Перегружаеться сервер
Уже 4 день подряд перегружаеться сервер маршрутизации
Понимаю что изза dummynet, но что именно незнаю. На сервере ничего не менялось.
Помогите пожалуйста разобраться.
uname -a
FreeBSD tr_bnet 7.3-RELEASE FreeBSD 7.3-RELEASE #0: Thu Jun 28 12:34:35 UTC 2012	 pa4ka@tr_bnet:/usr/src/sys/i386/compile/BNETRAYON i386
/var/crach/vmcore0
Fatal trap 12: page fault while in kernel mode
cpuid = 0; apic id = 00
fault virtual address = 0xc
fault code = supervisor read, page not present
instruction pointer = 0x20:0xc089e628
stack pointer		 = 0x28:0xc6ed7b54
frame pointer		 = 0x28:0xc6ed7b70
code segment = base 0x0, limit 0xfffff, type 0x1b
= DPL 0, pres 1, def32 1, gran 1
processor eflags = interrupt enabled, resume, IOPL = 0
current process = 55 (dummynet)
trap number = 12
panic: page fault
cpuid = 0
Uptime: 6d5h45m42s
Physical memory: 3571 MB
Ядро
# GENERIC -- Generic kernel configuration file for FreeBSD/i386
# For more information on this file, please read the handbook section on
# Kernel Configuration Files:
# http://www.FreeBSD.org/doc/en_US.ISO8859-1/books/handbook/kernelconfig-config.html
# The handbook is also available locally in /usr/share/doc/handbook
# if you've installed the doc distribution, otherwise always see the
# FreeBSD World Wide Web server (http://www.FreeBSD.org/) for the
# latest information.
# An exhaustive list of options and more detailed explanations of the
# device lines is also present in the ../../conf/NOTES and NOTES files.
# If you are in doubt as to the purpose or necessity of a line, check first
# in NOTES.
# $FreeBSD: src/sys/i386/conf/GENERIC,v 1.474.2.22.2.1 2010/02/10 00:26:20 kensmith Exp $
#cpu		 I486_CPU
#cpu		 I586_CPU
cpu			 I686_CPU
ident		 GENERIC
# To statically compile in device wiring instead of /boot/device.hints
#hints		 "GENERIC.hints"		 # Default places to look for devices.
makeoptions	 DEBUG=-g			 # Build kernel with gdb(1) debug symbols
options		 SCHED_ULE			 # ULE scheduler
options		 PREEMPTION			 # Enable kernel thread preemption
options		 INET				 # InterNETworking
options		 INET6				 # IPv6 communications protocols
options		 SCTP				 # Stream Control Transmission Protocol
options		 FFS					 # Berkeley Fast Filesystem
options		 SOFTUPDATES			 # Enable FFS soft updates support
options		 UFS_ACL				 # Support for access control lists
options		 UFS_DIRHASH			 # Improve performance on big directories
options		 UFS_GJOURNAL		 # Enable gjournal-based UFS journaling
options		 MD_ROOT				 # MD is a potential root device
options		 NFSCLIENT			 # Network Filesystem Client
options		 NFSSERVER			 # Network Filesystem Server
options		 NFSLOCKD			 # Network Lock Manager
options		 NFS_ROOT			 # NFS usable as /, requires NFSCLIENT
options		 MSDOSFS				 # MSDOS Filesystem
options		 CD9660				 # ISO 9660 Filesystem
options		 PROCFS				 # Process filesystem (requires PSEUDOFS)
options		 PSEUDOFS			 # Pseudo-filesystem framework
options		 GEOM_PART_GPT		 # GUID Partition Tables.
options		 GEOM_LABEL			 # Provides labelization
options		 COMPAT_43TTY		 # BSD 4.3 TTY compat [KEEP THIS!]
