Shuher 216 Опубликовано: 2016-07-14 15:35:48 Share Опубликовано: 2016-07-14 15:35:48 Доброго дня! Решил переехать с BDCOM на ZTE Сборная солянка китайских ону в основном завелась. Не заработали вот такие ону BDCM 3022 (1501С) и FORA 101C ZXAN#show card Rack Shelf Slot CfgType RealType Port HardVer SoftVer Status ------------------------------------------------------------------------------- 1 1 1 GTGO GTGOG 8 120301 V1.2.5P2 INSERVICE 1 1 2 ETGO ETGOD 8 091201 V1.2.5P2 INSERVICE 1 1 3 SMXA SMXA 3 110702 V1.2.5P2 INSERVICE 1 1 4 SMXA SMXA 3 110702 V1.2.5P2 STANDBY ZXAN#show card slotno 2 Config-Type : ETGO Status : INSERVICE Real-Type : ETGOD Serial-Number : 279624700560 Port-Number : 8 BootROM-VER : V1.2.3 2012-06-14 15:43:41 PCB-VER : 091201 Software-VER : V1.2.5P2 2013-09-22 23:29:01 Cpld-VER : V1.5 Phy-Mem-Size : 256MB Main-CPU : PowerPC Processor Cpu-Usage : 8% Cpu-Alarm-Threshold : 100% Mem-Usage : 56% Mem-Alarm-Threshold : 100% Uptime : 0 Day , 1 Hours , 5 Minutes , 0 Second ZXAN#show card slotno 3 Config-Type : SMXA Status : INSERVICE Real-Type : SMXA Serial-Number : 278266500730 Port-Number : 3 BootROM-VER : V4.0.0 2013-12-18 14:28:28 PCB-VER : 110702 Software-VER : V1.2.5P2 2013-09-23 07:34:16 Cpld-VER : V1.8 Phy-Mem-Size : 1024MB Main-CPU : PowerPC Processor Cpu-Usage : 1% Cpu-Alarm-Threshold : 100% Mem-Usage : 29% Mem-Alarm-Threshold : 100% Uptime : 0 Day , 1 Hours , 10 Minutes , 6 Second Subcard 1 : Config-Type : UCDC/1 Real-Type : UCDC/1 Status : INSERVICE Port-Nummber : 3 В логах пишет вот такое: An alarm 43265 level cleared occurred at 18:09:01 07/14/2016 utc sent by MCP Epon alarm OnuPowerOff: shelf 1 slot 2 olt 8 onu 3 level 5 on An alarm 43061 level notifications occurred at 18:01:11 07/14/2016 utc sent by MCP Epon inform OnuDyingGasp: shelf 1 slot 2 olt 8 onu 3 level 6 on An alarm 43265 level critical occurred at 18:01:11 07/14/2016 utc sent by MCP Epon alarm OnuPowerOff: shelf 1 slot 2 olt 8 onu 3 level 0 Онушки отваливаются/регятся, сигналы около - 23 дб, маков за ону не появляется. Что подскажете? Спасибо! Ссылка на сообщение Поделиться на других сайтах
BARVIT 113 Опубліковано: 2016-07-14 19:47:52 Share Опубліковано: 2016-07-14 19:47:52 Хм... интересно, тоже есть 320, лежит пара фор, но не пробовал что там и как, говорили что наоборот в зте работают а в бдкоме тоже работают но не видно сигналов с олт, хотя затачивалось именно под бдком. На данный момент есть проблема с 320 это рандомно перегружается карта епон. От чего пока не известно. Ссылка на сообщение Поделиться на других сайтах
foxmaster 2 Опубліковано: 2016-07-15 08:19:16 Share Опубліковано: 2016-07-15 08:19:16 а какие заработали нормально поделитесь опытом плз. Ссылка на сообщение Поделиться на других сайтах
Avad0n 23 Опубліковано: 2016-07-15 08:31:54 Share Опубліковано: 2016-07-15 08:31:54 (відредаговано) а какие заработали нормально поделитесь опытом плз. EPON на zte относительно не прихотлив, проверялось с бдком, фора, нгпон, пикоком, тплинк, etc. Тут лучше всего лично проверять, иногда могут приехать ону другой ревизии или с проблемным софтом, которые по всякому себя могут вести. Заказывать по одной штуке предлагающихся ону, проверять и делать заказ поболее, будучи более менее увереным что железка вас устраивает. По проблеме Shuher-a , была анлогичная ситуация , решилось тем что перед переключением деревьев, обновили софт на ону (насколько помню были проблемы с bd-com 1501). После чего всё заработало. Відредаговано 2016-07-15 08:35:35 Avad0n Ссылка на сообщение Поделиться на других сайтах
Shuher 216 Опубліковано: 2016-07-15 09:12:02 Автор Share Опубліковано: 2016-07-15 09:12:02 Обновил 1501с , все полетело Всем спасибо! Ссылка на сообщение Поделиться на других сайтах
