warham 0 Опубликовано: 2006-11-10 12:37:27 Share Опубликовано: 2006-11-10 12:37:27 Здравствуйте. Подскажите пожалуйста почему при компиляции сервера stg-2.402.9.7 на Suse 10.0 Linux выдает ошибки? Библиотека libexpat установлена в /usr/lib/. inetsrv:/home/diman/2006.11.01/server/stg-2.402.9.7/projects/stargazer # ./build ############################################################################# Building STG 2.4 for Linux ############################################################################# Makeing stg_logger.lib ../Makefile.in:74: deps: No such file or directory g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c stg_logger.cpp ar rc libstg_logger.a stg_logger.o ranlib libstg_logger.a cp stg_logger.h ../../include/ cp libstg_logger.a ../../lib/ Makeing crypto.lib ../Makefile.in:74: deps: No such file or directory g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c ag_md5.c g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c blowfish.cpp ar rc libcrypto.a ag_md5.o blowfish.o ranlib libcrypto.a cp ag_md5.h blowfish.h ../../include/ cp libcrypto.a ../../lib/ Makeing common.lib ../Makefile.in:74: deps: No such file or directory g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c debug.c g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c stg_error.c g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c common.cpp ar rc libstg_common.a debug.o stg_error.o common.o ranlib libstg_common.a cp debug.h stg_error.h common.h ../../include/ cp libstg_common.a ../../lib/ Makeing conffiles.lib ../Makefile.in:74: deps: No such file or directory g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c conffiles.cpp ar rc libconffiles.a conffiles.o ranlib libconffiles.a cp conffiles.h ../../include/ cp libconffiles.a ../../lib/ Makeing hostallow.lib ../Makefile.in:74: deps: No such file or directory g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c hostallow.cpp ar rc libhostallow.a hostallow.o ranlib libhostallow.a cp hostallow.h ../../include/ cp libhostallow.a ../../lib/ Makeing pinger.lib ../Makefile.in:74: deps: No such file or directory g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c pinger.cpp ar rc libstg_pinger.a pinger.o ranlib libstg_pinger.a cp pinger.h ../../include/ cp libstg_pinger.a ../../lib/ Makeing dotconfpp.lib ../Makefile.in:74: deps: No such file or directory g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c dotconfpp.cpp g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c mempool.cpp ar rc libdotconfpp.a dotconfpp.o mempool.o ranlib libdotconfpp.a cp dotconfpp.h mempool.h ../../include/ cp libdotconfpp.a ../../lib/ Makefile:95: deps: No such file or directory g++ -c admin.cpp -g3 -Wall -I ../../include -DLINUX ../../include/base_store.h:25: warning: ‘class BASE_STORE’ has virtual functions but non-virtual destructor /usr/include/c++/4.0.2/bits/stl_construct.h: In function ‘void std::_Destroy(_ForwardIterator, _ForwardIterator, _Allocator) [with _ForwardIterator = RESETABLE<std::string>*, _Allocator = std::allocator<RESETABLE<std::string> >]’: /usr/include/c++/4.0.2/bits/stl_vector.h:273: instantiated from ‘std::vector<_Tp, _Alloc>::~vector() [with _Tp = RESETABLE<std::string>, _Alloc = std::allocator<RESETABLE<std::string> >]’ ../../include/user_conf.h:74: instantiated from here /usr/include/c++/4.0.2/bits/stl_construct.h:174: error: no matching function for call to ‘std::allocator<RESETABLE<std::string> >::destroy(std::string*)’ /usr/include/c++/4.0.2/ext/new_allocator.h:109: note: candidates are: void __gnu_cxx::new_allocator<_Tp>::destroy(_Tp*) [with _Tp = RESETABLE<std::string>] /usr/include/c++/4.0.2/bits/stl_construct.h: In function ‘void std::_Destroy(_ForwardIterator, _ForwardIterator, _Allocator) [with _ForwardIterator = __gnu_cxx::__normal_iterator<RESETABLE<std::string>*, std::vector<RESETABLE<std::string>, std::allocator<RESETABLE<std::string> > > >, _Allocator = std::allocator<RESETABLE<std::string> >]’: /usr/include/c++/4.0.2/bits/vector.tcc:125: instantiated from ‘typename std::vector<_Tp, _Alloc>::iterator std::vector<_Tp, _Alloc>::erase(__gnu_cxx::__normal_iterator<typename _Alloc::pointer, std::vector<_Tp, _Alloc> >, __gnu_cxx::__normal_iterator<typename _Alloc::pointer, std::vector<_Tp, _Alloc> >) [with _Tp = RESETABLE<std::string>, _Alloc = std::allocator<RESETABLE<std::string> >]’ /usr/include/c++/4.0.2/bits/stl_vector.h:425: instantiated from ‘void std::vector<_Tp, _Alloc>::resize(size_t, const _Tp&) [with _Tp = RESETABLE<std::string>, _Alloc = std::allocator<RESETABLE<std::string> >]’ /usr/include/c++/4.0.2/bits/stl_vector.h:442: instantiated from ‘void std::vector<_Tp, _Alloc>::resize(size_t) [with _Tp = RESETABLE<std::string>, _Alloc = std::allocator<RESETABLE<std::string> >]’ ../../include/user_conf.h:75: instantiated from here /usr/include/c++/4.0.2/bits/stl_construct.h:174: error: no matching function for call to ‘std::allocator<RESETABLE<std::string> >::destroy(std::string*)’ /usr/include/c++/4.0.2/ext/new_allocator.h:109: note: candidates are: void __gnu_cxx::new_allocator<_Tp>::destroy(_Tp*) [with _Tp = RESETABLE<std::string>] gmake: *** [admin.o] Ошибка 1 inetsrv:/home/diman/2006.11.01/server/stg-2.402.9.7/projects/stargazer # Ссылка на сообщение Поделиться на других сайтах
Seico 0 Опубліковано: 2006-11-22 04:22:24 Share Опубліковано: 2006-11-22 04:22:24 Такая же проблема. Есть решение??? Ссылка на сообщение Поделиться на других сайтах
egor2fsys 5 Опубліковано: 2006-11-22 04:30:31 Share Опубліковано: 2006-11-22 04:30:31 обновите gcc Ссылка на сообщение Поделиться на других сайтах
Seico 0 Опубліковано: 2006-11-24 11:21:28 Share Опубліковано: 2006-11-24 11:21:28 Стоит gcc 4.1 версия.... И не компилиться.... Ссылка на сообщение Поделиться на других сайтах
egor2fsys 5 Опубліковано: 2006-11-24 17:06:24 Share Опубліковано: 2006-11-24 17:06:24 для линухов собранная свежая версия лежит здесь: http://shareua.com/files/5e410f/stg_2.402.tar.bz2.html собрано на Red Hat linux, gcc version 3.4.6 Ссылка на сообщение Поделиться на других сайтах
Seico 0 Опубліковано: 2006-11-28 03:50:26 Share Опубліковано: 2006-11-28 03:50:26 И что теперь с этими файлами делать? Проинсталить с варнингами, а потом заменить? или в инсталяторе заменить? Каков порядок действия?? Ссылка на сообщение Поделиться на других сайтах
egor2fsys 5 Опубліковано: 2006-11-28 05:07:57 Share Опубліковано: 2006-11-28 05:07:57 Собирать не надо, это уже скомпиленные файлы. Просто развернуть из архива демона в /usr/sbin/, а библиотеки в /usr/lib/stg/ Ссылка на сообщение Поделиться на других сайтах
Seico 0 Опубліковано: 2006-11-28 05:35:42 Share Опубліковано: 2006-11-28 05:35:42 так ведь когда делаем ./build вылетает много предупреждений как все таки с нуля установить stargazer?? Ссылка на сообщение Поделиться на других сайтах
Seico 0 Опубліковано: 2006-11-30 04:09:22 Share Опубліковано: 2006-11-30 04:09:22 egor2fsys, скажи все таки, как ставить с нуля на SuSE 10. Сначала сделать ./Build и не обращая внимания на warning (g++ -c admin.cpp -g3 -Wall -I ../../include -DLINUX ../../include/base_store.h:25: warning: 'BASE_STORE' has virtual functions but non-virtual destructor g++ -c admins.cpp -g3 -Wall -I ../../include -DLINUX ../../include/base_store.h:25: warning: 'BASE_STORE' has virtual functions but non-virtual destructor g++ -c main.cpp -g3 -Wall -I ../../include -DLINUX) сделать ./install. А потом заменить из архива http://shareua.com/files/5e410f/stg_2.402.tar.bz2.html демона в /usr/sbin/, а библиотеки в /usr/lib/stg/ . А таким образом StarGazer работать будет правильно? не уверен. Скомпиленные файлы библиотек, с учетом warning, весят в 2 раза больше чем в архиве. Что же все таки делать?? Ссылка на сообщение Поделиться на других сайтах
egor2fsys 5 Опубліковано: 2006-11-30 05:00:35 Share Опубліковано: 2006-11-30 05:00:35 Все будет правильно работать. Это пострипанные уже бинарники, у кучи людей работает, будет и у вас. Ссылка на сообщение Поделиться на других сайтах
XoRe 0 Опубліковано: 2006-11-30 15:48:16 Share Опубліковано: 2006-11-30 15:48:16 Учили бы програмирование... А заодно английский. 'BASE_STORE' has virtual functions but non-virtual destructor: означает "'BASE_STORE' имеет виртуальные функции, но не виртуальный деструктор". Ссылка на сообщение Поделиться на других сайтах
