Serjiozz 0 Posted 2010-01-18 12:34:12 Share Posted 2010-01-18 12:34:12 Цена - $12000 Вопросы (предложения) в личку. Продается по факту апгрейда.... sh ver ниже... ----------------------------------------------------------- Cisco IOS Software, 7200 Software (C7200P-SPSERVICESK9-M), Version 12.4(11)T3, RELEASE SOFTWARE (fc4) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2007 by Cisco Systems, Inc. Compiled Thu 12-Jul-07 00:44 by prod_rel_team ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1) BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-BOOT-M), Version 12.4(4)XD10, RELEASE SOFTWARE (fc2) Router uptime is 1 year, 35 weeks, 2 days, 23 hours, 31 minutes System returned to ROM by power-on System restarted at 18:51:00 EEST Thu Mar 6 2008 System image file is "disk2:c7200p-spservicesk9-mz.124-11.T3.bin" If you require further assistance please contact us by sending email to export@cisco.com. Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory. Processor board ID 36163548 MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2 6 slot VXR midplane, Version 2.11 Last reset from power-on PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points. Current configuration on bus mb1 has a total of 0 bandwidth points. This configuration is within the PCI bus capacity and is supported. PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points. Current configuration on bus mb2 has a total of 0 bandwidth points. This configuration is within the PCI bus capacity and is supported. Please refer to the following document "Cisco 7200 Series Port Adaptor Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com> for c7200 bandwidth points oversubscription and usage guidelines. 1 FastEthernet interface 3 Gigabit Ethernet interfaces 2045K bytes of NVRAM. 250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes). 65536K bytes of Flash internal SIMM (Sector size 512K). Configuration register is 0x2102 Link to post Share on other sites
SeNeS 15 Posted 2010-01-18 14:57:53 Share Posted 2010-01-18 14:57:53 Cisco 7206-NPE-G1 Продам такую же кошку с первым НПЕ состояние идеальное Тел. 80996084234 аська 284349465 http://hotnet.com.ua/ Link to post Share on other sites
Ivan_Zuiev 3 Posted 2010-01-18 15:00:55 Share Posted 2010-01-18 15:00:55 Цена - $12000 Вопросы (предложения) в личку. Продается по факту апгрейда.... sh ver ниже... ----------------------------------------------------------- Cisco IOS Software, 7200 Software (C7200P-SPSERVICESK9-M), Version 12.4(11)T3, RELEASE SOFTWARE (fc4) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2007 by Cisco Systems, Inc. Compiled Thu 12-Jul-07 00:44 by prod_rel_team ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1) BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-BOOT-M), Version 12.4(4)XD10, RELEASE SOFTWARE (fc2) Router uptime is 1 year, 35 weeks, 2 days, 23 hours, 31 minutes System returned to ROM by power-on System restarted at 18:51:00 EEST Thu Mar 6 2008 System image file is "disk2:c7200p-spservicesk9-mz.124-11.T3.bin" If you require further assistance please contact us by sending email to export@cisco.com. Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory. Processor board ID 36163548 MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2 6 slot VXR midplane, Version 2.11 Last reset from power-on PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points. Current configuration on bus mb1 has a total of 0 bandwidth points. This configuration is within the PCI bus capacity and is supported. PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points. Current configuration on bus mb2 has a total of 0 bandwidth points. This configuration is within the PCI bus capacity and is supported. Please refer to the following document "Cisco 7200 Series Port Adaptor Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com> for c7200 bandwidth points oversubscription and usage guidelines. 1 FastEthernet interface 3 Gigabit Ethernet interfaces 2045K bytes of NVRAM. 250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes). 65536K bytes of Flash internal SIMM (Sector size 512K). Configuration register is 0x2102 А на что апргрейдили, если не секрет? Link to post Share on other sites
Serjiozz 0 Posted 2010-01-18 15:04:10 Author Share Posted 2010-01-18 15:04:10 Цена - $12000 Вопросы (предложения) в личку. Продается по факту апгрейда.... sh ver ниже... А на что апргрейдили, если не секрет? SUP-720-3BXL Link to post Share on other sites
SeNeS 15 Posted 2010-01-18 15:57:43 Share Posted 2010-01-18 15:57:43 Есть в наличии и SUP-720-3B SUP-720 Link to post Share on other sites
Serjiozz 0 Posted 2010-01-18 16:17:30 Author Share Posted 2010-01-18 16:17:30 Есть в наличии и SUP-720-3B SUP-720 уже проапгрейдили, потому и продаем освободившееся Link to post Share on other sites
][-RaY 387 Posted 2010-01-18 17:44:49 Share Posted 2010-01-18 17:44:49 Подскажите за сколько потом к ней можно будет купить бу платы расширения с гиг портами ? Link to post Share on other sites
rul 12 Posted 2010-01-22 16:10:41 Share Posted 2010-01-22 16:10:41 О! И еще одну нашу купите в отличном состоянии за туже цену! Link to post Share on other sites
yoksel 0 Posted 2010-01-23 20:53:31 Share Posted 2010-01-23 20:53:31 отдадим и свою Cisco 7206-NPE-G2 в хорошие руки, по цене 10000 - на гарантии, полный комплект. Link to post Share on other sites
