Не стартует модуль xmlrpc
Тычччу лет не собирал старгейзер.
Надо перенести биллинг на новый сервер Ubuntu 20.04
Пробовал, как 408 так и 409 версию - не стартует модуль xmlrpc.
2021-06-07 17:43:15 -- ---------------------------------------------
2021-06-07 17:47:06 -- Stg v. 2.408
2021-06-07 17:47:06 -- Message queue created successfully. msgKey=5555 msgID=12
2021-06-07 17:47:06 -- Timer thread started successfully.
2021-06-07 17:47:06 -- Storage plugin: file_store v.1.04. Loading successfull.
2021-06-07 17:47:06 -- Error: Error loading plugin '/usr/lib/stg/mod_conf_rpc.so': '/usr/lib/stg/mod_conf_rpc.so: cannot open shared object file: No such file or directory'
2021-06-07 17:47:06 -- Traffcounter: Stop successfull.
2021-06-07 17:47:06 -- Users: Stop successfull.
2021-06-07 17:47:07 -- Queue removed successfully.
2021-06-07 17:47:08 -- StgTimer: Stop successfull.
2021-06-07 17:47:08 -- Stg stopped successfully.
2021-06-07 17:47:08 -- ---------------------------------------------
2021-06-07 18:24:44 -- Stg v. 2.409
2021-06-07 18:24:44 -- Message queue created successfully. msgKey=5555 msgID=13
2021-06-07 18:24:44 -- Timer thread started successfully.
2021-06-07 18:24:44 -- Storage plugin: file_store v.1.04. Loading successfull.
2021-06-07 18:24:45 -- Users started successfully.
2021-06-07 18:24:45 -- Traffcounter started successfully.
2021-06-07 18:24:45 -- Plugin file '/usr/lib/stg/mod_conf_rpc.so' is missing or inaccessible.
2021-06-07 18:24:45 -- Module 'Pinger v.1.01' started successfully.
2021-06-07 18:24:45 -- Module 'Stg Configurator v. 2.0' started successfully.
2021-06-07 18:24:45 -- Module 'Always Online authorizator v.1.0' started successfully.
2021-06-07 18:24:45 -- Module 'InetAccess authorization plugin v.1.4' started successfully.
2021-06-07 18:24:45 -- Module 'cap_ether v.1.2' started successfully.
2021-06-07 18:24:45 -- Stg started successfully.
2021-06-07 18:24:45 -- +++++++++++++++++++++++++++++++++++++++++++++
Вроде как собрался и установился старгейзер, установил отдельно модули sgconf и sgconf_xml
А, библиотеки то нету. (((
cat /usr/lib/stg/mod_conf_rpc.so
cat: /usr/lib/stg/mod_conf_rpc.so: No such file or directory
Что не так, дайте дельный совет.
Благодарю за помощь!!!
Подсунул вручную файлик и мею ошибку
2021-06-08 08:28:12 -- ---------------------------------------------
2021-06-08 08:28:12 -- Stg v. 2.409
2021-06-08 08:28:12 -- Message queue created successfully. msgKey=5555 msgID=14
2021-06-08 08:28:12 -- Timer thread started successfully.
2021-06-08 08:28:12 -- Storage plugin: file_store v.1.04. Loading successfull.
2021-06-08 08:28:12 -- Users started successfully.
2021-06-08 08:28:12 -- Traffcounter started successfully.
2021-06-08 08:28:12 -- Error loading plugin '/usr/lib/stg/mod_conf_rpc.so': 'libxmlrpc_server_abyss++.so.3: cannot open shared object file: No such file or directory'
2021-06-08 08:28:12 -- Module 'Pinger v.1.01' started successfully.
2021-06-08 08:28:12 -- Module 'Stg Configurator v. 2.0' started successfully.
2021-06-08 08:28:12 -- Module 'Always Online authorizator v.1.0' started successfully.
2021-06-08 08:28:12 -- Module 'InetAccess authorization plugin v.1.4' started successfully.
2021-06-08 08:28:12 -- Module 'cap_ether v.1.2' started successfully.
2021-06-08 08:28:12 -- Stg started successfully.
2021-06-08 08:28:12 -- +++++++++++++++++++++++++++++++++++++++++++++
Идеи кончились. )))
Ну так, для того чтобы собирался mod_conf_xmlrpc должны быть установлены необходимые библиотеки — xmlrpc-c. И не только для сборки но и для работы.
Естественно нет, или установил но не то :)
Надо -dev пакет для сборки. И собирать желательно там где оно будет запускаться, иначе может оказаться что собрано с одними версиями библиотек, а там где запускается — другие.
Відредаговано madf
  В 08.06.2021 в 08:37, Небесный сказав:
Что тут не так. (((
Expand
Вот:
Установил из исходников.
Expand
apt-get install libxmlrpc-c++8-dev
И вся проблема решена. )))
Отдельное спасибо madf'y и passer'y.
Відредаговано Небесный
    • Від camchatix
      Привіт!
    • Від ppv
      та
    • Від ppv
      Потрібно було витерти одну мережу, всі абоненти з неї були перенесені в іншу. Але світить що 6 IP зайняті, хоча вона повністю вільна.
      ID    Мережа/CID           RВсього IP        Використано IP ▾           Вільно IPСервіс
      6      172.16.70.0/23        506                    6                                       500
      Підкажіть як правильно це підчистити щоб видалити мережу.
    • Від ppv
      Проглянув FAQ і Ubilling Wiki. Зацікавило питання чи є в Ubilling якась реалізація reCAPTCHA, чи потрібно додавати руцями, (для прикладу для форми подачі заявок чи для кабінету користувача)?
    • Від ppv
      Доброго дня, не працює примусовий опит OLT. Якщо оновлювати дані для даного ОЛТ то все норм. Була версія білінгу 1.3.3, вчора оновив до 1.3.6 нічого не змінилось.
      Чи може я щось пропустив в оновленях що треба було доналаштувати? Підкажіть будь ласка, хочу знати на що звернути увагу.
      Через крон теж не згрібає сигнали, хоча бачу регламенти проходять. Олт BDCOM різного типу.
      До білінгу давно не дивився, незнаю точно коли проблема появилась.
