Продам RAID контроллер Supermicro AOC-LPZCR2
Б\у - полностью рабочий. 1200 грн. Торг уместен
Продается по ненужности
Key Features line_yellow.gifDimensions
  • 2.5" x 6.6 " (W x H)
Processor
  • Intel 80321 600MHz I/O Processor
RAID Levels
  • 0, 1, 5, 10
  • 50 (SAS and SATA modes)
Cache Memory
  • 256 MB onboard ECC DDR MEmory
Bus Type
  • 64-bit / 100MHz PCI-X
Key RAID Features
  • RAID detection, buildup, delete, error detection
  • Disk initialization and verification
  • Hot-spare disk drive support for easy replacement
  • Hot-spare disk support with automatic rebuild
  • Monitors the functionality of LED and alarm for attached disk drives
  • Indicates disk drive failure with audible alarm and LED
  • Indicates disk drive rebuild through LED
  • Eliminates human error such as removal of wrong disk drive(s)
  • Monitors temperature and system overheat
  Support / Advantages line_yellow.gifAdvantages
  • Supports SAS, SATA and SCSI modes (interchangeable via jumper settings)
  • Supports SAS SES2 Enclosure Management Software for SAS mode
  • Utilizes motherboard's existing SAS / SATA / SCSI I/O Channels.
  • Eliminates the need of a SAS / SATA / SCSI I/O chip on motherboard. Saves on cost of a regular RAID card.
  • Offers high-speed throughput, scalability and space-saving/cost-effective hardware RAID solution
Compatible Operating Systems
  • Microsoft Windows XP / 2000 / 2003
    For Windows 2003 Server, please install the driver from the CD instead of the default driver in Windows.
  • Linux SuSE 9.0 / 9.1 / 9.2, RedHat 3.0 / 4.0
Management Software
  • Storage Management (ASM)
  • Flash Utility (AFU)
  • Configuration Utility (ACU)
Есть еще:
1.3WARE AMCC 9550SXU-8LP SATA RAID контроллер 8 портов + BBU контроллер - 800 грн
2.3ware 9500S-4LP 4-port 128MB RAID Controller PCI/PCI-X - 300 грн
Низкопрофильный RAID-контроллер 3ware 9500S-4LP.
4 порта(с поддержкой Hot-swap и hot-spare), на борту кэш 128Мб ECC SDRAM(расширение до 1 Гб)
Возможна установка батареи резервного питания.
Поддерживаемые уровни RAID 0, 1, 10, 5, JBOD
Управление Поддержка рассылок оповещений по SMTP протоколу.
Масштабирование Возможна совместная работа до 4х плат в одной системе.
BIOS Есть
Память 1х SO-DIMM разъем для небуферизованных модулей памяти, с возможностью, 1х 128 Mб ECC SDRAM модуль в комплекте.
Интерфейс PCI 2.2 64 бита/66 МГц. Обратно совместима с обычным PCI.
Processor
RAID Levels
  • 0, 1, 5, 10
Cache Memory
Bus Type
Key RAID Features
Management Software
Здравствуйте !
Я могу взять его .
  • 4 months later...
  • 4 months later...
Processor
RAID Levels
  • 0, 1, 5, 10
Cache Memory
Bus Type
Key RAID Features
Management Software
Появилось пару штук лишних из-за замены серверов.
Посему - продаются.
Processor
RAID Levels
  • 0, 1, 5, 10
Cache Memory
Bus Type
Key RAID Features
Management Software
Посему - продаются.
Все еще продается
Processor
RAID Levels
  • 0, 1, 5, 10
Cache Memory
Bus Type
Key RAID Features
Management Software
Посему - продаются.
Все еще продаются. Торг уместен
    • Від ProstoName
      Куплю HP 72G SAS 2.5' 2шт з кошиками
    • Від Viper999
      Продам SAS/Sata контролери RAID масивів LSI 9361-8i, в наявності є кілька штук. Повністю справні.
      3000грн/шт
    • Від darell34
      Жёсткий диск для сервера Seagate Exos 10E300 SAS 2,5" 10000об/мин. 300Гб.
      Новый, не устанавливался. Доставался из упаковки для фото. В наличии 2шт.
      Цена за 1шт. 2000грн.
    • Від dos.ua
      Серверні диски SAS, протестовані (Victoria, HDD Sentinel) - без помилок SMART. Гарантія 3 міс.
      2500 грн (23 шт) Жорсткий диск 4TB SAS 3.5" 7200RPM 128MB Seagate Constellation ES.3 (ST4000NM0023) вживаний, 2016 рік
      1000 грн (10 шт) Жорсткий диск 2TB SAS 3.5" 7200RPM 64MB Toshiba MG (MG03SCA200) вживаний, 2013 рік
      Безготівка від ФОП.
    • Від mitnik
      Продам б/у диски для ПК/Сервера 3tb 4tb 3.5" SAS/SATA.  т. О73-162-87-41
      БУ Жесткий диск SAS 3Tb Seagate st33000650ss  в наявності 20шт  - 600грн
      БУ Жесткий диск SATA  4Tb Seagate st4000dm004 в наявності 3шт *пробіг до 1500г! - 1700грн
