NETOS 137 Опубликовано: 2011-05-20 07:52:40 Share Опубликовано: 2011-05-20 07:52:40 Всем привет! Настроил РРРоЕ подключение к провайдеру но что-то не работает. DHCP сервер провайдера пингуется нормально. Привожу настройки и логи. Помогите пожалуйста. Подключаюсь: Цитата server# ppp -ddial slav Working in ddial mode Using interface: tun0 Warning: Bad label in /etc/ppp/ppp.conf (line 41) - missing colon Логи подключения ppp.log Цитата May 20 09:58:15 server newsyslog[799]: logfile first createdMay 20 10:01:45 server ppp[1522]: Phase: Using interface: tun0 May 20 10:01:45 server ppp[1522]: Phase: deflink: Created in closed state May 20 10:01:45 server ppp[1522]: tun0: Command: default: ident user-ppp VERSION May 20 10:01:45 server ppp[1522]: tun0: Command: default: set device /dev/cuau1 May 20 10:01:45 server ppp[1522]: tun0: Command: default: set speed 115200 May 20 10:01:45 server ppp[1522]: tun0: Command: default: set dial ABORT BUSY ABORT NO\sCARRIER TIMEOUT 5 "" AT OK-AT-OK ATE1Q0 OK \dATDT\T TIMEOUT 40 CONNECT May 20 10:01:45 server ppp[1522]: tun0: Command: default: set timeout 180 May 20 10:01:45 server ppp[1522]: tun0: Command: default: enable dns May 20 10:01:45 server ppp[1522]: tun0: Warning: Bad label in /etc/ppp/ppp.conf (line 41) - missing colon May 20 10:01:45 server ppp[1528]: tun0: Phase: PPP Started (ddial mode). May 20 10:01:45 server ppp[1528]: tun0: Phase: bundle: Establish May 20 10:01:45 server ppp[1528]: tun0: Phase: deflink: closed -> opening May 20 10:01:45 server ppp[1528]: tun0: Warning: deflink: /dev/cuau1: Bad file descriptor May 20 10:01:45 server ppp[1528]: tun0: Chat: Failed to open device May 20 10:01:45 server ppp[1528]: tun0: Phase: deflink: Enter pause (30) for redialing. May 20 10:02:15 server ppp[1528]: tun0: Chat: deflink: Redial timer expired. May 20 10:02:15 server ppp[1528]: tun0: Warning: deflink: /dev/cuau1: Bad file descriptor May 20 10:02:15 server ppp[1528]: tun0: Chat: Failed to open device May 20 10:02:15 server ppp[1528]: tun0: Phase: deflink: Enter pause (30) for redialing. May 20 10:02:46 server ppp[1528]: tun0: Chat: deflink: Redial timer expired. May 20 10:02:46 server ppp[1528]: tun0: Warning: deflink: /dev/cuau1: Bad file descriptor May 20 10:02:46 server ppp[1528]: tun0: Chat: Failed to open device May 20 10:02:46 server ppp[1528]: tun0: Phase: deflink: Enter pause (30) for redialing. May 20 10:03:16 server ppp[1528]: tun0: Chat: deflink: Redial timer expired. May 20 10:03:16 server ppp[1528]: tun0: Warning: deflink: /dev/cuau1: Bad file descriptor May 20 10:03:16 server ppp[1528]: tun0: Chat: Failed to open device May 20 10:03:16 server ppp[1528]: tun0: Phase: deflink: Enter pause (30) for redialing. May 20 10:03:46 server ppp[1528]: tun0: Chat: deflink: Redial timer expired. May 20 10:03:46 server ppp[1528]: tun0: Warning: deflink: /dev/cuau1: Bad file descriptor May 20 10:03:46 server ppp[1528]: tun0: Chat: Failed to open device May 20 10:03:46 server ppp[1528]: tun0: Phase: deflink: Enter pause (30) for redialing. May 20 10:04:16 server ppp[1528]: tun0: Chat: deflink: Redial timer expired. May 20 10:04:16 server ppp[1528]: tun0: Warning: deflink: /dev/cuau1: Bad file descriptor May 20 10:04:16 server ppp[1528]: tun0: Chat: Failed to open device May 20 10:04:16 server ppp[1528]: tun0: Phase: deflink: Enter pause (30) for redialing. May 20 10:04:46 server