Куплю коммутаторы Cisco 3750G(X) серии
Доброго дня, куплю  коммутаторы Cisco 3750G(X) серии
нужно  - 2шт.
мин. - 24 порта и больше
Цена договорная
Ваши предложение пишите в лс(модель, год, кол-во и цена)
Ваге
+380636106898
Такая есть:
Master_Switch_3750G uptime is 3 days, 3 hours, 44 minutes
System returned to ROM by power-on
System image file is "flash:/c3750-ipservicesk9-mz.122-52.SE/c3750-ipservicesk9-mz.122-52.SE.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision C0) with 131072K bytes of memory.
Processor board ID FOC0909U12A
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
30 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:13:7F:59:D1:00
Motherboard assembly number     : 73-9637-08
Power supply part number        : 341-0098-01
Motherboard serial number       : FOC09084SCS
Power supply serial number      : DCA0906004Y
Model revision number           : C0
Motherboard revision number     : A0
Model number                    : WS-C3750G-24TS-S1U
System serial number            : FOC0909U12A
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CAT09060LZN
Top Assembly Part Number        : 800-27030-02
Top Assembly Revision Number    : B0
Version ID                      : 02
CLEI Code Number                : CNMWS00ARB
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24TS-1U  12.2(52)SE            C3750-IPSERVICESK9-M
Configuration register is 0xF
    • Від kotqq
      Характеристики:
      Модель: Cisco Nexus 3548-X
      Кількість портів: 48 x 10GbE
      Затримка: < 250 нс
      Підтримка VXLAN: Так
      Управління:  CLI, SNMP, API
      Форм-фактор: 1U
      Енергоспоживання: ~250 Вт
      Розміри: 43.9 x 43.2 x 4.4 см
      Вага: 7.9 кг
    • Від GustavFischer
      Вітаю!
      Замовили світч cisco nexus 3164q (N3K-C3164Q-40GE) на еBay, який прийшов з "дохлим" ssd.
      Нажаль не маю можливості завантажити прошивку з офіційного сайту https://software.cisco.com/download/home/286254956/type/286280105/release/9.3(6) для заміни диску і запуску в роботу обладнання. У вільному доступі також не зміг нічого знайти.
      Будь ласка, поділіться хто має прошивку на дане обладнання, або, хто має можливість, допоможіть скачати з офіційного сайту.
      Заздалегідь дякую!
    • Від kotqq
      Продам IP-телефони Cisco CP-8961-C-K9, ціна 6000грн
    • Від kotqq
      Продам VoIP телефони Cisco 7821, в наявості, гарний стан, ціна 1500грн
    • Від yurii11
      пишите
