Перегружается OLT при подключении нового абонента.
При этом наблюдается shutdown аплинк порта:
Apr 26 13:33:56 10.0.19.42  000342: sw1.prm45 %Apr 26 14:33:54 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to DOWN
Apr 26 13:34:13 10.0.19.42  000343: sw1.prm45 %Apr 26 14:34:12 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to UP
Apr 26 13:39:08 10.0.19.42  000349: sw1.prm45 %Apr 26 14:39:07 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to DOWN
Apr 26 13:39:25 10.0.19.42  000350: sw1.prm45 %Apr 26 14:39:25 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to UP
И возможно (визуально не подтверждаю) ребут OLT:
Apr 26 14:29:40 olt1.prm45 %EPON-ONUREG: ONU 8479.7323.0437 is registered on EPON0/1:9.
Jan  1 00:00:40 olt1.prm45 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error
Apr 26 14:31:22 olt1.prm45 %EPON-ONUREG: ONU 8479.7323.0437 is registered on EPON0/1:9.
Jan  1 00:00:40 olt1.prm45 %OLT: Interface EPON0/1:9's CTC OAM extension negotiated successfully!
Apr 26 14:32:59 olt1.prm45 %OLT: Interface EPON0/1:9's OAM Operational Status: Operational
Jan  1 00:00:38 olt1.prm45 %239.0.10.1 add error, insufficient multicast VLAN xlate table space.
Apr 26 14:34:36 olt1.prm45 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error
Apr 26 14:38:11 olt1.prm45 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error
Jan  1 00:00:41 olt1.prm45 %EPON-ONUAUTHEN: ONU 8479.7323.0375 is authenticated on EPON0/1:8.
Apr 26 14:39:52 olt1.prm45 User motivprm logged in from 192.168.156.100 on vty 1
Подозреваю, так как сбивается дата.
Так же криво накатываются шаблоны:
interface EPON0/2:3
epon onu port 1 ctc vlan mode tag 1600
epon onu port 1 loopback detect
interface EPON0/2:4
description morsk_63
Основной конфиг во вл.
sw 33463
ONU исключительно P1501C1 и P1004C1
conf.txt
Edited by loschikatilos
Проблема была в накатывании конфига от 4х портовой ONU на 1 портовую.
Из за этого перегружалась OLT.
Доберусь до офиса скину лог.
Вот что в итоге словил:
Apr 26 16:21:09 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/2
Apr 26 16:21:09 timestamp 0, window 0, threshold 0, value 0
Apr 26 16:21:09 %LINE-5-UPDOWN: Line on Interface EPON0/2, changed state to up
Apr 26 16:21:09 %LINEPROTO-5-UPDOWN: Line protocol on Interface EPON0/2, changed state to up
Apr 26 16:21:09 %EPON-ONUREG: ONU fcfa.f718.f26d is registered on EPON0/2:1.
Apr 26 16:21:09 %EPON-ONUREG: ONU fcfa.f718.f86a is registered on EPON0/2:3.
Apr 26 16:21:09 %EPON-ONUREG: ONU 8479.7323.0321 is registered on EPON0/2:4.
Apr 26 16:21:09 %EPON-ONUAUTHEN: ONU fcfa.f718.f26d is authenticated on EPON0/2:1.
Apr 26 16:21:09 %EPON-ONUAUTHEN: ONU fcfa.f718.f86a is authenticated on EPON0/2:3.
Apr 26 16:21:09 %EPON-ONUAUTHEN: ONU 8479.7323.0321 is authenticated on EPON0/2:4.
Apr 26 16:21:09 %OLT: Interface EPON0/2:3's OAM Operational Status: Operational
Apr 26 16:21:09 %OLT: Interface EPON0/2:1's OAM Operational Status: Operational
Apr 26 16:21:09 %OLT: Interface EPON0/2:4's OAM Operational Status: Operational
Apr 26 16:21:10 %OLT: Interface EPON0/2:3's CTC OAM extension negotiated successfully!
