Продам оборудование Polycom
        Продам Polycom:
  • ASSY-PWR-KIT 24V/2KV POE -  This item is 24V Power Supply for the Polycom CX500 & CX600 telephones  $25/шт.  в наличии 2 шт.
  • IP 7000 POE  " Equipped with built-in Power over Ethernet (PoE). An optional A/C power kit also available. 20 ft (6.1 m) microphone pickup, and even more with optional expansion microphones or multi-unit connectivity, reaching all corners of the room., Automatic Gain Control intelligently adjusts the microphone sensitivity based on where participants are seated in the conference room,  Features technology that resists interference from mobile phones and other wireless devices, delivering clear communications without distractions.Built-in 2.5 mm applications port allows you to connect the conference phone to a mobile phone for productive calls even where no network connection is available, or to a computer for calls using PC-based soft phone clients." http://www.polycom.com/content/dam/polycom/common/documents/data-sheets/soundstation-ip-7000-ds-enus.pdf  $535  1 шт.
 Продам Polycom:
    • By sys.and.networks
      Чистые. Не запароленные.
      Цена - 2499 грн/шт.
    • By Asterix_in
      Особенности:
    • By Oleksij
      Питання по живленню.
      Але це теоретично.
    • By yurii11
      пишите
    • By avdept
      Продам свіч, 24 порти, ПОЕ до 400вт комбіновано. Все працює, екран, віддалений доступ. Хочу 18000грн
