Mechanik 49 Опубликовано: 2011-10-10 16:59:06 Share Опубликовано: 2011-10-10 16:59:06 Продам новую карту в упаковке. TBS6984 PCI-E DVB-S2 Quard tuner TV card. 4 головы, дрова по linux PCI-E DVB-S2 Quad Tuner TV card supports 4 DVB-S2 TV channels receiving synchronously, which enables you to watch channel from one transporder/satellite while recording another 3 channels from another 3 transporders / satellites. Or you can download data from 4 transporders / satellites in the same time. TBS6984 is ideal for building HTPC under Linux MythTV, VDR, XBMC and Windows 7 Media Center. TBS6984 is compatible with Freesat. Main Features: Quad Channels DVB-S2/S HD/SD TV Receiving Synchronously Broadband via Internet High-speed Data Download via Satellite Linux S2API Drivers Compatible with MythTV, VDR, XBMC, DVBLast, VLC, etc. Supported by DVBDream, DVBViewer, DVBlogic, ProgDVB, Skynet, Tsreader etc Specifications: Receiving Frequency: 925~2175 MHz Tuning Range Input Level: -69~23dBm 4x Advanced DVB-S2/DVB-S 8PSK QPSK Demodulator Symbol Rates: DVB-S QPSK: 1-45 Msps DVB-S2 8PSK/QPSK: 2-36 Msps Code Rates: DVB-S: 1/2, 2/3, 3/4, 5/6, 7/8 DVB-S2 QPSK: 1/2, 3/5, 2/3, 3/4. 4/5. 5/6, 8/9, 9/10 DVB-S2 8PSK: 3/5, 2/3. 3/4. 5/6. 8/9, 9/10 Automatic Acquisition Range: ±10MHz DiSEqC 2.x Compliant PCI Express Interface System Requirements: Windows 2000 / XP / Vista / 7, Linux DirectX9.0 or later Version Available PCI slot CD-Rom(Driver and Software Installation) Satellite Dish and LNB For DVB-S: 1GHz CPU or above 256MB RAM or above Graphic Card with at least 16MB RAM For DVB-S2 HDTV (1080i/ MPEG4 <AVC/ H2.64> ): 3.0GHz Penium IV CPU or above 1GB RAM or Above Graphic Card with at Least 64MB RAM Package Content: 1 x TBS6984 PCI-E Dual DVB-S2 Tuner card 1x Remote control 1x IR receiver 1x Software CD 1x Power Cable 300$ отправлю любым перевозчиком Ссылка на сообщение Поделиться на других сайтах
Singer 0 Опубликовано: 2011-12-14 10:07:31 Share Опубликовано: 2011-12-14 10:07:31 за 250 заберу Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2011-12-14 10:25:24 Автор Share Опубликовано: 2011-12-14 10:25:24 проданы, ожидаем еще Ссылка на сообщение Поделиться на других сайтах
paha 0 Опубликовано: 2011-12-26 16:45:56 Share Опубликовано: 2011-12-26 16:45:56 Интересует данное предложение, есть ли в оно в наличии. (TBS6984 PCI-E DVB-S2 Quard tuner TV card)? Ссылка на сообщение Поделиться на других сайтах
Butaxa 1 Опубликовано: 2011-12-26 19:37:54 Share Опубликовано: 2011-12-26 19:37:54 сори что не в тему- а что с ней делать? спунт каналы в сеть транслировать? Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2011-12-26 19:44:54 Автор Share Опубликовано: 2011-12-26 19:44:54 Интересует данное предложение, есть ли в оно в наличии. (TBS6984 PCI-E DVB-S2 Quard tuner TV card)? ждем , на днях, как появится-отпишу карта удобна для iptv стриммера, Вы используете 1 pcie порт сразу на 4 транспондера,те в 1й системе можно собрать большое кол-во транспондеров и закрыть полность все нужные спутники к примеру вся Украина закрывается 2мя картами, более 60 каналов Ссылка на сообщение Поделиться на других сайтах
Dragon 13 Опубликовано: 2011-12-27 00:05:53 Share Опубликовано: 2011-12-27 00:05:53 А у них после ребута не меняться номера устройств под Linux ? Ссылка на сообщение Поделиться на других сайтах
