Продам A10 Networks Thunder 3030S TH3030
Від renegade310
Доброго дня.
Маємо коробку A10 3030s.
Прошивка:
64-bit Advanced Core OS (ACOS) version 4.1.4-GR1-P5, build 81 (Sep-08-2020,09:32) Booted from Hard Disk primary image Number of control CPUs is set to 1 aFleX version: 2.0.0 GUI primary image (default) version 4_1_4-GR1-P5-4_1_4-gr1-p5-38 GUI secondary image version 4_1_4-GR1-P5-4_1_4-gr1-p5-38 aXAPI version: 3.0 Cylance version: N/A Hard Disk primary image (default) version 4.1.4-GR1-P5, build 81 Hard Disk secondary image version 4.1.4-GR1-P5, build 81 Last configuration saved at Feb-9-2023, 18:37 Hardware: 8 CPUs(Stepping 9), Single 74G drive, Free storage is 34G Total System Memory 16350 Mbytes, Free Memory 7692 Mbytes Hardware Manufacturing Code: 175211 Current time is Feb-11-2023, 19:01 The system has been up 21 days, 1 hour, 9 minutes
І недавно сталася проблема що розвалився lag на ньому і в логах було таке:
Feb 09 2023 16:54:12 Notice [Router]:Interface(s) ethernet 9, removed from aggregator po2 Feb 09 2023 16:54:12 Notice [Router]:Interface(s) ethernet 10, removed from aggregator po2 Feb 09 2023 16:54:12 Notice [Router]:Interface(s) ethernet 11, removed from aggregator po1 Feb 09 2023 16:54:12 Notice [Router]:Interface(s) ethernet 12, removed from aggregator po1 Feb 09 2023 16:54:11 Error [Fail Safe]:Failed in thread LWP 6361 Feb 09 2023 16:54:11 Error [Fail Safe]:Failed in thread LWP 6338 Feb 09 2023 16:54:11 Error [Fail Safe]:Failed in thread LWP 6340 Feb 09 2023 16:54:11 Error [Fail Safe]:Failed in thread 0x6f09149 Feb 09 2023 16:54:11 Error [Fail Safe]:FailSafe timestamp 4704431868, last update time 409464572 Feb 09 2023 16:54:11 Error [Fail Safe]:FailSafe detected problem in ALB threads. Feb 09 2023 16:54:11 Warning [AXMON]:Detected problem in Health Monitor DataCPU1 (LWP 6216). (Last counter was -1772775275 at time 4704431868 bit 7). Feb 09 2023 16:54:11 Warning [AXMON]:Detected problem in Health Monitor DataCPU4 (LWP 6220). (Last counter was -1460486145 at time 4704431868 bit 6). Feb 09 2023 16:54:11 Warning [AXMON]:Detected problem in Health Monitor DataCPU0 (LWP 6215). (Last counter was -974207122 at time 4704431868 bit 5). Feb 09 2023 16:54:11 Warning [AXMON]:Detected problem in Health Monitor DataCPU3 (LWP 6219). (Last counter was 1747921038 at time 4704431868 bit 4). Feb 09 2023 16:54:11 Warning [AXMON]:Detected problem in Health Monitor DataCPU2 (LWP 6217). (Last counter was -1737089530 at time 4704431868 bit 3). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU1 (LWP 6216). (Last counter was -1772775275 at time 4704431789 bit 7). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU4 (LWP 6220). (Last counter was -1460486145 at time 4704431789 bit 6). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU0 (LWP 6215). (Last counter was -974207122 at time 4704431789 bit 5). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU3 (LWP 6219). (Last counter was 1747921038 at time 4704431789 bit 4). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU2 (LWP 6217). (Last counter was -1737089530 at time 4704431789 bit 3). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU1 (LWP 6216). (Last counter was -1772775275 at time 4704431713 bit 7). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU4 (LWP 6220). (Last counter was -1460486145 at time 4704431713 bit 6). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU0 (LWP 6215). (Last counter was -974207122 at time 4704431713 bit 5). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU3 (LWP 6219). (Last counter was 1747921038 at time 4704431712 bit 4). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU1 (LWP 6216). (Last counter was -1772775275 at time 4704431636 bit 7). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU4 (LWP 6220). (Last counter was -1460486145 at time 4704431636 bit 6). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU0 (LWP 6215). (Last counter was -974207122 at time 4704431636 bit 5). Feb 09 2023 16:54:10 Warning [AXMON]:Detected problem in Health Monitor DataCPU3 (LWP 6219). (Last counter was 1747921038 at time 4704431636 bit 4). Feb 09 2023 16:54:09 Warning [AXMON]:Detected problem in Health Monitor DataCPU1 (LWP 6216). (Last counter was -1772775275 at time 4704431556 bit 7). Feb 09 2023 16:54:09 Warning [AXMON]:Detected problem in Health Monitor DataCPU0 (LWP 6215). (Last counter was -974207122 at time 4704431556 bit 5). Feb 09 2023 16:54:09 Warning [AXMON]:Detected problem in Health Monitor DataCPU3 (LWP 6219). (Last counter was 1747921038 at time 4704431552 bit 4).
Проблема була тимчасова, буквально за хвилину лаг знову зібрався і все працює.
В чому може бути проблема?
Від LENS
Продается высокопроизводительный комплекс обработки трафика.
В использовании не был и стоял как резервный для защиты от сетевых аномалий. Состояние можно оценить по отсутствию пыли и ее следов.
Установлена прошивка, которая позволяет аппаратно выполнить CGNAT на скорости до 38Гбит.
Наилучшее соотношение цена - производительность.
Например, если покупать плату Juniper MS-MIC-16G, то ее производительность до 9 гбит, а цена 3500 у.е.
Соответственно, чтобы добиться аналогичной производительности на MS-MIC-16G, необходимо инвестиций более чем в два раза больше, чем выполнить эту задачу на этом A10 Thunder
При желании возможно сделать rollback на TPS версию и организовать защиту от сетевых аномалий на аппаратном уровне.
Устройство операторского класса, поддерживает мульти пользовательский режим с выделением ресурсов в суб аренду. Полностью аппаратное решение с высокой надежностью и Out of band управлением
Стоимость: 5600$
Контакт через ЛС
