Продам OLT V-Solutoin 4 порта
В наличии 2 OLT EPON PITon V1600d4 4ports. Цена-520 дол.
Техническое описание
НаименованиеV1600D2
Шассистойка1U 19" standard box
1000M Uplink PortКол-во8
RJ45 port 4*10/100/1000M auto-negotiation
SFP (независимый)4*SFP or SFP+ slots (SFP+ is 10GE)
EPON portКол-во4
физический интерфейсSFP Slots
Connector Type1000BASE-PX20+
Max splitting ratio1*64
Порты управления 1*10/100BASE-T out-band port, 1*CONSOLE port
Спецификация PON PortTransmission Distance20KM
скорость EPON port Symmetrical 1.25Gbps
Длина волн TX 1490nm, RX 1310nm
Connector SC/PC
Fiber Type 9/125μm SMF
TX Power +2~+7dBm
Rx Sensitivity-27dBm
Насыщенность  оптической мощности-6dBm
Режим управления SNMP, Telnet and CLI
Функциия управления
Fan Group Detecting;
Port Status monitoring and configuration management;
Layer2 switch configuration such as VLAN, Trunk, RSTP, IGMP,  QOS, etc; EPON management function: DBA,ONU authorization, ACL, QOS, etc; Online ONU configuration and management;
Alarm management.
User management;
Layer2 Switch
Support port VLAN and protocol VLAN;
Support 4096 VLANs;
Support VLAN tag/Un-tag ,VLAN transparent transmission, QinQ;
Support IEEE802.3d trunk;
Support RSTP;
QOS based on port, VID, TOS and MAC address;
IGMP Snooping;
IEEE802.x flow control;
Port stability statistic and monitoring.
Layer 3 Route
1024 Host Routes;
512 Subnet Routes;
256 IP Multicast Groups;
EPON FunctionSupport port-based rate limitation and bandwidth control;
In compliant with IEEE802.3ah standard;
Up to 20KM transmission Distance;
Support data encryption, multi-cast, port VLAN, separation, RSTP, etc; Support Dynamic Bandwidth Allocation (DBA);
Support ONU auto-discovery/link detection/remote upgrade of software; Support VLAN division and user separation to avoid broadcast storm; Support various LLID configuration and single LLID configuration; Different user and different service could provide different QoS by means of different LLID channels;
Support power-off alarm function, easy for link problem detection;
Support broadcasting storm resistance function;
Support port isolation between different ports;
Support ACL and SNMP to configure data packet filter flexibly;
Specialized design for system breakdown prevention to maintain stable system;
Support dynamic distance calculation on EMS online;
Support RSTP, IGMP Proxy.
Размер(L*W*H) 442mm*200mm*43.6mm
Вес 4.2kg
Источник питания220VAC AC:90~264V, 47/63Hz
Потребляемая мощность 30W
Рабочая средаРабочая температура-10~+55℃
Температура хранения-40~+85℃
Относительная влажность5~90%(non-conditioning)
    • Від Інет.укр
      Продам huawei olt 5608t
      Комплект
      2x MCUD Control Card
      1x GPFD Service Board
      1x MPWD Power module
      16x GPON SFP C++
    • Від ikoko
      Продам OLTи BDCOM б.у.
    • Від sergeyko
    • Від Туйон
      У продажу OLT V-SOL V1600D, стан прекрасний, у заводскій коробці, без проблем, глюків та ремонтів, працював десь півроку, потім був встановлений 8-портовий.
      Нормальний веб-інтерфейс, коректно працював з усіма онушками. Була встановлена остання прошивка десь півроку назад.
      Зібраний гарно, є фото внутрішностей (один раз відкрив, думав може пилюка попала, але чистий, та і було цікаво глянути який він там).
      Детальні характеристики та опис почитайте ТУТ
      З головних плюсів у порівнянні з класикою BDCOM 3310 на мій погляд - порти 10Г та як мені здалося, трохі меньше жре електрики, веб інтерфейс кращій.
      Ціна 8000 грн (половина від ціни нового).
      Можлива продаж за USDT за домовленостю.
      Всі питання у особисті повідомлення.
    • Від x-net
      Продам вживаний EPON OLT C-Data (Stels) FD1208S-R2-DAP + DAC 1m + 8 EPON SFP, вуха та рідна коробка. Прошу 20 тис.
