Вопросы/Замечания/Пожелания к СТГ 2.4
Собственно, скачал скоимпилил, вроде скомпилилось, но вот что настораживает, при компиляции выдавало вот что:
Makeing stg_logger.lib
../Makefile.in:74: deps: No such file or directory
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD -DSTG_TIME -c stg_logger.cpp
Makeing crypto.lib
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD -DSTG_TIME -c ag_md5.c
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD -DSTG_TIME -c blowfish.cpp
Makeing common.lib
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD -DSTG_TIME -c debug.c
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD -DSTG_TIME -c stg_error.c
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD -DSTG_TIME -c common.cpp
ar rc libstg_common.a debug.o stg_error.o common.o
Makeing conffiles.lib
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD -DSTG_TIME -c conffiles.cpp
ar rc libconffiles.a conffiles.o
ranlib libconffiles.a
cp conffiles.h ../../include/
cp libconffiles.a ../../lib/
Makeing hostallow.lib
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD -DSTG_TIME -c hostallow.cpp
ar rc libhostallow.a hostallow.o
Makeing pinger.lib
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD -DSTG_TIME -c pinger.cpp
ar rc libstg_pinger.a pinger.o
ranlib libstg_pinger.a
cp pinger.h ../../include/
cp libstg_pinger.a ../../lib/
Makeing dotconfpp.lib
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD -DSTG_TIME -c dotconfpp.cpp
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD -DSTG_TIME -c mempool.cpp
ar rc libdotconfpp.a dotconfpp.o mempool.o
ranlib libdotconfpp.a
cp dotconfpp.h mempool.h ../../include/
cp libdotconfpp.a ../../lib/
Makefile:94: deps: No such file or directory
/usr/lib/libc.so: WARNING! setkey(3) not present in the system!
/usr/lib/libc.so: warning: this program uses gets(), which is unsafe.
/usr/lib/libc.so: warning: mktemp() possibly used unsafely; consider using mkstemp()
/usr/lib/libc.so: WARNING! des_setkey(3) not present in the system!
/usr/lib/libc.so: WARNING! encrypt(3) not present in the system!
/usr/lib/libc.so: warning: tmpnam() possibly used unsafely; consider using mkstemp()
/usr/lib/libc.so: warning: this program uses f_prealloc(), which is not recommended.
/usr/lib/libc.so: WARNING! des_cipher(3) not present in the system!
/usr/lib/libc.so: warning: tempnam() possibly used unsafely; consider using mkstemp()
for plugin in ./plugins/authorization/ao ./plugins/authorization/inetaccess ./plugins/store/files ./plugins/configuration/sgconfig ./plugins/other/ping ./plugins/capture/ether_freebsd----------------------------------------------------------2.4.8.6/projects/stargazer/plugins/authorization/ao'
Makefile:54: deps: No such file or directory
gmake[1]: Leaving directory `/usr/install/stg-2.4.8.6/projects/stargazer/plugins/authorization/ao'
gmake[1]: Leaving directory `/usr/install/stg-2.4.8.6/projects/stargazer/plugins/authorization/inetaccess'
Makefile:53: deps: No such file or directory
gmake[1]: Leaving directory `/usr/install/stg-2.4.8.6/projects/stargazer/plugins/store/files'
gmake[1]: Entering directory `/usr/install/stg-2.4.8.6/projects/stargazer/plugins/store/files'
g++ -c file_store.cpp -g3 -Wall -fPIC -I ../../../../../include -DFREE_BSD
g++ file_store.o -g3 -shared -o mod_store_files.so
gmake[1]: Entering directory `/usr/install/stg-2.4.8.6/projects/stargazer/plugins/configuration/sgconfig'
Makefile:60: deps: No such file or directory
gmake[1]: Leaving directory `/usr/install/stg-2.4.8.6/projects/stargazer/plugins/configuration/sgconfig'
Makefile:51: deps: No such file or directory
gmake[1]: Leaving directory `/usr/install/stg-2.4.8.6/projects/stargazer/plugins/capture/ether_freebsd'
gmake[1]: Entering directory `/usr/install/stg-2.4.8.6/projects/stargazer/plugins/capture/ether_freebsd'
g++ -c ether_cap.cpp -g3 -Wall -fPIC -I ../../../../../include -DFREE_BSD
g++ ether_cap.o -g3 -shared -o mod_cap_bpf.so
Некоторые подробности опущены.
