Продам: HP Procurve 5304XL
Продам HP Procurve 5304XL. 4 юнитовый.
В слоте А: J4821A (Gigabit) (100/1000-T) (4 ports)
HP ProCurve Expansion Module
Manufacturer
HP Manufacturer Part # J4821A Ports
4 Ports
Form Factor
Plug-in Module Cabling Type
Ethernet 100Base-T, Ethernet 1000Base-T Data Transfer Rate 1 Gbps, 100 Mbps Fast Ethernet
Connectivity
Wired
Features
Full duplex capability, hot swap module replacement, auto-negotiation, MDI/MDI-X switch Compliant Standards
IEEE 802.3U, IEEE 802.3ab Status Indicators
Port status, link activity, port transmission speed, port duplex mode, error
Dimensions
(H X W X D)
Unit
5" H x 14.25" D
Weight
Unit
1.5 lbs
Warranty
Lifetime Warranty
В слоте В: J8161A (PoE) (10/100TX) (24 ports)
HP ProCurve Switch xl 24-Port 10/100-TX Expansion PoE Module J8161A, w/ 24 x 10/100Base-TX LAN.[/size]
В слоте C: J4820A (10/100-TX)  (24 ports)
24 auto-sensing 10/100 ports (IEEE 802.3 Type 10Base-T; 802.3u Type 100Base-TX); Connector: RJ-45; HP Auto-MDIX: yes; Duplex: half or full[/size]
В слоте D: J4907A (100/1000-T Gigabit/mini GBIC/SFP) (16 ports)
Technical features Product Note with 14 auto-sensing 10/100/1000 ports and 2 dual-personality ports (10/100/1000 or mini-GBIC) External I/O ports 14 auto-sensing 10/100/1000 ports (IEEE 802.3 Type 10Base-T; 802.3u Type 100Base-TX; 802.3ab Type 1000Base-T); 2 dual personality ports; HP Auto-MDIX: yes; Connector: RJ-45; Duplex: half or full Cabling technology Type: 10Base-T: Category 3 (or better) 100 Ω differential unshielded twisted pair (UTP) or shielded twisted pair (STP), complying with IEEE 802.3 Type 10Base-T specifications; 100BaseTX: Category 5 (or better), 100 Ω differential unshielded twisted pair (UTP) or shielded twisted pair (STP), complying with IEEE 802.3u 100Base-TX; 1000Base-T: Category 5 (5E or better recommended), 100 Ω differentiated 4-pair unshielded twisted pair (UTP) or shielded twisted pair (STP) balanced, complying with IEEE 802.3ab 1000Base-T; Maximum distance: 100m
+ Два блока питания J4839A (2X)
Все это выглядит вот так:
Хочу за все 200$.
В одном месте можно подключить 48 человек на 10\100 + 24 портам из них PoE
20 гигабитных портов в разные узлы сети.
На ядро прекрасный вариант. Эта железка будет жить очень долго.
Вижу здесь недолюбливают такие гробы)
Но тем не менее комплектация очень сладкая и прошу не дорого.
Резерв снят и все еще в продаже.
Відредаговано 2late
Какое количество vlan поддерживает?
The 5300 has supported up to 256 VLANs since it was released. No need to worry about what firmware you're running. Just use the max-vlans command as mentioned above.
Поддерживает 256 вланов.
Відредаговано 2late
а максимальный влан какой?
я правильно понял, что есть команда которая открывает весь диапазон вланов 1-4094?
    • Від Constanin4ik
      HP Z6 G4
      Intel Xeon Platinum 8160 24 ядер 48 Потоков 3.70 Ггц/ БП 1000W/ NVIDIA Quadro P4000 8GB/ NO RAM/ 480GB SSD /Есть царапины
      Цена 25000грн
    • Від Oleh B
      Продаж від 10 шт.
    • Від hardware_all
      Стан нового
      40 000грн
      Бренд: HP
      Клас пристрою: офісний
      Формат паперу: A3
      Дуплекс: є
      Витратні матеріали
      Кількість картриджів: 1
      Інтерфейси
      USB: є
      Друк з USB-накопичувачів: є
      Друк з карт пам'яті: немає
      Wi-Fi: - (Опція)
      Bluetooth: немає
      NFC: немає
      Ethernet: є
      Загальні характеристики
      Ємність прийому, стор: 250
      Розміри, мм: 568x596x392
      Вага, кг: 38,5
    • Від vavanehochuha
    • Від BatoSan
      Новые в упаковках из чулана.
      DPS-460EB A 1000 грн.
      HSTNS-PL14 1100 грн.
      DPS-460BB B 400 грн.
      DPS-600PB B 600 грн.
