Від Alina1989
Hey, fellows, our S6865-56YC switch is a high-performance and high-density uplink switch with 25Gigabit Downlink & 100Gigabit Uplink, which is designed and developed by our company independently. The whole switch adopts advanced hardware structure design and pluggable power redundancy design.
It can support a maximum of 48 *25Gigabit ports, 8*100G uplink ports, provide full port L2/L3 line speed forwarding capability, and support IPV6. This device provides rich service features and powerful functions, such as ACL policies, flexible Q-in-Q, and network security protection.
Meanwhile, the product has the highest 10 Gigabit port density and the largest switching capacity of the same grade equipment in the industry, and supports full-port line speed forwarding. The elastic stack function virtualizes multiple devices into a logical entity, which can expand port and switching capacity, manage, upgrade, and maintain multiple devices in a unified manner.
To meet the requirements of large data traffic and non-blocking transmission in data centers, the product provides powerful cache capabilities and supports advanced cache scheduling mechanisms to ensure the maximum effective utilization of the device's cache capabilities. It is designed to meet the requirements of high-density and high-bandwidth network applications in next-generation enterprise networks, data centers and metropolitan area networks.
It can be applied to the Ethernet aggregation layer or access layer of network operators or campuses, as well as the access layer of data centers and the core layer of small and medium-sized enterprises, and provides rich server access solutions for data centers.
S6865-56YC (1+1 modular redundant power supply)
More details, contact me directly!
Whatsapp/ Viber/ Wehcat : +86 18086327779
Skype: alinaquan14@hotmail.com
Від tkachik
Продаю пару новых VDSL модемов. Модемы работают друг с другом по одной паре медных проводов. Позволяют получить скорость до 80 Мбит/с (симметричный канал). Интерфейс - 100Мб Ethernet медный.
Скорость соединения модемов зависит от протяжённости линии и её качества.
Результаты тестов на разных линиях:
На кабеле П-274 длиной 500м состоящий из 3 скрученых кусков 100м+200м+200м (скрутки непропаянные) 18Мбит/16Мбит
На кабеле ТПП100х2х0.4 длина 1,5 км (знаю что на этой длине 2 муфты и 2 кросса) 10Мбит/10Мбит
На катушке кабеля КПП-ВП 0.5мм длина 305 м 40Мбит/30Мбит.
Питание 12В 1А
цена за пару модемов 3000 грн.
Від Whitemankpi
Добрий день, намагаюсь знайти провайдера в м Івано Франківськ по вул бельведерська 35 для встановлення енергонезалежного підключення
Від yama
подскажите по фото как к одной ONU подключено два роутера по ethernet ?
Gpon приходит , а на выходе подключено два роутера по ethernet
свича/комутатора не вижу ... что за фантастика ...
Как я понимаю по фото : 8 парний кабель разделили на два 4 парн. и завели двум абонентам у каждого по роутеру ... но как ? ведь из ONU один выход ethernet или бывает два???
Від SergZTE
Продам DSL-3785 - гігабітный маршрутизатор з модемом Refurbished. Є кількість.
Ціна : 1000 грн
Універсальний маршрутизатор зі встроенним модемом VDSL/ADSL2+
Двохдіапазонний бездротовий AC1200 (867 Мбіт/с на 5 ГГц + 300 Мбіт/с на 2,4 ГГц)
-802.11ac с MU-MIMO
-4 гігабітных локальних мереж
-1 порт USB 2.0 для обміну мультимедіа
Вмонтованний модем ADSL2+/VDSL2 для подключення до високошвидкісному широкополосному інтернет-зєднанню.
Детальний опис : https://www.dlink.com/en/products/dsl-3785-wireless-ac1200-dual-band-gigabit-adsl2vdsl2-modem-router