Apr 26 16:21:10 %OLT: Interface EPON0/2:1's CTC OAM extension negotiated successfully!
Apr 26 16:21:10 %OLT: Interface EPON0/2:4's CTC OAM extension negotiated successfully!
Apr 26 16:21:11 %EPON-ONUREG: ONU fcfa.f718.f951 is registered on EPON0/2:2.
Apr 26 16:21:14 %OLT: Interface EPON0/2:2's OAM Operational Status: Operational
Apr 26 16:21:14 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error
Apr 26 16:21:14 ONU-4-PRECFG: CMD "epon onu port 2 ctc vlan mode tag 720" parse failed, maybe spell error, please check preconfig template T-TV cmd-sequence 2
Apr 26 16:21:14 %OLT: Config ONU on interface EPON0/2:4 failed for 1 times, must deregister it!
Apr 26 16:21:14 %EPON-ONUAUTHEN: ONU fcfa.f718.f951 is authenticated on EPON0/2:2.
Apr 26 16:21:14 %EPON-ONUDEREG: ONU 8479.7323.0321 is deregistered on EPON0/2:4.
Apr 26 16:21:15 %OLT: Interface EPON0/2:2's CTC OAM extension negotiated successfully!
Apr 26 16:21:16 %EPON-ONUREG: ONU 8479.7323.0321 is registered on EPON0/2:4.
Apr 26 16:21:16 %OLT: Interface EPON0/2:4's OAM Operational Status: Operational
Apr 26 16:21:16 %EPON-ONUAUTHEN: ONU 8479.7323.0321 is authenticated on EPON0/2:4.
Apr 26 16:21:17 %OLT: Interface EPON0/2:4's CTC OAM extension negotiated successfully!
Apr 26 16:21:17 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error
Apr 26 16:21:17 ONU-4-PRECFG: CMD "epon onu port 2 ctc vlan mode tag 720" parse failed, maybe spell error, please check preconfig template T-TV cmd-sequence 2
Apr 26 16:21:17 %OLT: Config ONU on interface EPON0/2:4 failed for 2 times, must deregister it!
Apr 26 16:21:17 %EPON-ONUDEREG: ONU 8479.7323.0321 is deregistered on EPON0/2:4.
Apr 26 16:21:19 %EPON-ONUREG: ONU 8479.7323.0321 is registered on EPON0/2:4.
Apr 26 16:21:19 %EPON-ONUAUTHEN: ONU 8479.7323.0321 is authenticated on EPON0/2:4.
Apr 26 16:21:19 %OLT: Interface EPON0/2:4's OAM Operational Status: Operational
Apr 26 16:21:19 %OLT: Interface EPON0/2:4's CTC OAM extension negotiated successfully!
Apr 26 16:21:20 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error
Apr 26 16:21:20 ONU-4-PRECFG: CMD "epon onu port 2 ctc vlan mode tag 720" parse failed, maybe spell error, please check preconfig template T-TV cmd-sequence 2
Apr 26 16:21:20 %OLT: Config ONU on interface EPON0/2:4 failed for 3 times, must reboot it!
Apr 26 16:21:22 %EPON-ONUDEREG: ONU 8479.7323.0321 is deregistered on EPON0/2:4.
Apr 26 16:21:23 %EPON-ONUREG: ONU 8479.7323.0321 is registered on EPON0/2:4.
Apr 26 16:21:23 %EPON-ONUAUTHEN: ONU 8479.7323.0321 is authenticated on EPON0/2:4.
Apr 26 16:21:23 %OLT: Interface EPON0/2:4's OAM Operational Status: Operational
Apr 26 16:21:23 %OLT: Interface EPON0/2:4's CTC OAM extension negotiated successfully!