ppp[1528]: tun0: Chat: deflink: Redial timer expired. May 20 10:04:46 server ppp[1528]: tun0: Warning: deflink: /dev/cuau1: Bad file descriptor May 20 10:04:46 server ppp[1528]: tun0: Chat: Failed to open device May 20 10:04:46 server ppp[1528]: tun0: Phase: deflink: Enter pause (30) for redialing. Конфигурация файла ppp.conf Цитата slav: set device PPPoE:rl0 set authname login set authkey parol set dial set login enable dns add default HISADDR настройки сети: Цитата rl0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=3808<VLAN_MTU,WOL_UCAST,WOL_MCAST,WOL_MAGIC> ether 00:e0:52:92:b3:1e inet 172.26.112.94 netmask 0xffffff80 broadcast 172.26.112.127 media: Ethernet autoselect (100baseTX <full-duplex>) status: active rl1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=3808<VLAN_MTU,WOL_UCAST,WOL_MCAST,WOL_MAGIC> ether 00:e0:52:92:b3:07 inet 192.168.0.5 netmask 0xffffff00 broadcast 192.168.0.255 media: Ethernet autoselect (100baseTX <full-duplex>) status: active tun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> metric 0 mtu 1500 options=80000<LINKSTATE> Opened by PID 1528 Ссылка на сообщение Поделиться на других сайтах
VitalyMoiseev 113 Опубліковано: 2011-05-20 08:03:10 Share Опубліковано: 2011-05-20 08:03:10 Warning: Bad label in /etc/ppp/ppp.conf (line 41) - missing colon о чем-то говорит Ссылка на сообщение Поделиться на других сайтах
ZEKA 6 Опубліковано: 2011-05-20 11:34:05 Share Опубліковано: 2011-05-20 11:34:05 http://www.freebsd.org/doc/ru_RU.KOI8-R/books/handbook/pppoe.html Ссылка на сообщение Поделиться на других сайтах
NETOS 137 Опубліковано: 2011-05-20 12:26:21 Автор Share Опубліковано: 2011-05-20 12:26:21 В 20.05.2011 в 08:03, VitalyMoiseev сказав: Warning: Bad label in /etc/ppp/ppp.conf (line 41) - missing colon о чем-то говорит указывает какой интерфейс смотрит в сторону провайдера, у меня все правильно написано Ссылка на сообщение Поделиться на других сайтах
VitalyMoiseev 113 Опубліковано: 2011-05-20 13:12:41 Share Опубліковано: 2011-05-20 13:12:41 В 20.05.2011 в 12:26, Tooreagen сказав: В 20.05.2011 в 08:03, VitalyMoiseev сказав: Warning: Bad label in /etc/ppp/ppp.conf (line 41) - missing colon о чем-то говорит указывает какой интерфейс смотрит в сторону провайдера, у меня все правильно написано а фря говорит: - missing colon Можете спорить с ней до бесконечности. Вам же привели ссылку на хендбук - обратите внимание на то, как там записан ppp.conf Особенно на missing colon - отсутствующие отступы Ссылка на сообщение Поделиться на других сайтах
NETOS 137 Опубліковано: 2011-05-21 06:23:13 Автор Share Опубліковано: 2011-05-21 06:23:13 Действительно, добавил пробелы и подключилось. Но интернета так и нет, что может быть? Ссылка на сообщение Поделиться на других сайтах
wifi_master 132 Опубліковано: 2011-05-21 06:39:56 Share Опубліковано: 2011-05-21 06:39:56 используй mpd5 и будет тебе счастье. Ссылка на сообщение Поделиться на других сайтах
VitalyMoiseev 113 Опубліковано: 2011-05-21 08:00:40 Share Опубліковано: 2011-05-21 08:00:40 В 21.05.2011 в 06:23, Tooreagen сказав: Действительно, добавил пробелы и подключилось. Но интернета так и нет, что может быть? ifconfig и netstat -rn после подключения в студию. Ссылка на сообщение Поделиться на других сайтах
