BDCom OLT P3310 Exception
SpiderX
BDCom перегружается (ловит exception) в случае, когда приходит Access Accept пакет от RADIUS-сервера.
Exceptions (четыре их тут) :
Switch_config#radius-server host 10.21.5.243 auth-port 1812 acct-port 1813
Switch_config#radius-server key 0 oNxVWnGmHrxwWxcwFk3L
Switch_config#zero     at       v0       v1       a0       a1       a2       a3
00000000-00000000-00000064-803d10f4-0000004b-00000000-00000000-0000004f
t0       t1       t2       t3       t4       t5       t6       t7
00000001-00000000-00000075-00000000-00000006-00000000-0000008c-41c64e6d
s0       s1       s2       s3       s4       s5       s6       s7
867300a8-85b420ac-8672fa18-00000014-85b42098-00000000-0000004b-867300a8
t8       t9       k0       k1       gp       sp       s8       ra
38753d10-00003875-38750004-00000000-80e20300-85b42008-00000000-803d0f98
pc
803d10f4
System Exception 0x4
Offset a7ffe000  Num 1
Task RADU suspend
Switch#zero     at       v0       v1       a0       a1       a2       a3
00000001-00000000-000000a0-00000000-00000006-00000000-0000008c-41c64e6d
8672fba8-85b420ac-8672fc48-00000014-85b42098-00000000-0000004b-8672fba8
8da0241c-00008da0-0da00004-00000000-80e20300-85b42008-00000000-803d0f98
pc
803d10f4
Offset a7ffe200  Num 2
Task RADU suspend
00000001-00000000-0000008a-00000000-00000006-00000000-0000008c-41c64e6d
8672fbd0-85b420ac-8672fb58-00000014-85b42098-00000000-0000004b-8672fbd0
2b89f211-00002b8a-2b8a0004-00000000-80e20300-85b42008-00000000-803d0f98
pc
803d10f4
Offset a7ffe000  Num 3
Task RADU suspend
Конфиг BDCOM, с которым проблема повторяется:
!version 10.1.0B build 14297
service timestamps log date
service timestamps debug date
logging console warnings
ip default-gateway 172.16.46.250
no spanning-tree
aaa authentication login default group gts_radius_l group radius local
aaa authentication enable default none
username admin password 0 123
!!slot 0 84
interface GigaEthernet0/1
 switchport trunk vlan-allowed 1046
 switchport trunk vlan-untagged none
 switchport mode trunk
interface GigaEthernet0/2
 shutdown
interface GigaEthernet0/3
 shutdown
interface GigaEthernet0/4
 shutdown
interface GigaEthernet0/5
 shutdown
interface GigaEthernet0/6
 shutdown
interface EPON0/1
 shutdown
interface EPON0/2
 shutdown
interface EPON0/3
 shutdown
interface EPON0/4
 shutdown
!!slot end
interface VLAN1046
 ip address 172.16.46.193 255.255.255.0
vlan 1046
 name System
vlan 1,1046
ip sshd auth-retries 3
ip sshd timeout 3600
ip sshd save
ip sshd enable
!Pending configurations for absent linecards:
Мне железку просто дали, и попросили настроить, контактов поставщика/разработчиков нет. Может кто-то отослать проблему разработчикам или дать их контакты/их представителей?
P.S. Кто-то знает, как можно затереть конфиг / сбросить в нули ? Как-то я не ожидал, что даже через консоль он будет на радиус ломиться =)
Відредаговано SpiderX
    • Від Alina1989
    • Від Інет.укр
      Продам huawei olt 5608t
      Комплект
      2x MCUD Control Card
      1x GPFD Service Board
      1x MPWD Power module
      16x GPON SFP C++
    • Від ikoko
      Продам OLTи BDCOM б.у.
    • Від sergeyko
    • Від Туйон
      У продажу OLT V-SOL V1600D, стан прекрасний, у заводскій коробці, без проблем, глюків та ремонтів, працював десь півроку, потім був встановлений 8-портовий.
      Нормальний веб-інтерфейс, коректно працював з усіма онушками. Була встановлена остання прошивка десь півроку назад.
      Зібраний гарно, є фото внутрішностей (один раз відкрив, думав може пилюка попала, але чистий, та і було цікаво глянути який він там).
      Детальні характеристики та опис почитайте ТУТ
      З головних плюсів у порівнянні з класикою BDCOM 3310 на мій погляд - порти 10Г та як мені здалося, трохі меньше жре електрики, веб інтерфейс кращій.
      Ціна 8000 грн (половина від ціни нового).
      Можлива продаж за USDT за домовленостю.
      Всі питання у особисті повідомлення.
