DVB карта tbs6984 вещает iptv в astra на debian 7 64-bit работает в течении месяца после чего перестает работать в системе выведется, кто подскажет в чем может быть проблема ?
ls /dev/dvb/
adapter0  adapter1  adapter2  adapter3
лог астры при старте
Jan 07 05:15:04: INFO: [dvb_input 0:0] fe has lock. status:SCVYL signal:74% snr:75%
Jan 07 05:15:04: INFO: [dvb_input 1:0] fe has lock. status:SCVYL signal:74% snr:63%
Jan 07 05:15:05: INFO: [dvb_input 2:0] fe has lock. status:SCVYL signal:74% snr:70%
Jan 07 05:15:05: INFO: Starting Astra 4.4.98
Jan 07 05:15:05: INFO: [dvb_input 3:0] fe has lock. status:SCVYL signal:49% snr:73%
Jan 07 05:15:11: ERROR: [M2 #1] Bitrate:0Kbit/s
Jan 07 05:15:12: ERROR: [M2 #1] Bitrate:0Kbit/s
Jan 07 05:15:13: ERROR: [M2 #1] Bitrate:0Kbit/s
Jan 07 05:15:14: ERROR: [M2 #1] Bitrate:0Kbit/s
Jan 07 05:15:14: ERROR: [M2] Failed to switch to reserve
dmesg
[2931744.865194]  ffff8800b77240c4 ffffffff8150ac96 ffff8800b7724000 ffffffff810bd10d
[2931744.865196]  ffff8800b7724000 0000000000000012 0000000000000000 ffffffff810bd631
[2931744.865197]  0000000000000000 0000000000000000 0000000000000012 0000000000000000
[2931744.865198] Call Trace:
[2931744.865199]  <IRQ>  [<ffffffff8150ac96>] ? dump_stack+0x41/0x51
[2931744.865205]  [<ffffffff810bd10d>] ? __report_bad_irq+0x2d/0xc0
[2931744.865207]  [<ffffffff810bd631>] ? note_interrupt+0x241/0x290
[2931744.865209]  [<ffffffff810bae51>] ? handle_irq_event_percpu+0xa1/0x190
[2931744.865210]  [<ffffffff810baf78>] ? handle_irq_event+0x38/0x60
[2931744.865211]  [<ffffffff810be173>] ? handle_fasteoi_irq+0x83/0x150
[2931744.865214]  [<ffffffff810150ed>] ? handle_irq+0x1d/0x30
[2931744.865216]  [<ffffffff81513bf9>] ? do_IRQ+0x49/0xe0
[2931744.865218]  [<ffffffff81511aad>] ? common_interrupt+0x6d/0x6d
[2931744.865218]  <EOI>  [<ffffffff81074956>] ? get_next_timer_interrupt+0x1d6/0x250
[2931744.865223]  [<ffffffff813ddb52>] ? cpuidle_enter_state+0x52/0xc0
[2931744.865225]  [<ffffffff813ddb48>] ? cpuidle_enter_state+0x48/0xc0
[2931744.865226]  [<ffffffff810a7e68>] ? cpu_startup_entry+0x2f8/0x400
[2931744.865228]  [<ffffffff81903071>] ? start_kernel+0x492/0x49d
[2931744.865229]  [<ffffffff81902a04>] ? set_init_arg+0x4e/0x4e
[2931744.865230]  [<ffffffff81902120>] ? early_idt_handlers+0x120/0x120
[2931744.865231]  [<ffffffff8190271f>] ? x86_64_start_kernel+0x14d/0x15c
[2931744.865232] handlers:
[2931744.865340] [<ffffffffa09ecba0>] saa716x_tbs6984_pci_irq [saa716x_tbs_dvb]
[2931744.865477] Disabling IRQ #18
Відредаговано speedfire87
