OSPF, переваги, підкажіть будь ласка
Від fet4
Привет всем.
Кто-то может объяснить следующее поведение ospf
Есть 3 маршрутизатора с quagga на борту.
R1
interface vlan11 ip ospf area 0 ip ospf authentication null ip ospf network broadcast ! interface ppp-archer ip ospf area 1 ip ospf authentication null ip ospf network point-to-point ! router ospf ospf router-id 172.19.1.1 passive-interface default no passive-interface vlan11 no passive-interface ppp-archer redistribute connected
R2
interface vlan11 ip ospf area 0 ip ospf authentication null ip ospf network broadcast ! interface ppp-archer2 ip ospf area 1 ip ospf authentication null ip ospf network point-to-point ! router ospf ospf router-id 172.19.1.2 passive-interface default no passive-interface vlan11 no passive-interface ppp-archer2 redistribute connected
R3
interface l2tp-r1 ip ospf area 1 ip ospf authentication null ip ospf network point-to-point ! interface l2tp-r2 ip ospf area 1 ip ospf authentication null ip ospf network point-to-point ! route-map CONNECTED permit 10 match interface br-lan ! router ospf ospf router-id 192.168.1.1 passive-interface default no passive-interface l2tp-r1 no passive-interface l2tp-r2 redistribute connected route-map CONNECTED
Не пойму почему R1 и R2 видят маршруты друг к другу через R3.
Например
X.X.47.216/29 via ppp-archer2
X.X.150.200/29 via ppp-archer
Ожидалось что через vlan11 будут видны
R1# show ip route ospf Codes: K - kernel route, C - connected, S - static, R - RIP, O - OSPF, I - IS-IS, B - BGP, P - PIM, A - Babel, N - NHRP, > - selected route, * - FIB route O>* X.X.150.200/29 [110/20] via 172.19.3.2, ppp-archer, 00:15:02 O 172.19.0.0/24 [110/20] via 172.19.3.2, ppp-archer, 00:15:02 O 172.19.1.0/24 [110/10] is directly connected, vlan11, 00:17:40 O>* 172.19.3.1/32 [110/30] via 172.19.1.2, vlan11, 00:15:03 O 172.19.3.2/32 [110/10] is directly connected, ppp-archer, 00:17:40 O>* 172.19.3.6/32 [110/30] via 172.19.3.2, ppp-archer, 00:15:03 O>* 172.19.3.254/32 [110/20] via 172.19.3.2, ppp-archer, 00:15:13 O>* 192.168.1.0/24 [110/20] via 172.19.3.2, ppp-archer, 00:15:12 R2# show ip route ospf Codes: K - kernel route, C - connected, S - static, R - RIP, O - OSPF, I - IS-IS, B - BGP, P - PIM, A - Babel, N - NHRP, > - selected route, * - FIB route O>* X.X.47.216/29 [110/20] via 172.19.3.6, ppp-archer2, 00:09:49 O 172.19.0.0/24 [110/20] via 172.19.3.6, ppp-archer2, 00:09:49 O 172.19.1.0/24 [110/10] is directly connected, vlan11, 00:11:30 O>* 172.19.2.0/24 [110/20] via 172.19.3.6, ppp-archer2, 00:09:49 O>* 172.19.3.1/32 [110/20] via 172.19.3.6, ppp-archer2, 00:09:50 O>* 172.19.3.2/32 [110/30] via 172.19.3.6, ppp-archer2, 00:09:50 O 172.19.3.6/32 [110/10] is directly connected, ppp-archer2, 00:11:30 O>* 172.19.3.254/32 [110/30] via 172.19.1.1, vlan11, 00:10:00 O>* 192.168.1.0/24 [110/20] via 172.19.3.6, ppp-archer2, 00:09:49 R3# show ip route ospf Codes: K - kernel route, C - connected, S - static, R - RIP, O - OSPF, I - IS-IS, B - BGP, P - PIM, A - Babel, > - selected route, * - FIB route O>* X.X.150.200/29 [110/20] via 172.19.3.254, l2tp-r2, 00:15:48 O>* X.X.47.216/29 [110/20] via 172.19.3.1, l2tp-r1, 00:15:55 O>* 172.19.0.0/24 [110/20] via 172.19.3.1, l2tp-r1, 00:15:48 * via 172.19.3.254, l2tp-r2, 00:15:48 O>* 172.19.1.0/24 [110/20] via 172.19.3.1, l2tp-r1, 00:15:49 * via 172.19.3.254, l2tp-r2, 00:15:49 O>* 172.19.2.0/24 [110/20] via 172.19.3.1, l2tp-r1, 00:15:55 O 172.19.3.1/32 [110/10] is directly connected, l2tp-r1, 00:16:07 O>* 172.19.3.2/32 [110/20] via 172.19.3.1, l2tp-r1, 00:15:48 O>* 172.19.3.6/32 [110/20] via 172.19.3.254, l2tp-r2, 00:15:48 O 172.19.3.254/32 [110/10] is directly connected, l2tp-r2, 00:16:07
Від Mechanik
Есть ли у кого то на олт zte функционал bgp/ospf для резервирования pon сети ?
Как стабильность работы ?
как защита олт с белыми ip ?
Від lemosh
Привет всем!
Остановился на простом, листаю мануалы, понять не могу.
Есть L3 Brocade, есть несколько микротиков. Поднят OSPF, все между собой обмениваются маршрутами. Хочу зафильтровать на brodace прием маршрутов по OSPF.
Задача: в таблицу маршрутизации принимать маршруты только с desrtination принадлежащей подсети реальниками.
Пробовал так:
router ospf area 0 default-information-originate permit redistribute 1 all redistribution bgp redistribution static distribute-list 2 in ! access-list 1 permit any ! access-list 2 permit 5.6.7.0 0.0.0.255 access-list 2 deny any ! все маршруты по OSPF отваливаются и ничего в таблицу маршрутизации не попадает
PS подсеть с реальниками 5.6.7.0/24 взята для примера
Від RadioMarket
Продам L3-коммутатор DELL S4810
Б.У. в отличном состоянии
48 портов 10Gbe , 4 порта 40Gbe ,
BGP (v4) , RIP (v1/v2) , OSPF (v2/v3)
Цена 45 000 грн.
https://i.dell.com/sites/csdocuments/Shared-Content_data-Sheets_Documents/en/Dell_Networking_S4810_Spec_Sheet.pdf
Від Garik
Продам коммутаторы Cisco Catalyst WS-C3560E-48TD, L3, 48 портов Ethernet 10/100/1000 Мбит/сек, 2 X2 10G Ethernet uplinks
Документация: data_sheet_3560-E.pdf
$350