Вопрос к автору это нормально?
Система FreeBSD 4.9 expat-1.95.8.0
  • Replies 78
  • Created
  • Last Reply
на 7.94 МЬ увеличился бинарник. Или в 36.1 раза.
Интерестно а на сколько увеличилось потребелние RAM?
ЗЫ: это не критика, просто замечания.
Конфигуратор у меня работает некорректно. Захожу под admin'ом - всё ок. Создаю другого админа и выставляю ему ВСЕ галочки, жму сохранить. Потом захожу под новым админом, пытаюсь зайти в список админов, а мне говорит, что Access Denied.
Опытным путём было найдено, что:
- если снять все галочки с админа, то:
ChgAdmin=0
ChgCash=0
ChgConf=0
ChgPassword=0
ChgStat=0
ChgTariff=0
password=
UsrAddDel=0
- если выставить ВСЕ галочки, то получаем следующую картину:
ChgAdmin=0
ChgCash=3
ChgConf=3
ChgPassword=1
ChgStat=3
ChgTariff=0
password=
UsrAddDel=0
- если поправить ручками вот так:
ChgAdmin=1
ChgCash=1
ChgConf=1
ChgPassword=1
ChgStat=1
ChgTariff=1
password=
UsrAddDel=1
..., то всё работает.
Отсюда вывод: баг конфигуратора.
ChgAdmin=0
ChgCash=0
ChgConf=0
ChgPassword=0
ChgStat=0
ChgTariff=0
password=
UsrAddDel=0
ChgAdmin=0
ChgCash=3
ChgConf=3
ChgPassword=1
ChgStat=3
ChgTariff=0
password=
UsrAddDel=0
ChgAdmin=1
ChgCash=1
ChgConf=1
ChgPassword=1
ChgStat=1
ChgTariff=1
password=
UsrAddDel=1
Ошибка конфигуратора.
Исправлена.
Качать тут Исправленный конфигуратор
Спасибо за оперативность :)
# ./install
install: boris: Invalid argument
Вот если бы не зашёл в файл install, не за что бы не догадался :) Подправить надо бы README.
# Installed        #
# /usr/sbin/stargazer - daemon                                                 #
# /usr/lib/stg/ - stg modules                                                  #
# /usr/etc/stargazer/ - settings                                               #
# /var/stargazer/ - DB                                                         #
Настройки у меня так и остались в /etc/stargazer, так что тоже подправить надо.
В остальном работает нормально, пока жалоб нет, кроме описанных выше.
Вопрос сразу про ExecutersNum. Как оптимально распределить это кол-во? Это и есть MaxUsers?
Второй вопрос: когда выбираю ПЕЧАТАТЬ ПОЛЬЗОВАТЕЛЯ там есть url различные, где они меняются?
Всё добро прекрасно работает на:
# uname -a
FreeBSD 6.0-RELEASE
Мда, ща пофикшу. :00:
userconf.tpl.html в директории с конфигуратором
В пофикшенном конфигураторе увидел опции рассылки сообщений, заметно более функциональные :) Глаз радуется, но они слегка не работают...
Б%я
Одим словом их не должно там быть вообще.
Чтоб не смущало тебя, скачай конфигуратор. Я убрал этот пункт меню :)
Да ладно :)
А как насчёт ExecutersNum? Это и есть MaxUsers? Как оптимальнее выставить этот параметр?
Да ладно :)
Скрипты выполняются процессом(и) stg-exec, который запускает стг. Одновременно может выполнятся столько скриптов, сколько запущено этих процессов, соотв. ExecutersNum задает число этих процессов.
Параметр MaxUsers навсегда ушел из стг. Раньше он отвечал за резервирование памяти под юзеров, сейчас же то не нужно. Память выделяется на ходу.
Почему то неработает параметр FreeMbAllowInet = yes
баланс у пользователя 0.000, предоплаченый трафик 1.000
и стоит галочка "Всегда Online" но "Online" не загорается
в чём может быть проблема?
Stargazer 2.4.8.6
Linux Fedora Core 3
А нет всё нормально работает, только почему то не сразу применяется, как это было в 2.0 версии
на сколько не сразу? должно быт в пределах пары секунд.