wifi_master 132 Опубліковано: 2011-05-21 15:18:06 Share Опубліковано: 2011-05-21 15:18:06 cd /usr/ports/net/mpd5 && make install clean ee /usr/local/etc/mpd5/mpd.conf конфиг: startup: # Установим параметры пользователя # имя пароль роль_пользователя set user comanderspok 123456 admin # Разрешим консоль на локалхосте set console self 127.0.0.1 5005 # Это настройки по умолчанию - они будут вызваны при обычном запуске default: load pppoe_client pppoe_client: # # PPPoE client: только исходящие соединения, автоматический реконнект, # адреса получаются по ipcp, односторонняя аутентификация, # маршрут по умолчанию смотрит на шлюз провайдера # create bundle static B1 set iface route default set ipcp ranges 0.0.0.0/0 0.0.0.0/0 # Запросим ДНС у удаленного сервера # Это не всегда работает set ipcp enable req-pri-dns set ipcp enable req-sec-dns create link static L1 pppoe set link action bundle B1 # Надо указать свои логин и пароль set auth authname твой логин set auth password твой пароль set link max-redial 0 set link mtu 1480 set link keep-alive 10 60 # Тут надо прописать свой интерфейс set pppoe iface fxp0 # Не устанавливать имя сервиса, так как мы - клиент set pppoe service "" # Запустить соединение open Вот и усьо. Ссылка на сообщение Поделиться на других сайтах
supportod 1 Опубліковано: 2011-07-02 15:34:36 Share Опубліковано: 2011-07-02 15:34:36 В 21.05.2011 в 06:39, wifi_master сказав: используй mpd5 и будет тебе счастье. +1 Ссылка на сообщение Поделиться на других сайтах
Skr 11 Опубліковано: 2011-08-13 13:39:47 Share Опубліковано: 2011-08-13 13:39:47 Сталкивался с такой проблемкой - ставлю чистую фрю, интернет через pppoe . как из портов mpd поставить? Ссылка на сообщение Поделиться на других сайтах
VitalyMoiseev 113 Опубліковано: 2011-08-13 14:52:17 Share Опубліковано: 2011-08-13 14:52:17 В 13.08.2011 в 13:39, Skr сказав: Сталкивался с такой проблемкой - ставлю чистую фрю, интернет через pppoe . как из портов mpd поставить? http://www.freshports.org/net/mpd5 To install the port: cd /usr/ports/net/mpd5/ && make install clean To add the package: pkg_add -r mpd5 Но, как понимаю, инета нет. тогда проще так: http://www.freebsd.org/doc/ru_RU.KOI8-R/books/handbook/pppoe.html Ссылка на сообщение Поделиться на других сайтах
Skr 11 Опубліковано: 2011-08-13 16:00:07 Share Опубліковано: 2011-08-13 16:00:07 Щас такая ситуация: У машины 2 сетевухи - lan1 и lan2 lan1 подключена к роутера, через нее идет интернет. lan2 - подключена на прямую к прову, настроил (по инстр. выше) mpd. стартанул mpd. ifconfig: Цитата ng0: flags=88d1<UP,POINTOPOINT,RUNNING,NOARP,SIMPLEX,MULTICAST> metric 0 mtu 1480 inet 131.142.11.211 --> 125.127.138.129 netmask 0xffffffff Поднялся mpd Но трасса на ya.ru идет через роутер, следовательно через lan1 . Никаких фаерволов и маршрутизаций на фре не делано. Попробую вечером отключить lan1. Ссылка на сообщение Поделиться на других сайтах
natiss 16 Опубліковано: 2011-08-13 18:10:29 Share Опубліковано: 2011-08-13 18:10:29 route change 0 -iface ng0 не? Ссылка на сообщение Поделиться на других сайтах
Skr 11 Опубліковано: 2011-08-13 19:15:01 Share Опубліковано: 2011-08-13 19:15:01 Отключил lan1, побежал через ng0. Да как-бы не проблема, занят был и другими делами, не подумал как использовать 2 канала. Ушел, машина осталась на ng0, а его ip я не глянул) Ссылка на сообщение Поделиться на других сайтах
Skr 11 Опубліковано: 2011-09-09 18:36:04 Share Опубліковано: 2011-09-09 18:36:04 Подскажите как обучить ipfw принимать интернет через рррое и натить на 2-ю сетевуху? Ссылка на сообщение Поделиться на других сайтах