options		 COMPAT_FREEBSD4		 # Compatible with FreeBSD4
options		 COMPAT_FREEBSD5		 # Compatible with FreeBSD5
options		 COMPAT_FREEBSD6		 # Compatible with FreeBSD6
options		 SCSI_DELAY=5000		 # Delay (in ms) before probing SCSI
options		 KTRACE				 # ktrace(1) support
options		 STACK				 # stack(9) support
options		 SYSVSHM				 # SYSV-style shared memory
options		 SYSVMSG				 # SYSV-style message queues
options		 SYSVSEM				 # SYSV-style semaphores
options		 P1003_1B_SEMAPHORES	 # POSIX-style semaphores
options		 _KPOSIX_PRIORITY_SCHEDULING # POSIX P1003_1B real-time extensions
options		 KBD_INSTALL_CDEV	 # install a CDEV entry in /dev
options		 ADAPTIVE_GIANT		 # Giant mutex is adaptive.
options		 STOP_NMI			 # Stop CPUS using NMI instead of IPI
options		 AUDIT				 # Security event auditing
#options	 KDTRACE_HOOKS		 # Kernel DTrace hooks
options		 INCLUDE_CONFIG_FILE	 # Include this file in kernel
# To make an SMP kernel, the next two lines are needed
options		 SMP					 # Symmetric MultiProcessor Kernel
device		 apic				 # I/O APIC
# CPU frequency control
device		 cpufreq
# Bus support.
device		 eisa
device		 pci
# Floppy drives
device		 fdc
# ATA and ATAPI devices
device		 ata
device		 atadisk		 # ATA disk drives
device		 ataraid		 # ATA RAID drives
device		 atapicd		 # ATAPI CDROM drives
device		 atapifd		 # ATAPI floppy drives
device		 atapist		 # ATAPI tape drives
options		 ATA_STATIC_ID # Static device numbering
# SCSI Controllers
device		 ahb			 # EISA AHA1742 family
device		 ahc			 # AHA2940 and onboard AIC7xxx devices
options		 AHC_REG_PRETTY_PRINT # Print register bitfields in debug
								 # output. Adds ~128k to driver.
device		 ahd			 # AHA39320/29320 and onboard AIC79xx devices
options		 AHD_REG_PRETTY_PRINT # Print register bitfields in debug
								 # output. Adds ~215k to driver.
device		 amd			 # AMD 53C974 (Tekram DC-390(T))
device		 hptiop		 # Highpoint RocketRaid 3xxx series
device		 isp			 # Qlogic family
#device		 ispfw		 # Firmware for QLogic HBAs- normally a module
device		 mpt			 # LSI-Logic MPT-Fusion
#device		 ncr			 # NCR/Symbios Logic
device		 sym			 # NCR/Symbios Logic (newer chipsets + those of `ncr')
device		 trm			 # Tekram DC395U/UW/F DC315U adapters
device		 adv			 # Advansys SCSI adapters
device		 adw			 # Advansys wide SCSI adapters
device		 aha			 # Adaptec 154x SCSI adapters
device		 aic			 # Adaptec 15[012]x SCSI adapters, AIC-6[23]60.
device		 bt			 # Buslogic/Mylex MultiMaster SCSI adapters
device		 ncv			 # NCR 53C500
device		 nsp			 # Workbit Ninja SCSI-3
device		 stg			 # TMC 18C30/18C50
# SCSI peripherals
device		 scbus		 # SCSI bus (required for SCSI)
device		 ch			 # SCSI media changers
device		 da			 # Direct Access (disks)
device		 sa			 # Sequential Access (tape etc)
device		 cd			 # CD
device		 pass		 # Passthrough device (direct SCSI access)
device		 ses			 # SCSI Environmental Services (and SAF-TE)
# RAID controllers interfaced to the SCSI subsystem
device		 amr			 # AMI MegaRAID
device		 arcmsr		 # Areca SATA II RAID
device		 asr			 # DPT SmartRAID V, VI and Adaptec SCSI RAID
device		 ciss		 # Compaq Smart RAID 5*
device		 dpt			 # DPT Smartcache III, IV - See NOTES for options
device		 hptmv		 # Highpoint RocketRAID 182x
device		 hptrr		 # Highpoint RocketRAID 17xx, 22xx, 23xx, 25xx
device		 iir			 # Intel Integrated RAID
device		 ips			 # IBM (Adaptec) ServeRAID
device		 mly			 # Mylex AcceleRAID/eXtremeRAID
device		 twa			 # 3ware 9000 series PATA/SATA RAID
# RAID controllers
device		 aac			 # Adaptec FSA RAID
device		 aacp		 # SCSI passthrough for aac (requires CAM)
