FTTH_VN 59 Posted 2016-02-23 09:40:03 Share Posted 2016-02-23 09:40:03 (edited) Приветствую всех. Есть такая проблема олт режет трафик между ону по умолчанию, отключить не получается. show version-running PhyLoc FileType VerType VerTag BuildTime VerLength -------------------------------------------------------------------------------- 0/0/2 EPFCB MVR V1.2.3P1 2013-02-28 05:04:28 1903865 0/0/2 EPFCB BT V1.2.3 2012-10-16 17:23:15 333344 0/0/3 EPFCB MVR V1.2.3P1 2013-02-28 05:04:28 1903865 0/0/3 EPFCB BT V1.2.3 2012-10-16 17:23:15 333344 0/0/6 EPFCB MVR V1.2.3P1 2013-02-28 05:04:28 1903865 0/0/6 EPFCB BT V1.2.1P1 2011-04-25 11:16:19 333984 0/0/7 GCSAS MVR V1.2.3P1 2013-02-28 03:22:00 7962100 0/0/7 GCSAS BT V1.2.3 2012-10-16 18:01:28 432832 0/0/8 GCSAS MVR V1.2.3P1 2013-02-28 03:22:00 7962100 0/0/8 GCSAS BT V1.2.3 2012-10-16 18:01:28 432832 0/0/14 EIG MVR V1.2.3P1 2013-02-28 04:26:36 609714 0/0/14 EIG BT V1.2.3 2012-10-16 17:12:04 325232 show running-config interface epon-olt_0/6/1 Building configuration... ! interface epon-olt_0/6/1 p2p mode group p2p group 1 p2p group-name 1 onu onu 1 type ZTE-F401 mac 0040.с053.b07c ip-cfg static onu 2 type ZTE-F401 mac 0022.d836.c463 ip-cfg static ! end show running-config interface epon-onu_0/6/1:1 Building configuration... ! interface epon-onu_0/6/1:1 admin enable ems-autocfg-request disable encrypt direction downstream disable vport 1 join-p2p-group 1 switchport mode hybrid vport 1 switchport default vlan 100 vport 1 port-location sub-option remote-id enable vport 1 port-location sub-option remote-id name 61 vport 1 dhcp-option82 enable vport 1 dhcp-option82 trust true replace vport 1 ip dhcp snooping enable vport 1 ! end show running-config interface epon-onu_0/6/1:2 Building configuration... ! interface epon-onu_0/6/1:2 admin enable ems-autocfg-request disable encrypt direction downstream disable vport 1 join-p2p-group 1 switchport mode hybrid vport 1 switchport default vlan 100 vport 1 port-location sub-option remote-id enable vport 1 port-location sub-option remote-id name 62 vport 1 dhcp-option82 enable vport 1 dhcp-option82 trust true replace vport 1 ip dhcp snooping enable vport 1 ! end pon-onu-mng epon-onu_0/6/1:1 isolation disable auto-config vlan port eth_0/1 mode transparent ! ! pon-onu-mng epon-onu_0/6/1:2 isolation disable auto-config vlan port eth_0/1 mode transparent ! Edited 2016-02-23 09:41:19 by FTTH_VN Link to post Share on other sites
serg_cl 3 Posted 2017-11-04 17:39:00 Share Posted 2017-11-04 17:39:00 Столкнулся с такой же проблемой ! Удалось ли отключить эту блокировку ? isolation disable не помогает, олт блокирует трафик не только между онушками одного дерева, но и при одинаковом vlan между ону соседних деревьев. Link to post Share on other sites
gudwin888 13 Posted 2017-11-04 20:28:42 Share Posted 2017-11-04 20:28:42 на стволе пропишите p2p mode full По умолчанию изоляция включена Link to post Share on other sites
serg_cl 3 Posted 2017-11-05 07:30:17 Share Posted 2017-11-05 07:30:17 Если необходимо, чтоб ону в одном vlan но на разных портах олта так же общались между собой, то это нужно указать на обоих портах верно ? Link to post Share on other sites
gudwin888 13 Posted 2017-11-05 16:01:37 Share Posted 2017-11-05 16:01:37 Да на обоих портах, отпишитесь потом помогло или нет, мне помогло, я долго искал в чем проблема Link to post Share on other sites
FTTH_VN 59 Posted 2017-11-05 20:13:02 Author Share Posted 2017-11-05 20:13:02 Да на обоих портах, отпишитесь потом помогло или нет, мне помогло, я долго искал в чем проблема Зачем разрешать все абонам на двух портах ? Группу создать и кинут в нее 2 ону. Link to post Share on other sites
Kiano 619 Posted 2017-11-05 20:41:41 Share Posted 2017-11-05 20:41:41 Да на обоих портах, отпишитесь потом помогло или нет, мне помогло, я долго искал в чем проблема Зачем разрешать все абонам на двух портах ? Группу создать и кинут в нее 2 ону. и группе уже разрешить? Link to post Share on other sites