KaYot 3 740 Опубликовано: 2011-12-27 07:37:46 Share Опубликовано: 2011-12-27 07:37:46 А я думал один такой, после ребута с матами переписываю конфиги VLC)) Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2011-12-27 07:45:09 Автор Share Опубликовано: 2011-12-27 07:45:09 не меняются все становятся четко по номерам, даже если добавлять следующие карты единственное, что если среди pcie карт добавляются pci, то номера меняются при каждом ребуте, как не прописывай привязки Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2012-01-16 19:43:16 Автор Share Опубликовано: 2012-01-16 19:43:16 есть еще несколько карт,новые запечатанные также продам skystar-2,3 бу 200-300грн Ссылка на сообщение Поделиться на других сайтах
Singer 0 Опубликовано: 2012-01-27 09:01:18 Share Опубликовано: 2012-01-27 09:01:18 Купил себе 3 таких карты. Поставил, установил дрова, всё хорошо и красиво. Прошла неделя, на одной из карт сгорела микросхемка возле разЪёма PCI-Express. Отправил назад для возврата, соответственно 150 грн за отправку отдал. Проходит ещё неделя, перестаёт на двух оставшихся картах лочиться сигнал на портах A и B одновременно. Переустановка драйвера эффекта не дала. Сижу в шоке... Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2012-01-31 01:42:48 Автор Share Опубликовано: 2012-01-31 01:42:48 просто так микрухи не горят, а судя по описания сгорела именно микруха приемника на 2 канала очень часто горят входы, при накручивании кабеля и вкл компе стоят 5 шт в 2х машинах,работают на 4+ Ссылка на сообщение Поделиться на других сайтах
nickmas 1 Опубликовано: 2012-01-31 08:32:21 Share Опубликовано: 2012-01-31 08:32:21 Я тоже такую себе взял еще летом. Работает без нареканий. Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2012-04-02 20:53:13 Автор Share Опубликовано: 2012-04-02 20:53:13 В наличии есть еще 4 карты. Также есть 2 USB Phoenix/Smartmouse картоприемника по 25уе Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2012-04-15 18:15:08 Автор Share Опубликовано: 2012-04-15 18:15:08 осталась 1 карта и 2 картоприемника покупаем Ссылка на сообщение Поделиться на других сайтах
Alexander Nezhinskiy 0 Опубликовано: 2012-04-18 13:11:03 Share Опубликовано: 2012-04-18 13:11:03 Добрый день! Одну карту покупаю. и еще 2 дозакажу. Свяжитесь со мной - +380674634366 Спасибо Ссылка на сообщение Поделиться на других сайтах
RVL 6 Опубликовано: 2012-04-18 13:27:56 Share Опубликовано: 2012-04-18 13:27:56 Фото Феникса можно ? Ссылка на сообщение Поделиться на других сайтах
Mobil 70 Опубликовано: 2012-04-23 19:37:45 Share Опубликовано: 2012-04-23 19:37:45 А есть еще такие карты в наличии? Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2012-04-25 20:27:45 Автор Share Опубликовано: 2012-04-25 20:27:45 кардридеры есть 2шт карты закончились, будут в середине мая Ссылка на сообщение Поделиться на других сайтах
petrovi4 178 Опубликовано: 2012-06-15 14:58:04 Share Опубликовано: 2012-06-15 14:58:04 Крутые карточки, стоит 3шт пол года, полет нормальный! Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2012-06-25 14:18:48 Автор Share Опубликовано: 2012-06-25 14:18:48 карт осталось несколько штук, спешим запустить iptv в своей сети для летних акций!!! ридер закончились Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2012-07-02 11:05:34 Автор Share Опубликовано: 2012-07-02 11:05:34 еще есть несколько штук Ссылка на сообщение Поделиться на других сайтах
Denis" 0 Опубликовано: 2012-07-06 19:13:44 Share Опубликовано: 2012-07-06 19:13:44 одну за 250 отдашь? Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2012-07-06 19:56:40 Автор Share Опубликовано: 2012-07-06 19:56:40 нет, 1шт 2400грн Ссылка на сообщение Поделиться на других сайтах
Mechanik 49 Опубликовано: 2012-07-16 09:25:46 Автор Share Опубликовано: 2012-07-16 09:25:46 продам так жесть 2шт skystar3 бу Ссылка на сообщение Поделиться на других сайтах
