Авторизация админа
Сори за тупой вопрос но как то не могу сообразить. Установил stg-2.4-2007.01.20-13.47.20 установил патч mysql-0.66_stg-2.4-2007.01.20-13.47.20. Теперь у меня не пускает админа. :)
Ошибок вроде нет
Stg v. Stg 2.403b
2007-08-31 12:22:22 -- Message queue created successfully. msgKey=5555 msgID=32768
2007-08-31 12:22:22 -- Timer thread started successfully.
2007-08-31 12:22:22 -- Storage plugin: mysql_store v.0.66 (Alf). Loading successfull.
2007-08-31 12:22:22 -- Users started successfully.
2007-08-31 12:22:22 -- Traffcounter started successfully.
2007-08-31 12:22:22 -- Module: 'Ether_cap v.1.0'. Start successfull. 10
2007-08-31 12:22:22 -- Module: 'InetAccess authorizator v.1.1'. Start successfull. 50
2007-08-31 12:22:22 -- Module: 'Always Online authorizator v.1.0'. Start successfull. 70
2007-08-31 12:22:22 -- Module: 'Pinger v.1.01'. Start successfull. 100
2007-08-31 12:22:22 -- Stg started successfully.
2007-08-31 12:22:22 -- +++++++++++++++++++++++++++++++++++++++++++++
поставь последний модуль, -> логин admin пароль 123456
Поставил
2007-08-31 20:39:22 -- Stg v. Stg 2.403b
2007-08-31 20:39:22 -- Message queue created successfully. msgKey=5555 msgID=229376
2007-08-31 20:39:22 -- Timer thread started successfully.
2007-08-31 20:39:22 -- Storage plugin: mysql_store v.0.67 (Alf). Loading successfull.
2007-08-31 20:39:22 -- Users started successfully.
2007-08-31 20:39:22 -- Traffcounter started successfully.
2007-08-31 20:39:22 -- Module: 'Ether_cap v.1.0'. Start successfull. 10
2007-08-31 20:39:22 -- Module: 'InetAccess authorizator v.1.1'. Start successfull. 50
2007-08-31 20:39:22 -- Module: 'Always Online authorizator v.1.0'. Start successfull. 70
2007-08-31 20:39:22 -- Module: 'Pinger v.1.01'. Start successfull. 100
2007-08-31 20:39:22 -- Stg started successfully.
2007-08-31 20:39:22 -- +++++++++++++++++++++++++++++++++++++++++++++
Stargazer Configurator пишет на admin 123456 connect failed. В базе есть admin и его пароль, так же есть пользователь test 123456.
InetAccess тестера не пусает. Говорит IP не тот.
Таблице в базе
  actions
 admins
 messages
 stat
 tariffs
 users
 web_stg_admins
 web_stg_cards
 web_stg_config
 web_stg_config_ud
 web_stg_credits
 web_stg_dealers
 web_stg_dealers_history
 web_stg_errors
 web_stg_moneytransfer
 web_stg_users
если коннект фейлед, значит либо порт либо айпи на который коннектишься не верный. Гляди конфиг сервера СТГ (/etc/stargazer/stargazer.conf) и настройки конфигутратора.
Может я чего-то не втыкаю но должно быть так
2007-08-29 14:54:50 -- Stg v. Stg 2.403b
2007-08-29 14:54:50 -- Message queue created successfully. msgKey=5555 msgID=32768
2007-08-29 14:54:50 -- Timer thread started successfully.
2007-08-29 14:54:50 -- Storage plugin: mysql_store v.0.66 (Alf). Loading successfull.
2007-08-29 14:54:50 -- Users started successfully.
2007-08-29 14:54:50 -- Traffcounter started successfully.
2007-08-29 14:54:50 -- Module: 'Ether_cap v.1.0'. Start successfull. 10
2007-08-29 14:54:50 -- Module: 'InetAccess authorizator v.1.1'. Start successfull. 50
2007-08-29 14:54:50 -- Module: 'Always Online authorizator v.1.0'. Start successfull. 70
2007-08-29 14:54:50 -- Module: 'Pinger v.1.01'. Start successfull. 100
2007-08-29 14:54:50 -- Module: 'Stg configurator v.0.05'. Start successfull. 220
2007-08-29 14:54:50 -- Stg started successfully.
2007-08-29 14:54:50 -- +++++++++++++++++++++++++++++++++++++++++++++
Особеннобенно вот это
