RouterOS 5.0rc4 released...
What's new in 5.0rc4 (2010-Nov-22 16:58):
*) radius - fixed Disconnect and CoA response signature generation;
*) winbox - make double click work in text fields again;
*) winbox - allow to drag windows outside of main one to the left;
*) winbox - make some settings look more consistent;
*) winbox - allot to specify IPv6 address in routing filter prefix;
*) winbox - make possible to open IPv6 routes without crashing;
*) winbox - improved item reordering in long lists;
*) winbox - improved SNMP configuration support;
*) winbox - added support for KVM configuration;
*) winbox - added support for Traffic Engineering configuration;
*) ovpn - make ovpn client work with OpenVPN v2.1.3;
*) lcd - support Crystalfontz 631,633
also support for Crystalfontz lcd contrast setting is added;
*) console - fixed missing return value of the ping command when executed
from a scheduler entry;
*) console - 'ping' command with specified value of 'interface' always forced
"arp-ping=yes", fixed;
*) routing - fixed problem with 'check-gateway' status update that could get
triggered when multiple routes with different values of 'target-scope'
and 'check-gateway' referenced the same gateway IP address;
*) store - allow to use external disks;
*) modem firmware directory can be specified in /port firmware
Gobi users should change this setting or directory name;
*) ups - support USB UPS on RB4xx as well;
*) snmp - fix BER encoding for some INTEGER based values;
*) snmp - provide proxy stats using SQUID-MIB;
*) snmp - provide ups info using UPS-MIB;
*) snmp - provide external storage information;
*) wireless nv2 - add missing statistics fields;
*) wireless - add per-chain signal strength fields;
*) added hotspot html variable "host-ip";
*) fixed pcq queue type;
*) fixed leds on RB750;
Torrent:
http://www.mikrotik.com/download/routeros-ALL-5.0rc4.torrent
Regular download:
http://www.mikrotik.com/download.html
и кто готов проапдейтить и сказать как оно пашет?
ща буду апгрейдится. птп линк с nv2
если можно,выложите все ньюансы ДО и После апгрейда!
ньюансов до апгрейда как бы не было. оно просто работало. если что-то конкретное интересует - спрашивайте, попробую ответить.
