OLT BDCOM + DHCP-Relay + Option82 / Switch Dlink + DHCP-Relay + Option82
BERSERK
Собственно сам функцинал на OLT работает и более чем устраивает.
Планируется две схемы использования ONU:
- одна ONU на одного клиента
- ONU на дом и за ней управляемый свич
Первый вариант настроен и работает.
Второй работает только тогда, когда выключен snooping на OLT.
Информация об OLT:
BDCOM(tm) P3310B Software, Version 10.1.0B Build 33463
Copyright by Shanghai Baud Data Communication CO. LTD.
Compiled: 2016-2-24 18:9:56 by SYS_33463, Image text-base: 0x80008000
ROM: System Bootstrap, Version 0.3.8, Serial num:00313005120
System image file is "Switch.bin"
(RISC) processor with 131072K bytes of memory, 8192K bytes of flash
Base ethernet MAC Address: fc:fa:f7:c9:f2:7c
snmp info:
  product_ID:228   system_ID:1.3.6.1.4.1.3320.1.228.0
Switch uptime is 0:05:26:53, The current time: 1970-1-1 5:26:53
Конфигурация:
!version 10.1.0B build 33463
service timestamps log date
service timestamps debug date
ip default-gateway 192.168.10.1
spanning-tree mode rstp
epon dba hardware cycletime 25000 discovery-frequence 60 discovery-length 1024
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
username admin password 0 admin
epon onu-config-template All-ONU
 cmd-sequence 1 no epon onu port-protect
 cmd-sequence 2 epon onu all-port ctc vlan mode tag 3010
 cmd-sequence 3 epon onu all-port ctc loopback detect
 cmd-sequence 4 epon onu all-port ctc notify loopback
!!slot 0 84
interface GigaEthernet0/6
 switchport trunk vlan-allowed 3010-3011,3020
 switchport mode trunk
  dhcp snooping trust
interface EPON0/1
interface EPON0/2
interface EPON0/3
interface EPON0/4
 epon pre-config-template All-ONU binded-onu-llid 1-64
 epon bind-onu mac fcfa.f7c5.1111 1
 epon bind-onu mac fcfa.f7c5.2222 2
 switchport trunk vlan-untagged none
interface EPON0/4:1
 onu-configuration
  epon onu port 1 ctc vlan mode tag 3010
  epon onu port 1 ctc loopback detect
  epon onu port 1 ctc notify loopback
!!onu-configuration-end
interface EPON0/4:2
 onu-configuration
!!slot end
interface VLAN3020
 ip address 192.168.10.10 255.255.255.0
vlan 3010
 name Users
vlan 3011
 name Switches
vlan 3020
 name Skyline-mng
vlan 1-2,3010-3011,3020
ip dhcp-relay snooping
ip dhcp-relay snooping vlan  3010
ip dhcp-relay snooping information option format hn-type
ip dhcp-relay agent
ip dhcp-relay helper-address 192.168.1.1 vlan 3010
ip dhcp-relay snooping log
ip http server
!Pending configurations for absent linecards:
!No configurations pending global
Приведенный вариант конфига - пследний. Т.е. ONU  в  разных vlan id.
До этого пробовали в онушки в одном влане (3010).
Сейчас вторая онушка в решиме trasparent, так же пробовали trunk
Симптомы те же - если на OLT включен snooping - на свиче Relay не работает
Есть ли решение данной проблемы и какое?
Відредаговано BERSERK
всеж, мабуть
interface EPON0/4:2
onu-configuration
epon onu port 1 ctc vlan mode tag 3011
epon onu port
epon onu port
Маю схожу ситуацію - працює .
Відредаговано PBNM
    • Від WhoSoSerious
      Треба допомога в закритому тестуванні безкоштовного додатку для монтажників та проєктувальників PON мережі, що треба, долучитись до спільноти Google groups, скачати застосунок в PlayMarket
      1. https://groups.google.com/g/testers_pon_app
      2.https://play.google.com/store/apps/details?id=com.goodzone.pondesigner
      Дякую...
    • Від BatoSan
      Могу выполнять работы в Черкассах и области, 3-4 дня в неделю.
      Есть часть необходимого строительно монтажного инструмента, а также свой сварочный аппарат.
      Предложения в личку.
    • Від Rakim
      Продам кабель оптичний RCI S-CFP(NA)Fda-001 E9/125 - 1 волокно, на підвіс, діелектрик. Новий, в бухтах по 2км. Ціна - 4грн/м. Можливий продаж від ФОП.
    • Від Rakim
      Продам оптичні бокси Crosver FOB-04-16. Нові. Ціна - 400грн/шт. Можливий продаж від ФОП.
      Продам оптичні бокси Crosver FOB-05-24АH. Нові. Ціна - 450грн/шт. Можливий продаж від ФОП.
    • Від Rakim
      Продам затискач натяжний анкерний H3-SN (нові). Ціна - 9грн/шт. Можливий продаж від ФОП.
      Продам затискач натяжний анкерний H3D (нові). Ціна - 12грн/шт. Можливий продаж від ФОП.