serg_cl 3 Posted 2017-11-06 08:06:53 Share Posted 2017-11-06 08:06:53 А разве можно сделать группу в которой будут онушки с разных портов ? Link to post Share on other sites
serg_cl 3 Posted 2017-11-06 19:39:18 Share Posted 2017-11-06 19:39:18 Да на обоих портах, отпишитесь потом помогло или нет, мне помогло, я долго искал в чем проблема К сожалению, мне не помогло, пустил через шлюз, между онушками в одном влане на разных портах олта трафик не проходил по L2, p2p mode full указал на обоих портах. Link to post Share on other sites
Shuher 216 Posted 2018-04-02 16:32:19 Share Posted 2018-04-02 16:32:19 Нужно прогнать трафик между epon и gpon онушкой. Кто-то разобрался как это сделать? Команда p2p mode full на гпон порту не выполняеться Link to post Share on other sites
router_mx 4 Posted 2018-12-31 13:32:16 Share Posted 2018-12-31 13:32:16 В 06.11.2017 в 21:39, serg_cl сказал: К сожалению, мне не помогло, пустил через шлюз, между онушками в одном влане на разных портах олта трафик не проходил по L2, p2p mode full указал на обоих портах. таже проблема, один влан, разные порты олта, L2 трафик не проходит. Как можно решить? Link to post Share on other sites
router_mx 4 Posted 2019-02-27 08:51:58 Share Posted 2019-02-27 08:51:58 Configuring ARP Proxy This section describes how to configure ARP proxy to implement interworking between subscribers under the same PON port. By default, the ZXA10 C320 services on different ONUs under the same PON port are isolated. When a service, such as VoIP, requires interworking between the subscribers under the same PON port, the ZXA10 C320 uses the ARP proxy function to achieve interworking between the subscribers in the same VLAN and same network segment under the same PON port. Steps 1. In layer-3 VLAN interface mode, configure the layer-3 interface IP address. ZXAN(config)#interface vlan 100 ZXAN(config-if)#ip address 10.1.1.1 255.255.255.0 Note: The VLAN is the user VLAN. The IP address should be in the same network segment as that of the interworking device. 2. Enable ARP proxy on the layer-3 interface. ZXAN(config-if)#ip proxy-arp ZXAN(config-if)#exit – End of Steps – Link to post Share on other sites
lp_nik 0 Posted 2021-04-05 11:53:02 Share Posted 2021-04-05 11:53:02 (edited) В 27.02.2019 в 11:51, router_mx сказал: Configuring ARP Proxy This section describes how to configure ARP proxy to implement interworking between subscribers under the same PON port. By default, the ZXA10 C320 services on different ONUs under the same PON port are isolated. When a service, such as VoIP, requires interworking between the subscribers under the same PON port, the ZXA10 C320 uses the ARP proxy function to achieve interworking between the subscribers in the same VLAN and same network segment under the same PON port. Steps 1. In layer-3 VLAN interface mode, configure the layer-3 interface IP address. ZXAN(config)#interface vlan 100 ZXAN(config-if)#ip address 10.1.1.1 255.255.255.0 Note: The VLAN is the user VLAN. The IP address should be in the same network segment as that of the interworking device. 2. Enable ARP proxy on the layer-3 interface. ZXAN(config-if)#ip proxy-arp ZXAN(config-if)#exit – End of Steps – Кому то помогло ? Edited 2021-04-05 11:53:22 by lp_nik Link to post Share on other sites
router_mx 4 Posted 2021-04-17 18:47:32 Share Posted 2021-04-17 18:47:32 В 05.04.2021 в 14:53, lp_nik сказал: Кому то помогло ? Да, и не один раз) Link to post Share on other sites
vitukr 0 Posted 2021-11-05 20:03:35 Share Posted 2021-11-05 20:03:35 есть ли у кого реальный опыт L2 сети в одном дереве с разными ону? настроил всё как выше, если прописать IP статически , пинг ходит, но по DHCP ip не получает. так же смущает глобальная настройка разрешения трафика между ону (она реально применяется на все вланы и деревья) Link to post Share on other sites
