Куплю Л2 менеджмент світч, 16-24 10\100\1000 мідних портів.
By german22
Продам:
1.Linksys Gigabit 8-port Workgroup Switch - 400 грн
2. SITECOM Network Giga Switch 5 port - 250 грн
Все порты рабочие.
By SaleDatanet
Продается коммутатор HUAWEI S5700S-28P-LI-AC 24 Ethernet 10/100/1000 ports, 4 Gig SFP, AC 110/220V
http://e.huawei.com/ru/products/enterprise-networking/switches/campus-switches/s5700-li-model
Описание: Управляемый коммутатор уровня 2, 24 порта 10/100/1000Base-T и 4 порта GE SFP
Состояние: Новый
Цена: $399 (торг)
Манибек: 1 неделя
By Osiris
Netgear GSM712 12-port Managed Gigabit Switch = 70$
Features/Specifications: NETGEAR GSM712 10-Port 10/100/1000 Mbps & 2-Port GBIC Managed Fast Ethernet Switch
General Features: Network Protocol and Standards Compatibility: IEEE 802.3 10BASE-T, IEEE 802.3u 100BASE-TX, IEEE 802.3z 1000BASE-SX, IEEE 802.3ab 1000BASE-T, IEEE 802.3x flow control
Management Specifications: IEEE 802.1Q Static VLAN (Up to 64) IEEE 802.1p Class of Service (CoS) IEEE 802.1D Spanning Tree Protocol Port Trunking - Manual as per IEEE 802.3ad Link Aggregation Control (LACP) IGMP Snooping Support Port Mirroring Support RFC 1157 SNMP RFC 1757 RMON groups 1, 2, 3, and 9 RFC 1213 MIB II RFC 1643 Ethernet Interface MIB RFC 1493 Bridge MIB RFC 951 BootP RFC 2131 DHCP RFC 2998 DiffServ RFC 2865 RADIUS Private Enterprise MIB
User Interfaces: Command Line Interface via console port or Telnet Command Menu Interface via console port or Telnet Web-based management via embedded HTTP server
Performance Specifications: Forwarding modes: Store-and-forward Bandwidth: 24 Gbps (non-blocking) Packet forwarding: 17.8 Mpps Switch latency: < 80 μs for 64-byte frames (100 Mbps to 100 Mbps) System memory: 16 MB Packet buffer memory: 1.5 MB Address database size: 8,000 media access control (MAC) addresses per system Addressing: 48-bit MAC address Acoustic noise: (ANSI-S10.12) 45 dB Heat Dissipation: 18.99 BTU/hr
Physical Interfaces: Ten (10) RJ-45 connectors for 10BASE-T, 100BASE-TX, and 1000BASE-T (Auto Uplink on all ports) Two (2) Gigabit Interface Converter (GBIC) slots for GBIC modules One (1) RS-232 Console Port
LEDs: Per port: (10/100/1000 and Gigabit): Link, Mode (Max Speed, Activity, Full Duplex) Per device: Power
Power Specifications: 100 - 240V 50/60 Hz 2A max.
Unit Dimensions: 1.7 x 17.25 x 10.1-inches (H x W x D, approximate)
Regulatory Approvals: FCC CE cUL C-Tick WEEE TUV Package Includes: NETGEAR GSM712 10-Port 10/100/1000 Mbps & 2-Port GBIC Managed Fast Ethernet Switch Power cord RS-232 cable Mount kit Additional Information: Notes: NETGEAR Model: GSM712 UPC: 6 06449 03403 5
Requirements: Available power outlet Suitable network environment
By blackjeri
Ціна 150$
24 x 10/100/1000Base-T Ethernet Ports, 4x1000Base-X SFP Combo Ports
Type:RJ45, SFP Ethernet
