р3608 разные ONU
Від Alina1989
Overview
The Focuscom FS3124BE is a next-generation XGSPON optical terminal access device designed for high-end home and enterprise FTTX deployments. Integrating the latest WiFi 7 (BE3600) technology, it provides symmetrical 10Gbps upstream and downstream fiber access, delivering a robust solution for ultra-bandwidth applications.
Key Features & High-Speed Connectivity
Next-Gen XGSPON Speed: Supports symmetrical transmission rates of 10Gbps (Upstream/Downstream) using XGSPON technology.
WiFi 7 Performance: Delivers up to 3600Mbps total air speed (688Mbps on 2.4GHz and 2882Mbps on 5GHz).
Versatile Wired Ports: Equipped with one 2.5GE port for high-speed wired devices and three Gigabit Ethernet (GE) ports for standard networking.
Advanced Wireless Tech: Features $2\times2$ MIMO and Multi-Link Operation (MLO) across 2.4G and 5G bands to ensure lower latency and higher reliability.
Powerful Signal: High-gain 5dBi antennas provide excellent penetration, capable of passing through reinforced concrete or brick walls.
Comprehensive Functionality
Voice over IP (VoIP): Includes one RJ11 port supporting G.711, G.729, and G.722 standards for crystal-clear voice services and fax modes.
USB 3.0 Integration: A built-in USB 3.0 port allows for fast local file sharing and storage expansion.
Enterprise-Grade Security: Supports WPA3-SAE, WPA2-PSK, and robust firewall features to keep your network secure.
Smart Management: Easy configuration and maintenance via Web UI, OMCI, TR069, and CLI (Telnet/SSH).
Technical Specifications
Від tadesky
Продам б/в BDCOM P3616-2TE OLT .
Повністю робочий, без нюансів, знятий після модерну. Комплектований резервним БЖ.
Оціночна вартість 40 тис. грн.
За потреби можна комплектувати SFP Picotel EPON SFP PX++ = 600 грн/шт.
Пишіть в особисті.
Від forella
Имеется такая ситуация.
топология: абонент---ону---bdcom p3310---cisco 4948--- далее 2 пути, 99% идут на линуксовый шлюз, оставшиеся(избранные, назовем их так) 1% на микротик по оттдельному vlan.
олт 13шт. каждая олт оттдельным портом на 4948 подключена. все аналогично работают как описано выше.
наблюдается вот такая ситуация на циско:
*Apr 20 03:17:28.873: %C4K_EBM-4-HOSTFLAPPING: Host 78:9A:18:C7:61:85 in vlan 321 is moving from port Gi1/11 to port Gi1/7 *Apr 20 03:17:32.289: %C4K_EBM-4-HOSTFLAPPING: Host C4:AD:34:02:A9:FA in vlan 321 is moving from port Gi1/5 to port Gi1/11 *Apr 20 03:17:33.489: %C4K_EBM-4-HOSTFLAPPING: Host C4:AD:34:02:A9:FA in vlan 321 is moving from port Gi1/11 to port Gi1/5 *Apr 20 03:17:34.273: %C4K_EBM-4-HOSTFLAPPING: Host 74:4D:28:4D:3D:88 in vlan 321 is moving from port Gi1/10 to port Gi1/11 *Apr 20 03:17:34.277: %C4K_EBM-4-HOSTFLAPPING: Host 74:4D:28:4D:3D:88 in vlan 321 is moving from port Gi1/11 to port Gi1/10 *Apr 20 03:17:43.769: %C4K_EBM-4-HOSTFLAPPING: Host 78:9A:18:C7:61:85 in vlan 321 is moving from port Gi1/7 to port Gi1/11 *Apr 20 03:17:43.973: %C4K_EBM-4-HOSTFLAPPING: Host 78:9A:18:C7:61:85 in vlan 321 is moving from port Gi1/11 to port Gi1/7 *Apr 20 03:17:47.289: %C4K_EBM-4-HOSTFLAPPING: Host C4:AD:34:02:A9:FA in vlan 321 is moving from port Gi1/5 to port Gi1/11 vlan 321 это те самые избранные, и по логам видно что связующее звено 11 порт, за ней олт. (порты 5,7,10 так же олт)
что было сделано:
на олт за 11 портом выключены абоненты имеющие отношение к влан 321 - флапы продолжились.
выключены пон порты по очереди и все сразу - флапы продолжились.
выключен порт 11 на циско - флапы прекратились.
включен порт, но удален влан 321 на циско - флапы прекратились.
собственно вопрос - это глюк прошивки олт, что при выключеных пон портах флапы продолжаются, либо не там ищу причину?
