Не устанавливается ip на ONU P1004C1
Від loschikatilos
При этом наблюдается shutdown аплинк порта:
Apr 26 13:33:56 10.0.19.42 000342: sw1.prm45 %Apr 26 14:33:54 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to DOWN
Apr 26 13:34:13 10.0.19.42 000343: sw1.prm45 %Apr 26 14:34:12 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to UP Apr 26 13:39:08 10.0.19.42 000349: sw1.prm45 %Apr 26 14:39:07 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to DOWN Apr 26 13:39:25 10.0.19.42 000350: sw1.prm45 %Apr 26 14:39:25 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to UP И возможно (визуально не подтверждаю) ребут OLT: Apr 26 14:29:40 olt1.prm45 %EPON-ONUREG: ONU 8479.7323.0437 is registered on EPON0/1:9. Jan 1 00:00:40 olt1.prm45 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error Apr 26 14:31:22 olt1.prm45 %EPON-ONUREG: ONU 8479.7323.0437 is registered on EPON0/1:9. Jan 1 00:00:40 olt1.prm45 %OLT: Interface EPON0/1:9's CTC OAM extension negotiated successfully! Apr 26 14:32:59 olt1.prm45 %OLT: Interface EPON0/1:9's OAM Operational Status: Operational Jan 1 00:00:38 olt1.prm45 %239.0.10.1 add error, insufficient multicast VLAN xlate table space. Apr 26 14:34:36 olt1.prm45 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error Apr 26 14:38:11 olt1.prm45 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error Jan 1 00:00:41 olt1.prm45 %EPON-ONUAUTHEN: ONU 8479.7323.0375 is authenticated on EPON0/1:8. Apr 26 14:39:52 olt1.prm45 User motivprm logged in from 192.168.156.100 on vty 1
Подозреваю, так как сбивается дата.
Так же криво накатываются шаблоны:
interface EPON0/2:3
epon onu port 1 ctc vlan mode tag 1600
epon onu port 1 loopback detect
interface EPON0/2:4
description morsk_63
Основной конфиг во вл.
sw 33463
ONU исключительно P1501C1 и P1004C1
conf.txt
Від Steklorez
Здравствуйте. Ситуация такая. Местный провайдер подключает интернет по технологии GEPON. В данный момент, из-за отсутствия онушек, предлагает клиенту самостоятельно приобрести оборудование и только затем подключает к интернету. Я купил ону BDCOM P1004C1 и когда дело дошло до подключения, появилась проблема, что что линк с ней устанавливается, но интернет не хочет подниматься. У соседей взяли онушку, которую раньше ставил сам провайдер – Anykey. С ней всё сразу заработало с пол пинка. Что интересно, OLT у провайдера тоже марки BDCOM. Подскажите, пожайлуста, в чём может быть проблема?