VitalyMoiseev 113 Опубліковано: 2011-09-09 19:23:23 Share Опубліковано: 2011-09-09 19:23:23 В 09.09.2011 в 18:36, Skr сказав: Подскажите как обучить ipfw принимать интернет через рррое и натить на 2-ю сетевуху? http://www.freebsd.org/doc/ru_RU.KOI8-R/books/handbook/pppoe.html http://mpd.sourceforge.net/doc5/mpd39.html#39 Ссылка на сообщение Поделиться на других сайтах
Skr 11 Опубліковано: 2011-09-12 18:19:48 Share Опубліковано: 2011-09-12 18:19:48 С указанным выше конфигом MPD но измененными логин пасс и интерфейсом пытался запустить. После /usr/local/etc/rc.d/mpd5 start pmd starting но в ifconfig не показывается. пингуются только сервера провайдера. Что происходит, где смотреть? Моя машина из сети, по локальному ip пингуется. Ссылка на сообщение Поделиться на других сайтах
adeep 212 Опубліковано: 2011-09-12 20:01:18 Share Опубліковано: 2011-09-12 20:01:18 в лог mpd Ссылка на сообщение Поделиться на других сайтах
Skr 11 Опубліковано: 2011-09-12 20:29:09 Share Опубліковано: 2011-09-12 20:29:09 /var/log/ только ppp.log . find не находит. Ссылка на сообщение Поделиться на других сайтах
Skr 11 Опубліковано: 2011-09-13 20:38:52 Share Опубліковано: 2011-09-13 20:38:52 После ребута: Цитата # ps ax | grep mpd 1962 ?? Is 0:00.01 /usr/local/sbin/mpd5 -p /var/run/mpd5.pid -b 2021 0 RL+ 0:00.00 grep mpd Добавил лог: Цитата !mpd*.* /var/log/mpd.log В логе: Цитата Aug 13 04:45:02 holdfast mpd: process 1217 terminatedAug 13 04:45:02 holdfast mpd: Multi-link PPP daemon for FreeBSD Aug 13 04:45:02 holdfast mpd: Aug 13 04:45:02 holdfast mpd: process 1962 started, version 5.5 (root@holdfast 03:09 13-Aug-2011) Цитата # ifconfig re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=389b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_UCAST,WOL_MCAST,WOL_MAGIC> ether 00:1c:c0:ec:d0:7d inet 10.3.254.125 netmask 0xffffff00 broadcast 10.3.254.255 media: Ethernet autoselect (100baseTX <full-duplex>) status: active usbus0: flags=10000<> metric 0 mtu 0 usbus1: flags=10000<> metric 0 mtu 0 usbus2: flags=10000<> metric 0 mtu 0 usbus3: flags=10000<> metric 0 mtu 0 lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=3<RXCSUM,TXCSUM> inet6 fe80::1%lo0 prefixlen 64 scopeid 0x6 inet6 ::1 prefixlen 128 inet 127.0.0.1 netmask 0xff000000 nd6 options=3<PERFORMNUD,ACCEPT_RTAD # Соединение не устанавливается.. Сервера провайдера пингуются. Ссылка на сообщение Поделиться на других сайтах
Skr 11 Опубліковано: 2011-09-15 13:22:32 Share Опубліковано: 2011-09-15 13:22:32 Такс. С mpd не выходит пока. Пробовал через ppp.conf: ee /etc/ppp/ppp.conf default: Internet: set log Phase tun command set device PPPoE:re0 set authname login set authkey passw set mru 1492 set mtu 1492 enable lqr set lqrperiod 10 enable lqr echo enable echo enable dns set dial set login set timeout 0 set redial 0 0 #ppp -ddial Internet Стартует. #ifconfig появился tun0 tun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> metric 0 mtu 1492 options=80000<LINKSTATE> inet 82.252.52.32 –> 80.177.25.4 netmask 0xffffffff Opened by PID 23769 host# пинги серверов провайдера и его сайта идут, как по ip так и по домену. 82.252.52.32 - ip который дает мне по PPPoE провайдер 80.177.25.4 - gate моего прова, он тоже пингуется. сайты типа ya.ru не по домену не по ip не пингуются. Ссылка на сообщение Поделиться на других сайтах
