Продам світчі 24 port
Ціна 340$
24 SFP 100M ports and 2 SFP/TX 1000M combo ports,web managed Ethernet  switch
Відредаговано blackjeri
Ціна 340$
340$ ???!!! o_O !
конкретней про свич можно? Или это совсем китайский нонейм?
скриншот веб интерфейса в студию плз, как минимум....
Standards Conformance   Standards Compliance IEEE 802.3 (Ethernet)
IEEE 802.3u (Fast Ethernet)
IEEE 802.3ab (Gigabit Ethernet)
IEEE 802.3z (Gigabit Ethernet)
IEEE 802.3x (Full-Duplex Flow Control)
IEEE 802.1Q VLAN
IEEE 802.1p QoS
IEEE 802.1D (Spanning Tree Protocol)
IEEE 802.1w (Rapid Spanning Tree Protocol) Smart Function   System Configuration Web interface, SNMP v1 Port Configuration Port speed duplex mode selection
Flow control disable / enable
Port disable / enable
Port description on each port Bandwidth Control 1 / 2 / 4 / 8 / 16 / 32 / 64Mbps Broadcast Storm Control 5% / 10% / 25% / 50% / Disable Port Statistics Display detail Ethernet traffic counter information on each port VLAN - 32 IEEE 802.1Q VLAN groups
- 26 Port-Based VLAN groups
- MTU VLAN Spanning Tree Protocol - STP, IEEE 802.1D (Spanning Tree Protocol)
- RSTP, IEEE 802.1w (Rapid Spanning Tree Protocol) Link Aggregation - 2 groups of 4-Port 100Base-FX trunk support, up to 800Mbps bandwidth per trunk
- 1 group of 2-Port 10/100/1000Mbps trunk support, up to 4000Mbps bandwidth per trunk Port Mirroring Port mirroring allows monitoring of the traffic across any port in real time QoS Allows to assign low / high priority on each port
First-In-First-Out, All-High-before-Low, Weight-Round-Robin QoS policy Security MAC Address
TCP & UDP Filter IGMP Snooping v1 / v2 Allows to disable or enable
Physical Port
 24 x 100Base-FX Fast Ethernet ports
 2 x 1000Base-X SFP slots, shared with Port-25 and Port-26
Layer 2 Features
 Auto-MDI/MDI-X detection on  RJ-45 port(2526 ports)
 Prevents packet loss with back pressure (half-duplex) and IEEE 802.3x PAUSE frame flow control(full-duplex)
 High performance Store and Forward architecture, runt/CRC filtering eliminates erroneous packets to optimize the network bandwidth
 Supports VLAN
IEEE 802.1Q Tag-Based VLAN
Port-Based VLAN
MTU VLAN (Multi-Tenant Unit VLAN)
 Supports Spanning Tree Protocol
STP, IEEE802.1D (Classic Spanning Tree Protocol)
RSTP, IEEE802.1W (Rapid Spanning Tree Protocol)
Loopback Detection
 Supports Link Aggregation
up to 3 trunk groups
up to 4 Fast Ethernet ports or 2 Gigabit ports per trunk group
IEEE 802.3ad LACP (Link Aggregation Control Protocol)
Cisco ether-channel (Static Trunk)
 Port Mirroring to monitor the incoming or outgoing traffic on a particular port
Quality of Service
 2 priority queues on all Switch ports
 Traffic classification
Port-Based priority
IEEE 802.1p based priority
IP TOS / DSCP based priority
TCP / UDP Port-Based QoS
 Strict priority and Weighted Round Robin (WRR) CoS policies
 In/Out rate limit control on each port
 Broadcast Storm Control support
Multicast
 Supports IGMP Snooping v1 and v2
Security
 MAC address filter
 TCP & UDP filter on each port
 Management idle time security
Відредаговано sat12
    • Від avdept
      Продам свіч, 24 порти, ПОЕ до 400вт комбіновано. Все працює, екран, віддалений доступ. Хочу 18000грн
    • Від Alina1989
      Hey, fellows, our S6865-56YC switch is a high-performance and high-density uplink switch with 25Gigabit Downlink & 100Gigabit Uplink, which is designed and developed by our company independently. The whole switch adopts advanced hardware structure design and pluggable power redundancy design.
      It can support a maximum of 48 *25Gigabit ports, 8*100G uplink ports, provide full port L2/L3 line speed forwarding capability, and support IPV6. This device provides rich service features and powerful functions, such as ACL policies, flexible Q-in-Q, and network security protection.
      Meanwhile, the product has the highest 10 Gigabit port density and the largest switching capacity of the same grade equipment in the industry, and supports full-port line speed forwarding. The elastic stack function virtualizes multiple devices into a logical entity, which can expand port and switching capacity, manage, upgrade, and maintain multiple devices in a unified manner.
      To meet the requirements of large data traffic and non-blocking transmission in data centers, the product provides powerful cache capabilities and supports advanced cache scheduling mechanisms to ensure the maximum effective utilization of the device's cache capabilities. It is designed to meet the requirements of high-density and high-bandwidth network applications in next-generation enterprise networks, data centers and metropolitan area networks.
      It can be applied to the Ethernet aggregation layer or access layer of network operators or campuses, as well as the access layer of data centers and the core layer of small and medium-sized enterprises, and provides rich server access solutions for data centers.
        S6865-56YC (1+1 modular redundant power supply)
      More details, contact me directly!
      Whatsapp/ Viber/ Wehcat : +86 18086327779
      Skype: alinaquan14@hotmail.com
    • Від Diter_ua
      Продам управляемый коммутатор.
      4 сфп порт
      24 медных гигабитных
      без пароля.
      Хотелка 2500 грн. Торг
    • Від scaran
      Приветствую еще раз. Кто может поделится прошивкой 15.3.1.4 или ниже для summit x250e.  На свитче стоит 12.5.4.5, при попытке зашить 15.3.5.2 patch 1-19 ругается, что нужна промежуточная. А какая именно промежуточная инфы не нашел.
    • Від apels1n
      Всім привіт, на днях знадобився шаблон під zxr10 2928e, на просторах інтернету не знайшов, тому вирішив поділитися самостійно зробленим. Може комусь буде потрібно. Підходить до 6 заббіксу, на інших не тестував.
      zbx_export_templates.xml
