Gang 5 Опубликовано: 2011-12-07 12:47:40 Share Опубликовано: 2011-12-07 12:47:40 Доброго времени суток ! Прошу помочь. Не поднимается BGP в свежесозданном VR Extreme x650-a Image : ExtremeXOS version 12.5.2.6 v1252b6 by release-manager configure vr VR-Default delete ports 1 create virtual-router "VR-WORLD" type vrf vr "VR-Default" configure vr VR-WORLD add protocol bgp enable vr "VR-WORLD" create vlan "ISP_backup" vr "VR-WORLD" configure vlan "ISP_backup" tag 1711 configure vlan "ISP_backup" add ports 1 tagged configure vlan "ISP_backup" ipaddress xx.xx.xx.54 255.255.255.252 enable ipforwarding vlan ISP_backup create bgp neighbor xx.xx.xx.53 remote-AS-number НННН enable bgp neighbor xx.xx.xx.53 configure bgp neighbor xx.xx.xx.53 send-community extended configure bgp neighbor xx.xx.xx.53 route-policy in bgp_ISP_world_in configure bgp neighbor xx.xx.xx.53 route-policy out bgp_ISP_world_out enable bgp neighbor xx.xx.xx.53 soft-in-reset В итоге : #sh bgp nei --cut-- Ee-- xx.xx.xx.53 YYYY 1 CONNECT 0 0 (0 ) 0:1:42:12 #sh "VR-WORLD" Virtual Router : VR-WORLD Type : Non-VPN VRF [b]Operational State : Down (Inactive Vlans)[/b] IPv4 Admin State : Enabled IPv6 Admin State : Enabled IPv4 Route Sharing : Disabled IPv6 Route Sharing : Disabled Parent VR : VR-Default Protocols Configured : -------------------------------------------------------------------- Protocol Process Configuration Protocol Name Name Module Name Instances -------------------------------------------------------------------- BGP bgp bgp-3 2 -------------------------------------------------------------------- VLANS : ISP_backup Virtual Router Totals : Total Protocols : 1 Max Protocols : 8 Total Ports : 0 Total Vlans : 1 Total IPv4 Vlans : 1 Total Ipv6 Vlans : 0 Active IPv4 Vlans : 0 Active Ipv6 Vlans : 0 Inactive IPv4 Vlans : 1 Inactive Ipv6 Vlans : 0 # ping vr "VR-WORLD" xx.xx.xx.53 Ping(ICMP) xx.xx.xx.53: 4 packets, 8 data bytes, interval 1 second(s). 16 bytes from xx.xx.xx.53: icmp_seq=0 ttl=64 time=9.077 ms 16 bytes from xx.xx.xx.53: icmp_seq=1 ttl=64 time=3.658 ms 16 bytes from xx.xx.xx.53: icmp_seq=2 ttl=64 time=3.774 ms 16 bytes from xx.xx.xx.53: icmp_seq=3 ttl=64 time=3.701 ms # sh vlan "ISP_backup" VLAN Interface with name ISP_backup created by user Admin State: Enabled Tagging: 802.1Q Tag 1711 Virtual router: VR-WORLD IPv4 Forwarding: Enabled Primary IP : xx.xx.xx.54/30 IPv6 Forwarding: Disabled IPv6: None STPD: None Protocol: Match all unfiltered protocols Loopback: Disabled NetLogin: Disabled QosProfile: None configured Egress Rate Limit Designated Port: None configured Flood Rate Limit QosProfile: None configured Ports: 1. (Number of active ports=1) Tag: *1(ISP) Flags: (*) Active, (!) Disabled, (g) Load Sharing port ( Port blocked on the vlan, (m) Mac-Based port (a) Egress traffic allowed for NetLogin (u) Egress traffic unallowed for NetLogin (t) Translate VLAN tag for Private-VLAN (s) Private-VLAN System Port, (L) Loopback port (e) Private-VLAN End Point Port (x) VMAN Tag Translated port (G) Multi-switch LAG Group port В "VR-Default" все конечно-же работает. Это живой бордер. Кто сталкивался, подскажите пожалуйста. UPDATE: Все удалил, сделал заново. Теперь показывает : # sh "VR-WORLD" Virtual Router : VR-WORLD Type : Non-VPN VRF Operational State : Up IPv4 Admin State : Enabled IPv6 Admin State : Enabled IPv4 Route Sharing : Disabled IPv6 Route Sharing : Disabled Parent VR : VR-Default Protocols Configured : -------------------------------------------------------------------- Protocol Process Configuration Protocol Name Name Module Name Instances -------------------------------------------------------------------- BGP bgp bgp-3 2 -------------------------------------------------------------------- VLANS : ISP_backup Virtual Router Totals : Total Protocols : 1 Max Protocols : 8 Total Ports : 0 Total Vlans : 1 Total IPv4 Vlans : 1 Total Ipv6 Vlans : 0 Active IPv4 Vlans : 1 Active Ipv6 Vlans : 0 Inactive IPv4 Vlans : 0 Inactive Ipv6 Vlans : 0 Но: * (vr VR-WORLD) x650 # create bgp neighbor xx.xx.xx.53 remote-AS-number YYYY Error! EBGP peer xx.xx.xx.53 not directly connected Хотя хост пингуется, все хорошо. Куда копать ? Ссылка на сообщение Поделиться на других сайтах
fenix-vt 81 Опубликовано: 2011-12-07 13:10:02 Share Опубликовано: 2011-12-07 13:10:02 что-то мне подсказывает, что нейбора тоже надо в соотв. ВРФе создавать. синтаксиса не знаю, почитайте в документации на свою ОС, но так как вы написали, похоже, что пытаетесь создать нейбора просто в глобальном ВРФе. Ссылка на сообщение Поделиться на других сайтах
Gang 5 Опубликовано: 2011-12-07 13:16:03 Автор Share Опубликовано: 2011-12-07 13:16:03 что-то мне подсказывает, что нейбора тоже надо в соотв. ВРФе создавать. синтаксиса не знаю, почитайте в документации на свою ОС, но так как вы написали, похоже, что пытаетесь создать нейбора просто в глобальном ВРФе. x650 # virtual-router VR-WORLD * (vr VR-WORLD) x650 # create bgp neighbor xx.xx.xx.53 remote-AS-number YYYY Error! EBGP peer xx.xx.xx.53 not directly connected Я зашел в конкретный ВРФ и создаю нейбора. В документации пусто именно на данную тему. Ссылка на сообщение Поделиться на других сайтах
fenix-vt 81 Опубликовано: 2011-12-07 13:56:17 Share Опубликовано: 2011-12-07 13:56:17 есть еще один момент: пинг может идти на нейбора, но он при этом пингуется не напрямую по влану, а через роутинг. проверьте наличие АРП-записи в соотв. ВРФе. Ссылка на сообщение Поделиться на других сайтах
Gang 5 Опубликовано: 2011-12-07 14:02:59 Автор Share Опубликовано: 2011-12-07 14:02:59 есть еще один момент: пинг может идти на нейбора, но он при этом пингуется не напрямую по влану, а через роутинг. проверьте наличие АРП-записи в соотв. ВРФе. Эти моменты проверил сразу : * x650 # sh iparp vr "VR-WORLD" VR Destination Mac Age Static VLAN VID Port VR-WORLD хх.хх.хх.53 84:18:88:e8:80:f7 10 NO ISP_backup 1711 1 Ссылка на сообщение Поделиться на других сайтах
Gang 5 Опубликовано: 2011-12-09 16:47:57 Автор Share Опубликовано: 2011-12-09 16:47:57 Тему можно закрывать. Спасибо огромное Александру из DTEL-IX ! In this release, VRFs support only static routes. VRFs do not support dynamic routing protocols. Вместо : create virtual-router "VR-WORLD" type vrf vr "VR-Default" Нужно просто : create virtual-router "VR-WORLD" Тогда все чудесно : # conf "VR-WORLD" add protocol "bgp" Please wait for a few seconds for Protocol bgp to start in Virtual Router VR-WORLD Ссылка на сообщение Поделиться на других сайтах
