00s       0.00s
      Unknown (229):           1500            1       0.00s       0.00s
      Unknown (230):             79            1       0.00s       0.00s
      Unknown (237):            798            1       0.00s       0.00s
      Unknown (239):           2116            2       0.00s       0.00s
з середньостатистичного bridge0
Posted
13 минут назад, a_n_h сказав:
графіки малюються
Ну вони наразі не з нетфлову малюються, а самі собі.
І як ми бачимо, ваш сенсор взагалі жодного флову на інтерфейсі не споглядає, відповідно і до cap_nf долітати фізично нічому.
P.S. Шо за система то? Перевірю сам десь на дозвіллі.
Posted
7 минут назад, nightfly сказал:
FreeBSD 13.2, зробив міграцію на новий сервер.
Posted
В 23.11.2023 в 13:14, nightfly сказал:
  Проверил сам на тестовом тазике, все считает. Переставил систему с нуля - заработало.
  P.S. "Я ничего не трогал!", т.е. система была "из коробки"...
  • Thanks 1
Posted
6 часов назад, a_n_h сказав:
Ну от і чудово, бо я лиш зараз до робочого місця добрався по-нормальному :)
