продам Cisco 3750G
Продано
Хотелка 600 у.е.
Master_Switch_3750G uptime is 3 days, 3 hours, 44 minutes
System returned to ROM by power-on
System image file is "flash:/c3750-ipservicesk9-mz.122-52.SE/c3750-ipservicesk9-mz.122-52.SE.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision C0) with 131072K bytes of memory.
Processor board ID FOC0909U12A
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
30 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:13:7F:59:D1:00
Motherboard assembly number     : 73-9637-08
Power supply part number        : 341-0098-01
Motherboard serial number       : FOC09084SCS
Power supply serial number      : DCA0906004Y
Model revision number           : C0
Motherboard revision number     : A0
Model number                    : WS-C3750G-24TS-S1U
System serial number            : FOC0909U12A
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CAT09060LZN
Top Assembly Part Number        : 800-27030-02
Top Assembly Revision Number    : B0
Version ID                      : 02
CLEI Code Number                : CNMWS00ARB
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24TS-1U  12.2(52)SE            C3750-IPSERVICESK9-M
Configuration register is 0xF
  • 5 weeks later...
Гость
    • Від rusol
      ПРОДАМ Cisco 7206VXR/NPE-G1
      Комплект:
      шассі
      npe/g1
      блок живлення
      блок живлення
      $500
    • Від Oleh B
      Ціна 8900 грн за 1 шт с 2 БЖ.
      Можемо зробити сервери
    • Від xserver
      Software
      BIOS: version 07.69
      BIOS compile time: 04/07/2021
    • Від sys.and.networks
      Чистые. Не запароленные.
      Цена - 2499 грн/шт.
    • Від Oleh B
      Для связи, можете писать сюда