Щас ещё перепроверил, в некотрых случаях моментально как и в прошлой версии stargazera, но щас всё равно что то не то.
У одно пользователя сделал следующее, поставл денег 1.000 а трафика 0.000 онлай загорелся сразу, попробовал поставить денег -1.000 трафика -0.001 онлай не перестал гореть и горит уже около минут 20-и
У другого пользователя поставил денег 0.000 трафика 1.000 онлайн загорелся, потом поставил денег -1.000 и трафика 0.000 онлайн погас без задержек, потом оставил деньги -1.000 а трафик поставил 1.000 и уже минут 10 онлайн не загорается.
Ещё заметил такую вещь, после удаления пользователя, пользователь не переноситься в паку удалённых пользователей, может конечно он переноситься но я так и не дождался этого, то есть после рестарта stargazera это пользователь снова есть в списке пользователей.
Ща проверим.
А это уже странно. Удаленый пользователь должен переносится полюбому, но с задержкой в 2 минуты после удаления. И в любом случае при остановке. Странно. У меня всё работало...
Проверил. Работает. Попробуй у себя еще раз.
И посмотри лог.
Две минуты не ждал, но после рестарта точно оставался, я это несколько раз проделывал в итоге в ручную удалить пришлось.
Linux Fedora Core 3
Проверил всё равно не удаляется после рестарта.
Вот лог от момента создания пользователя.
2006-03-16 22:14:36 -- +++++++++++++++++++++++++++++++++++++++++++++
2006-03-16 22:20:18 -- Admin 'admin', 213.247.170.85: User 'test' added.
2006-03-16 22:20:22 -- Admin 'admin', 213.247.170.85: User 'test': 'IP' parameter changed from '*' to '192.168.0.22'.
2006-03-16 22:20:22 -- Admin 'admin', 213.247.170.85: User 'test': 'freeMb' parameter changed from '0' to '5.16'.
2006-03-16 22:20:22 -- Admin 'admin', 213.247.170.85: User 'test': 'password' parameter changed from '********' to '********'.
2006-03-16 22:20:22 -- Admin 'admin', 213.247.170.85: User 'test': 'tariff' parameter changed from '*_NO_TARIFF_*' to 'tariff'.
2006-03-16 22:21:23 -- Admin 'admin', 213.247.170.85: User 'test' deleted.
2006-03-16 22:21:48 -- Shutting down... 15
2006-03-16 22:21:48 -- +++++++++++++++++++++++++++++++++++++++++++++
2006-03-16 22:21:48 -- Module: 'Stg configurator v.0.03'. Stop successfull.
2006-03-16 22:21:51 -- Module: 'Pinger v.1.0'. Stop successfull.
2006-03-16 22:21:51 -- Module: 'Always Online authorizator v.0.9'. Stop successfull.
2006-03-16 22:21:52 -- Executer exited.
2006-03-16 22:22:12 -- Stg v. Stg 2.4
2006-03-16 22:22:12 -- Timer thread started successfully.
2006-03-16 22:22:12 -- Storage plugin: file_store v.1.01. Loading successfull.
2006-03-16 22:22:12 -- Users started successfully.
2006-03-16 22:22:12 -- Traffcounter started successfully.
2006-03-16 22:22:12 -- Module: 'Ether_cap v.1.0'. Start successfull. 10
2006-03-16 22:22:12 -- Module: 'InetAccess authorizator v.1.0'. Start successfull. 50
2006-03-16 22:22:12 -- Module: 'Always Online authorizator v.0.9'. Start successfull. 70
2006-03-16 22:22:12 -- Module: 'Pinger v.1.0'. Start successfull. 100
2006-03-16 22:22:12 -- Module: 'Stg configurator v.0.03'. Start successfull. 220
2006-03-16 22:22:12 -- Stg started successfully.
2006-03-16 22:22:12 -- +++++++++++++++++++++++++++++++++++++++++++++
Может быть проблема в медленном соединение с сервером?
Щас я к серверу удалённо подключаюсь конфигуратором, пинг до сервера 500-600ms, завтра днём поробую установить на другой комп котрый на одном комутаторе со мной будет висеть и тоже Fedira Core 3 поставлю.
