ProstoName 4 Опубликовано: 2024-03-24 09:55:43 Share Опубликовано: 2024-03-24 09:55:43 Після оновлення на 13.3 не вдається скомпілити stargazer, вилітає з помилками (це кінцівка): In file included from /usr/include/c++/v1/string:569: In file included from /usr/include/c++/v1/__algorithm/remove.h:12: /usr/include/c++/v1/__algorithm/find.h:17:10: fatal error: '__string/constexpr_c_functions.h' file not found 17 | #include <__string/constexpr_c_functions.h> | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 1 error generated. In file included from ./user_impl.cpp:35: In file included from ./user_impl.h:30: In file included from ../../include/stg/user.h:25: In file included from ../../include/stg/message.h:14: In file included from /usr/include/c++/v1/string:569: In file included from /usr/include/c++/v1/__algorithm/remove.h:12: /usr/include/c++/v1/__algorithm/find.h:17:10: fatal error: '__string/constexpr_c_functions.h' file not found 17 | #include <__string/constexpr_c_functions.h> | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 1 error generated. In file included from ./user_property.cpp:1: In file included from ../../include/stg/user_property.h:13: In file included from /usr/include/c++/v1/string:569: In file included from /usr/include/c++/v1/__algorithm/remove.h:12: /usr/include/c++/v1/__algorithm/find.h:17:10: fatal error: '__string/constexpr_c_functions.h' file not found 17 | #include <__string/constexpr_c_functions.h> | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 1 error generated. In file included from ./users_impl.cpp:39: In file included from /usr/include/c++/v1/algorithm:1751: In file included from /usr/include/c++/v1/__algorithm/copy.h:12: In file included from /usr/include/c++/v1/__algorithm/copy_move_common.h:14: In file included from /usr/include/c++/v1/__algorithm/unwrap_range.h:19: In file included from /usr/include/c++/v1/__utility/pair.h:17: /usr/include/c++/v1/__fwd/get.h:18:10: fatal error: '__tuple/tuple_element.h' file not found 18 | #include <__tuple/tuple_element.h> | ^~~~~~~~~~~~~~~~~~~~~~~~~ 1 error generated. deps:1: *** пропущен разделитель. Останов. Ссылка на сообщение Поделиться на других сайтах
ProstoName 4 Опубліковано: 2024-03-24 11:01:17 Автор Share Опубліковано: 2024-03-24 11:01:17 з base.txz розпакував недостаючі каталоги, тепер помилка далі: gmake[2]: выход из каталога «/usr/home/andrey/stg3/stg-2.409/stglibs/dotconfpp.lib» gmake[2]: вход в каталог «/usr/home/andrey/stg3/stg-2.409/stglibs/smux.lib» gmake[2]: Цель «all» не требует выполнения команд. gmake[2]: выход из каталога «/usr/home/andrey/stg3/stg-2.409/stglibs/smux.lib» gmake[1]: выход из каталога «/usr/home/andrey/stg3/stg-2.409/stglibs» gmake -C /home/andrey/stg3/stg-2.409/projects/stargazer/plugins gmake[1]: вход в каталог «/usr/home/andrey/stg3/stg-2.409/projects/stargazer/plugins» gmake -C authorization/ao gmake[2]: вход в каталог «/usr/home/andrey/stg3/stg-2.409/projects/stargazer/plugins/authorization/ao» clang++ -c ao.cpp -I/usr/local/include -DARCH_LE -fPIC -DNDEBUG -DFREE_BSD5 -I /home/andrey/stg3/stg-2.409/projects/stargazer/../../include -I ../../../../../stglibs/scriptexecuter.lib/include -I ../../../../../stglibs/logger.lib/include -I ../../../../../stglibs/common.lib/include -I /home/andrey/stg3/stg-2.409/projects/stargazer/../../include -DNDEBUG -DFREE_BSD5 ao.cpp:56:37: error: no template named 'binary_function' in namespace 'std'; did you mean '__binary_function'? 56 | class IS_CONTAINS_USER: public std::binary_function<varType, USER_PTR, bool> | ~~~~~^~~~~~~~~~~~~~~ | __binary_function /usr/include/c++/v1/__functional/binary_function.h:49:1: note: '__binary_function' declared here 49 | using __binary_function = __binary_function_keep_layout_base<_Arg1, _Arg2, _Result>; | ^ ao.cpp:89:56: error: no member named 'bind1st' in namespace 'std' 89 | std::for_each(usersList.begin(), usersList.end(), std::bind1st(std::mem_fun(&AUTH_AO::UpdateUserAuthorization), this)); | ~~~~~^ ao.cpp:89:69: error: no member named 'mem_fun' in namespace 'std' 89 | std::for_each(usersList.begin(), usersList.end(), std::bind1st(std::mem_fun(&AUTH_AO::UpdateUserAuthorization), this)); | ~~~~~^ ao.cpp:154:19: error: use of undeclared identifier 'bind2nd' 154 | bind2nd(IsContainsUserAOB, u)); | ^ ao.cpp:164:19: error: use of undeclared identifier 'bind2nd' 164 | bind2nd(IsContainsUserAOA, u)); | ^ ao.cpp:182:24: error: use of undeclared identifier 'bind2nd' 182 | bind2nd(IsContainsUserIPB, u)); | ^ ao.cpp:192:19: error: use of undeclared identifier 'bind2nd' 192 | bind2nd(IsContainsUserIPA, u)); | ^ 7 errors generated. gmake[2]: *** [deps:37: ao.o] Ошибка 1 gmake[2]: выход из каталога «/usr/home/andrey/stg3/stg-2.409/projects/stargazer/plugins/authorization/ao» gmake[1]: *** [Makefile:13: authorization/ao] Ошибка 2 gmake[1]: выход из каталога «/usr/home/andrey/stg3/stg-2.409/projects/stargazer/plugins» gmake: *** [Makefile:64: plugins] Ошибка 2 Ссылка на сообщение Поделиться на других сайтах
madf 279 Опубліковано: 2024-03-25 10:54:46 Share Опубліковано: 2024-03-25 10:54:46 export CC=/usr/bin/clang export CXX=/usr/bin/clang++ export CXXFLAGS=-std=c++11 1 1 Ссылка на сообщение Поделиться на других сайтах
nightfly 1 259 Опубліковано: 2024-03-25 11:26:32 Share Опубліковано: 2024-03-25 11:26:32 https://github.com/nightflyza/UBinstaller/blob/master/UBinstaller.sh#L207 Більше запитань викликає інше, але то таке. 1 Ссылка на сообщение Поделиться на других сайтах
ProstoName 4 Опубліковано: 2024-03-26 09:50:17 Автор Share Опубліковано: 2024-03-26 09:50:17 Дякую, питання закрите Ссылка на сообщение Поделиться на других сайтах