BreakNum: 94, Offset: 0xa7ffe200
Exception Type:2-TLB miss exception (load or instruction fetch)
TaskID=8405bcd0, TaskName=OLT
zero                    at                      v0                      v1
00000000                81010064                00000000                86e5ab4c
a0                      a1                      a2                      a3
83a607d0                00000001                00000000                83a690fc
t0                      t1                      t2                      t3
83a607ec                1000fc00                00000000                00000000
t4                      t5                      t6                      t7
00000000                00000023                0506693f                00000000
s0                      s1                      s2                      s3
0000002c                83a690e0                83a607d0                00000001
s4                      s5                      s6                      s7
0000005c                8405ac2c                00000003                00000001
t8                      t9                      k0                      k1
00000002                8405bcd0                80490b78                00000000
gp                      sp                      s8                      ra
81502ed0                84059e70                862b0c28                804cf79c
pc
804cf794
Как обойти баг или как его избежать?
От себя решили накатывать на все ONU конфиг с 1 рабочим портом, а при наличии 4х пртовых ONU настраивать руками.
Но о5 же в случае замены ONU либо ошибочного подключения 1 портовой словим постоянный ребут устройства.
Может есть возможность применять шаблоны в зависимости от модели ONU?
Какой то монолог получается )))
проблема передана в R&D
У меня как то так получается...
epon onu-config-template T2
 cmd-sequence 1 epon onu all-port ctc vlan mode tag 472
 cmd-sequence 2 epon onu all-port loopback detect
 cmd-sequence 3 switchport port-security mode dynamic
 cmd-sequence 4 switchport port-security dynamic maximum 5
 cmd-sequence 5 exit
 cmd-sequence 6 exit
 cmd-sequence 7 write
 cmd-sequence 8 write ifindex
И пофик сколько портов в ОНУшке.
 cmd-sequence 5 exit
 cmd-sequence 6 exit
у меня несколько услуг:
interface EPON0/1:4
 onu-configuration
 description Orehovaya_85
  epon onu port 1 ctc vlan mode tag 1501
  epon onu port 3 ctc vlan mode tag 333
  epon onu port 2 loopback detect
  epon onu port 3 loopback detect
  epon onu port 4 loopback detect
  epon onu port 3 ctc mcst tag-stripe enable
  epon onu port 3 ctc mcst mc-vlan add 666
!!onu-configuration-end
    • By sergeyko
    • By tadesky
      Вітаю,
      Маємо в наявності б/в OLT:
      BDCOM  P3310 С-2АС - 1 шт. = 8000 грн
      BDCOM  P3310 С - 1 шт. = 8000 грн
      BDCOM P3616-2 TE - 3 шт. = 38000 грн
      Всі OLT з запасними БЖ 220V (купляли на всяк випадок). Працювали весь час у серверних, робочі та без проблем.
      За потреби можемо укомплектувати модулями Picotel EPON SFP PX++ = 800 грн/шт.
      Питання та пропозиції прохання в особисті повідомлення.
      Дякую.
    • By Amigo
      Продам GEPON ОЛТи BDCOM
      1. BDCOM P3310B (Вживаний) - 6000 грн.
      2. BDCOM P3310C (Вживаний) - 7500 грн.
      3. BDCOM P3310C (Вживаний без вух) - 7000 грн.
      4. BDCOM P3608-2TE (Вживаний) - 20000 грн.
      5. BDCOM P3608-2TE  (Вживаний) - 19000 грн.
    • By Dimension
      Продам голову BDCOM P3310C абсолютно и полностью рабочий, не ремонтировался - 9000 грн
    • By ke1evra
      подскажите пожалуйста по config.db
      ресетнул (думал, что ресетнул) - удалил только startup-config, настроил по чистой, после установки начало рандомным онушкам раздавать то новый конфиг, то старый. я так понял, что олт берёт его из config.db.
      вот теперь вопрос - как удалённо пофиксить. если я удалю config.db не потеряю управление? там же вроде интерфейсы тоже есть...
      или как можно принудительно заставить выдавать указанный темплейт, потому что явно
      interface EPON0/1 epon pre-config-template abonent binded-onu-llid 1-64 не работает
