lemosh Опубликовано: October 14, 2017 at 20:49 Опубликовано: October 14, 2017 at 20:49 Задача банальна на Brocade FESX424 по BGP пришло 2 аплинка, по OSPF связаны между собой внутренние роутеры. BGP сессия подымается, пинги в мир с консоли ходят OSPF тоже подымается, правда маршрута с dst 0.0.0.0 никто не получает, все остальные локальные ус-ва видны в таблице маршрутизации и пингуются К Brocade FESX424 подключены Mikrotikи вот конфиг: Current configuration: ! ver 07.2.02kT3e3 ! ! ! ! vlan 91 by port untagged ethe 11 router-interface ve 91 ! vlan 92 by port untagged ethe 12 router-interface ve 92 ! vlan 99 by port tagged ethe 24 untagged ethe 1 ethe 3 router-interface ve 99 ! vlan 101 name adm_vlan by port tagged ethe 2 ethe 4 ethe 13 to 16 ethe 24 router-interface ve 1 ! ip route 192.168.***.0 255.255.255.0 192.168.***.1 ! ip router-id 10.117.***.1 username lemosh password ..... snmp-server community ..... ro clock timezone gmt GMT+02 no web-management hp-top-tools no web-management http router ospf area 0 ! interface ve 1 ip address 192.168.***.241 255.255.255.0 ! interface ve 91 ip access-group Incoming-From-Inside in ip address 195.2**.***.**0 255.255.255.240 ! interface ve 92 ip access-group Incoming-From-Inside in ip address 46.1**.***.*** 255.255.255.252 ! interface ve 99 ip address 10.117.***.1 255.255.255.0 ip ospf area 0 ip ospf md5-authentication key-id 1 key 1 $6\,-SGhn\ ! ! router bgp local-as 42146 neighbor 195.2**.***.*** remote-as 6703 neighbor 195.2**.***.*** description vega neighbor 195.2**.***.*** next-hop-self neighbor 195.2**.***.*** timers keep-alive 20 hold-time 60 neighbor 195.2**.***.*** soft-reconfiguration inbound neighbor 46.1**.***.*** remote-as 21219 neighbor 46.1**.***.*** description datagroup neighbor 46.1**.***.*** next-hop-self neighbor 46.1**.***.*** timers keep-alive 20 hold-time 60 neighbor 46.1**.***.*** soft-reconfiguration inbound ! ! ip access-list extended Incoming-From-Inside deny udp any any range netbios-ns netbios-ssn deny tcp any any range loc-srv netbios-ssn deny tcp any any eq microsoft-ds deny swipe any any deny mobile any any deny sun-nd any any deny pim any any deny icmp any any redirect deny ip 10.0.0.0 0.255.255.255 any deny ip 127.0.0.0 0.255.255.255 any deny ip 172.16.0.0 0.15.255.255 any deny ip 192.168.0.0 0.0.255.255 any permit ip any any ! ! ! ! ! ! ! end что могу пропустить?
lemosh Опубліковано: October 14, 2017 at 20:52 Автор Опубліковано: October 14, 2017 at 20:52 на микротике прописываю статик роут 0.0.0.0./0 шлюз 10.117.***.1.... т.е по идее весь трафик уходит на брокейд, а он дальше уже не пускает... А вообще по OSPF должен ли этот маршрут приходить автоматом или нет?
lemosh Опубліковано: October 15, 2017 at 11:08 Автор Опубліковано: October 15, 2017 at 11:08 Разобрался: нужно было добавить фильтры для анонсирования своей сети
Prihod Опубліковано: November 1, 2017 at 07:28 Опубліковано: November 1, 2017 at 07:28 Разобрался: нужно было добавить фильтры для анонсирования своей сети А какие фильтры добавляли?
lemosh Опубліковано: November 1, 2017 at 15:16 Автор Опубліковано: November 1, 2017 at 15:16 Разобрался: нужно было добавить фильтры для анонсирования своей сети А какие фильтры добавляли? Вот текущий рабочий конфиг: router bgp local-as ***** neighbor А.А.А.А remote-as 6703 neighbor А.А.А.А description vega neighbor А.А.А.А next-hop-self neighbor А.А.А.А timers keep-alive 20 hold-time 60 neighbor А.А.А.А soft-reconfiguration inbound neighbor В.В.В.В remote-as 21219 neighbor В.В.В.В description datagroup neighbor В.В.В.В next-hop-self neighbor В.В.В.В timers keep-alive 20 hold-time 60 neighbor В.В.В.В soft-reconfiguration inbound network С.С.С.0/24 neighbor А.А.А.А route-map in vega-in neighbor А.А.А.А route-map out vega-out neighbor В.В.В.В route-map in dg-in neighbor В.В.В.В route-map out dg-out ! route-map BRAS-out permit 100 match ip address prefix-list default route-map BRAS-out deny 200 ! route-map dg-in permit 100 match ip address prefix-list default set local-preference 50 route-map dg-in deny 200 ! route-map dg-out permit 100 match ip address prefix-list our-blocks set as-path prepend ***** route-map dg-out deny 200 ! route-map vega-in permit 100 match ip address prefix-list default route-map vega-in deny 200 ! route-map BRAS-in permit 100 match ip address prefix-list our-blocks route-map BRAS-in deny 200 ! route-map vega-out permit 100 match ip address prefix-list our-blocks route-map vega-out deny 200 !
