Проблема с bdcom p36xx
LIKO
Доброго времени суток форумчане!
Есть проблема с bdcom p3616, olt в деваулте, но после подключения ОНУ, происходит странное, в конфиг на ону прописывается влан 1425, соответственно ниче не работает.
Вот кусочек ранинг конфиг
interface EPON0/6:1
 switchport port-security dynamic maximum 2
  epon onu port 1 ctc vlan mode tag 1425
  epon onu port 1 ctc loopback detect
  epon onu port 1 ctc notify loopback
В логах пишет сдедущее
Switch_config#Jan  1 00:04:17 %EPON-ONUREG: ONU 001a.a995.fbc0 is registered on EPON0/6:1.
Jan  1 00:04:17 %EPON-ONUAUTHEN: ONU 001a.a995.fbc0 is authenticated on EPON0/6:1.
Jan  1 00:04:17 %LINE-5-UPDOWN: Line on Interface EPON0/6, changed state to up
Jan  1 00:04:17 %LINEPROTO-5-UPDOWN: Line protocol on Interface EPON0/6, changed state to up
Jan  1 00:04:18 %OLT: Interface EPON0/6:1's OAM Operational Status: Operational
Jan  1 00:04:18 %LINEPROTO-5-UPDOWN: Line protocol on Interface VLAN1, changed state to up
Jan  1 00:04:18 %LINE-5-UPDOWN: Line on Interface EPON0/6, changed state to down
Jan  1 00:04:18 %LINEPROTO-5-UPDOWN: Line protocol on Interface EPON0/6, changed state to down
Jan  1 00:04:19 %LINEPROTO-5-UPDOWN: Line protocol on Interface VLAN1, changed state to down
Jan  1 00:04:20 %LINE-5-UPDOWN: Line on Interface EPON0/6, changed state to up
Jan  1 00:04:20 %LINEPROTO-5-UPDOWN: Line protocol on Interface EPON0/6, changed state to up
Jan  1 00:04:20 %LINEPROTO-5-UPDOWN: Line protocol on Interface VLAN1, changed state to up
Jan  1 00:04:20 %LINE-5-UPDOWN: Line on Interface EPON0/6, changed state to down
Jan  1 00:04:20 %LINEPROTO-5-UPDOWN: Line protocol on Interface EPON0/6, changed state to down
Jan  1 00:04:20 %LINEPROTO-5-UPDOWN: Line protocol on Interface VLAN1, changed state to down
Jan  1 00:04:20 %EPON-ONUDEREG: ONU 001a.a995.fbc0 is deregistered on EPON0/6:1.
Jan  1 00:04:21 %LINE-5-UPDOWN: Line on Interface EPON0/6, changed state to up
Jan  1 00:04:21 %LINEPROTO-5-UPDOWN: Line protocol on Interface EPON0/6, changed state to up
Jan  1 00:04:21 %EPON-ONUREG: ONU 001a.a995.fbc0 is registered on EPON0/6:1.
Jan  1 00:04:21 %EPON-ONUAUTHEN: ONU 001a.a995.fbc0 is authenticated on EPON0/6:1.
Jan  1 00:04:21 %OLT: Interface EPON0/6:1's OAM Operational Status: Operational
Jan  1 00:04:21 %LINEPROTO-5-UPDOWN: Line protocol on Interface VLAN1, changed state to up
Jan  1 00:04:23 %OLT: Interface EPON0/6:1's CTC OAM extension negotiated successfully!
Может ктото что подскажет по даному поводу? Заранее всем благодарен
Не то слово....Вроде как убрал ету фигню, но незнаю, правильно ли ето. В директории был файл config.db незнаю зачем он, может он там нужен, но я его убил и вроде как все работает по дефаулту. У меня есть 33 серия там его точно нет, там три файла и все, а вот с 36 сталкиваюсь впервые. Может кто подскажет, что за чудо файл и может ли там храниться, какой то конфиг????
Охренеть подход: сначала удалил, потом подумал что именно. :facepalm:
Конфиг онушек как раз там и хранится.
Покажите весь конфиг, пароли и явки можно заменить звездочками ;)
а как же мне все скинуть по дефаулту? или как отредактировать даный файл? Делете не помогает. В стартап конфиг все пусто, а ранин появляются вланы
    • Від tadesky
      Продам б/в BDCOM P3616-2TE OLT .
      Повністю робочий, без нюансів, знятий після модерну.  Комплектований резервним БЖ.
      Оціночна вартість 40 тис. грн.
      За потреби можна комплектувати SFP Picotel EPON SFP PX++ = 600 грн/шт.
      Пишіть в особисті.
    • Від forella
      Имеется такая ситуация.
      топология: абонент---ону---bdcom p3310---cisco 4948--- далее 2 пути, 99% идут на линуксовый шлюз, оставшиеся(избранные, назовем их так) 1% на микротик по оттдельному vlan.
      олт 13шт. каждая олт оттдельным портом на 4948 подключена. все аналогично работают как описано выше.
      наблюдается вот такая ситуация на циско:
      *Apr 20 03:17:28.873: %C4K_EBM-4-HOSTFLAPPING: Host 78:9A:18:C7:61:85 in vlan 321 is moving from port Gi1/11 to port Gi1/7 *Apr 20 03:17:32.289: %C4K_EBM-4-HOSTFLAPPING: Host C4:AD:34:02:A9:FA in vlan 321 is moving from port Gi1/5 to port Gi1/11 *Apr 20 03:17:33.489: %C4K_EBM-4-HOSTFLAPPING: Host C4:AD:34:02:A9:FA in vlan 321 is moving from port Gi1/11 to port Gi1/5 *Apr 20 03:17:34.273: %C4K_EBM-4-HOSTFLAPPING: Host 74:4D:28:4D:3D:88 in vlan 321 is moving from port Gi1/10 to port Gi1/11 *Apr 20 03:17:34.277: %C4K_EBM-4-HOSTFLAPPING: Host 74:4D:28:4D:3D:88 in vlan 321 is moving from port Gi1/11 to port Gi1/10 *Apr 20 03:17:43.769: %C4K_EBM-4-HOSTFLAPPING: Host 78:9A:18:C7:61:85 in vlan 321 is moving from port Gi1/7 to port Gi1/11 *Apr 20 03:17:43.973: %C4K_EBM-4-HOSTFLAPPING: Host 78:9A:18:C7:61:85 in vlan 321 is moving from port Gi1/11 to port Gi1/7 *Apr 20 03:17:47.289: %C4K_EBM-4-HOSTFLAPPING: Host C4:AD:34:02:A9:FA in vlan 321 is moving from port Gi1/5 to port Gi1/11 vlan 321 это те самые избранные, и по логам видно что связующее звено 11 порт, за ней олт. (порты 5,7,10 так же олт)
      что было сделано:
      на олт за 11 портом выключены абоненты имеющие отношение к влан 321 - флапы продолжились.
      выключены пон порты по очереди и все сразу - флапы продолжились.
      выключен порт 11 на циско - флапы прекратились.
      включен порт, но удален влан 321 на циско - флапы прекратились.
      собственно вопрос - это глюк прошивки олт, что при выключеных пон портах флапы продолжаются, либо не там ищу причину?
    • Від Emanon
    • Від Alina1989
    • Від CoUL
      Sync users ONU скрипт.
