atande 0 Опубликовано: 2017-02-03 15:35:08 Share Опубликовано: 2017-02-03 15:35:08 (відредаговано) После обновления до версии 33463, появилась странная проблема, часть вполне нормально работавших ону отказалась принимать теймплейт, а те кто принял имеют странный конфиг. #sh versionBDCOM P3616-2TE Software, Version 10.1.0E Build 33463Copyright by Shanghai Baud Data Communication CO. LTD.Compiled: 2016-2-24 18:6:58 by SYS, Image text-base: 0x10000ROM: System Bootstrap, Version 0.4.1, Serial num:S15070230System image file is "Switch.bin"hardware version:1.1.1(RISC) processor with 262144K bytes of memory, 16384K bytes of flashBase ethernet MAC Address: fc:fa:f7:44:3c:9bPCB version:1.1.1snmp info: interface EPON0/1:35 epon sla upstream pir 100000 cir 14000 epon sla downstream pir 100000 cir 14000 epon onu port 1 ctc mcst max-group-number 128 epon onu port 2 ctc mcst max-group-number 128 epon onu-config-template 123 cmd-sequence 1 epon onu all-port loopback detect cmd-sequence 2 epon onu all-port storm-control mode 1 threshold 256 cmd-sequence 3 epon sla upstream pir 100000 cir 14000 cmd-sequence 4 epon sla downstream pir 100000 cir 14000 ntfName VendorID ModelID MAC Address Description BindType Status Dereg Reason ---------- --------- -------- -------------- --------------- --------- --------------- -----------------EPON0/1:1 BDCM 1005 fcfa.f7d8.4bce N/A static auto-configured N/A EPON0/1:2 BDCM 151C fcfa.f7c5.3212 N/A static config-failed N/A EPON0/1:3 BDCM 1005 fcfa.f7d8.587a N/A static auto-configured N/A EPON0/1:4 BDCM 1005 fcfa.f7d8.4bc6 N/A static auto-configured N/A EPON0/1:5 BDCM 3022 fcfa.f7c5.7190 N/A static config-failed N/A EPON0/1:6 BDCM 151C fcfa.f7c5.3036 N/A static config-failed N/A EPON0/1:7 BDCM 151C fcfa.f7c5.320b N/A static config-failed N/A EPON0/1:8 BDCM 3022 fcfa.f7c5.7185 N/A static config-failed N/A EPON0/1:9 BDCM 3022 fcfa.f7c5.6e0d N/A static config-failed N/A EPON0/1:10 BDCM 3022 fcfa.f7c5.6e12 N/A static config-failed N/A EPON0/1:11 FG 104 001d.2bf8.f470 N/A static config-failed N/A и так все 16 портов..перепривязка онушек не дала результатов, только после добавление в шаблон записий exit и write онушки стали принимать шаблон, но при этом заметно выросла нагрузка ЦПУ у ОЛТ, долго происходит применение шаблона. Понятно что убрав exit & write в шаблоне, нагрузка упадет Мож кто сталкивался с подобным..откуда в конфигах ону настройки которых нет в шаблоне?? Відредаговано 2017-02-03 15:43:23 atande Ссылка на сообщение Поделиться на других сайтах
Dimkers 1 615 Опубліковано: 2017-02-03 15:48:54 Share Опубліковано: 2017-02-03 15:48:54 (відредаговано) atande В данных олтах есть еще файлы ifindex и config.db в них содержится инфо об онушках, что были привязаны к ОЛТу. оба снесите, перегрузите ОЛТ. И да, используйте не write, а write all. И покажите кусок конфига с темплейтом. Відредаговано 2017-02-03 15:53:05 Dimkers Ссылка на сообщение Поделиться на других сайтах
atande 0 Опубліковано: 2017-02-03 16:01:22 Автор Share Опубліковано: 2017-02-03 16:01:22 В 03.02.2017 в 15:48, Dimkers сказав: atande В данных олтах есть еще файлы ifindex и config.db в них содержится инфо об онушках, что были привязаны к ОЛТу. оба снесите, перегрузите ОЛТ. И да, используйте не write, а write all. И покажите кусок конфига с темплейтом. Сразу после обновления до перезагрузки снес эти два файла, сделал write all, ребут...и получил такую ситуацию, сейчас добавил еще и write all --шаблон сейчас имеет такой вид #show onu-config-template ONU config template 123 ,total cmd 6 ------------------------------------------- Index command content 1 epon onu all-port loopback detect 2 epon onu all-port storm-control mode 1 threshold 256 3 epon sla upstream pir 100000 cir 14000 4 epon sla downstream pir 100000 cir 14000 5 exit 6 write all Ссылка на сообщение Поделиться на других сайтах
Dimkers 1 615 Опубліковано: 2017-02-03 16:22:49 Share Опубліковано: 2017-02-03 16:22:49 (відредаговано) atande Все также? Есть левые конфиги в онушках? Разница с моим темплейтом и вашим в "ctc" epon onu all-port ctc loopback detect Прошивка таже BDCOM(tm) P3612-2TE Software, Version 10.1.0E Build 33463 Copyright by Shanghai Baud Data Communication CO. LTD. Compiled: 2016-2-24 18:6:58 by SYS, Image text-base: 0x10000 Гемор с регой онушек на ОЛТе был только с модулем ZTE C++, там онухи на кортине регались и до получаса. Но связано это было не с прошивкой а с СФП. Відредаговано 2017-02-03 16:24:06 Dimkers Ссылка на сообщение Поделиться на других сайтах
atande 0 Опубліковано: 2017-02-03 16:46:11 Автор Share Опубліковано: 2017-02-03 16:46:11 (відредаговано) В 03.02.2017 в 16:22, Dimkers сказав: atande Все также? Есть левые конфиги в онушках? Разница с моим темплейтом и вашим в "ctc" epon onu all-port ctc loopback detect Прошивка таже BDCOM(tm) P3612-2TE Software, Version 10.1.0E Build 33463 Copyright by Shanghai Baud Data Communication CO. LTD. Compiled: 2016-2-24 18:6:58 by SYS, Image text-base: 0x10000 Гемор с регой онушек на ОЛТе был только с модулем ZTE C++, там онухи на кортине регались и до получаса. Но связано это было не с прошивкой а с СФП. Нет сейчас после применения в шаблоне write all, регистрация пошла быстрее, и после регистрации загрузка цпу возвращается к 13-15%, возможно, как предположение это связано с зоопарком онушек на ОЛТ особенно FoxGate 104, да и других хватает show running-config int epon0/6:36 Building configuration... Current configuration: ! interface EPON0/6:36 epon onu port 1 loopback detect epon onu port 1 storm-control mode 1 threshold 256 epon sla upstream pir 100000 cir 14000 epon sla downstream pir 100000 cir 14000 Відредаговано 2017-02-03 16:47:31 atande Ссылка на сообщение Поделиться на других сайтах
