Куплю программатор VIZIT-DM08
Від loschikatilos
BDCOM(tm) P3310C Software, Version 10.1.0E Build 37276
Building configuration...
Current configuration:
!version 10.1.0E build 37276
service timestamps log date
service timestamps debug date
hostname olt2.prm46
port-protected 1
ip default-gateway 10.0.19.97
no spanning-tree
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
username prm password 0 708
epon oam-version 1 0x21
epon oam-version 2 0x20
epon onu-config-template T1
cmd-sequence 1 epon onu port 1 ctc vlan mode tag 1903
cmd-sequence 2 epon onu port 2 ctc vlan mode tag 720
cmd-sequence 3 epon onu port 3 ctc vlan mode tag 339
cmd-sequence 4 epon onu port 3 ctc mcst tag-stripe enable
cmd-sequence 5 epon onu port 3 ctc mcst mc-vlan add 666
cmd-sequence 6 epon onu all-port loopback detect
!!slot 0 89
interface GigaEthernet0/1
switchport trunk vlan-untagged none
switchport mode trunk
switchport pvid 339
interface GigaEthernet0/2
shutdown
interface GigaEthernet0/3
shutdown
interface GigaEthernet0/4
shutdown
interface GigaEthernet0/5
shutdown
interface GigaEthernet0/6
shutdown
interface EPON0/1
epon pre-config-template T1 binded-onu-llid 1-64
interface EPON0/3:6
epon onu port 1 ctc vlan mode tag 1903 priority 0
epon onu port 1 loopback detect
!slot end
interface VLAN204
description --mgmt--
ip address 10.0.19.113 255.255.255.224
vlan 204
name mgmt4
vlan 333
name iptv
vlan 339
name pik:iptv-new
vlan 666
name iptv_mcast
vlan 720
name VoIP
vlan 1900
name pppoe
vlan 1902
name pppoe-new.prm9
vlan 1903
name pppoe.olt.prm9
vlan 1,204,333,339,666,720,1900,1902-1903
ip mcst enable
ip mcst mrouter interface GigaEthernet0/1
ip mcst mc-vlan 666 range 239.0.10.1 - 239.0.10.255
ip http server
snmp-server community 0 u RO
banner message
text PTK, Access Network, Perm, Russia, PoP Prm21
text Disconnect IMMEDIATELY if you are not an authorized person !!!
text Contact information: email: noc@relan.ru
time-zone EKB 6 0
ntp server 192.168
!Pending configurations for absent linecards:
!No configurations pending global
О проблеме:
У клиента PPPOE с белым ip.
Так же у него интернет домофон TIS OBERON
Нет связи с удаленным сервером с устройства.
При подключении домофона в коммутатор до BDCOM все работает.
Перепробовали все. В логах пусто. Руки опущены. Клиент в ярости.
Интернет работает отлично.
Уповаю на Вашу помощь.
Від gold2003a
Продам новые трубки для домофона - Устройство квартирное переговорное Vizit УКП-12M
Характеристики:
- дуплексная связь;
- кнопка отпирания замка;
- светодиодная индикация сигнала вызова;
- ступенчатая регулировка громкости вызова;
- габаритные размеры, мм, (ШхВхГ) - 54х200х40;
- диапазон рабочих температур, °C - от плюс 5 до плюс 45.
В наличии несколько десятков.
От 10 шт. - 130 грн./шт.
Від MasMaster
Заказал 4 ключа по предоплате.
Ключи пришли не рабочие, варианты обмена не рассматриваются.
Девушка на телефоне выслушать не хочет, разговаривать не хочет...
Мой вопрос был такой - можно ли универсальный ключ удалить или заблокировать в домофоне? Девушка сказала что нет, нельзя и все будет работать..
"Я Вас предупреждала что ключи могут не работать" - никто не предупреждал!
"Я Вас предупреждала что возврата не будет" - не предупреждали!
Оказывается что есть какие-то фильтры которые могу заблокировать ключи...
Оказывается я не первый с жалобами и она знает что например в Новой Каховке (рядом с нами) их ключи тоже не работают..
Единственное пожелание было предоплата - потому что я могу получить их на НП, скопировать и отправить назад как не рабочие.
Будьте осторожны при покупке в keyforce