device		 ida			 # Compaq Smart RAID
device		 mfi			 # LSI MegaRAID SAS
device		 mlx			 # Mylex DAC960 family
device		 pst			 # Promise Supertrak SX6000
device		 twe			 # 3ware ATA RAID
# atkbdc0 controls both the keyboard and the PS/2 mouse
device		 atkbdc		 # AT keyboard controller
device		 atkbd		 # AT keyboard
device		 psm			 # PS/2 mouse
device		 kbdmux		 # keyboard multiplexer
device		 vga			 # VGA video card driver
device		 splash		 # Splash screen and screen saver support
# syscons is the default console driver, resembling an SCO console
device		 sc
device		 agp			 # support several AGP chipsets
# Power management support (see NOTES for more options)
#device		 apm
# Add suspend/resume support for the i8254.
device		 pmtimer
# PCCARD (PCMCIA) support
# PCMCIA and cardbus bridge support
device		 cbb			 # cardbus (yenta) bridge
device		 pccard		 # PC Card (16-bit) bus
device		 cardbus		 # CardBus (32-bit) bus
# Serial (COM) ports
device		 sio			 # 8250, 16[45]50 based serial ports
device		 uart		 # Generic UART driver
# Parallel port
device		 ppc
device		 ppbus		 # Parallel port bus (required)
device		 lpt			 # Printer
device		 plip		 # TCP/IP over parallel
device		 ppi			 # Parallel port interface device
#device		 vpo			 # Requires scbus and da
# If you've got a "dumb" serial or parallel PCI card that is
# supported by the puc(4) glue driver, uncomment the following
# line to enable it (connects to sio, uart and/or ppc drivers):
#device		 puc
# PCI Ethernet NICs.
device		 de			 # DEC/Intel DC21x4x (``Tulip'')
device		 em			 # Intel PRO/1000 Gigabit Ethernet Family
device		 igb			 # Intel PRO/1000 PCIE Server Gigabit Family
device		 ixgb		 # Intel PRO/10GbE Ethernet Card
device		 le			 # AMD Am7900 LANCE and Am79C9xx PCnet
device		 txp			 # 3Com 3cR990 (``Typhoon'')
device		 vx			 # 3Com 3c590, 3c595 (``Vortex'')
# PCI Ethernet NICs that use the common MII bus controller code.
# NOTE: Be sure to keep the 'device miibus' line in order to use these NICs!
device		 miibus		 # MII bus support
device		 age			 # Attansic/Atheros L1 Gigabit Ethernet
device		 alc			 # Atheros AR8131/AR8132 Ethernet
device		 ale			 # Atheros AR8121/AR8113/AR8114 Ethernet
device		 bce			 # Broadcom BCM5706/BCM5708 Gigabit Ethernet
device		 bfe			 # Broadcom BCM440x 10/100 Ethernet
device		 bge			 # Broadcom BCM570xx Gigabit Ethernet
device		 dc			 # DEC/Intel 21143 and various workalikes
device		 et			 # Agere ET1310 10/100/Gigabit Ethernet
device		 fxp			 # Intel EtherExpress PRO/100B (82557, 82558)
device		 jme			 # JMicron JMC250 Gigabit/JMC260 Fast Ethernet
device		 lge			 # Level 1 LXT1001 gigabit Ethernet
device		 msk			 # Marvell/SysKonnect Yukon II Gigabit Ethernet
device		 nfe			 # nVidia nForce MCP on-board Ethernet
device		 nge			 # NatSemi DP83820 gigabit Ethernet
#device		 nve			 # nVidia nForce MCP on-board Ethernet Networking
device		 pcn			 # AMD Am79C97x PCI 10/100 (precedence over 'le')
device		 re			 # RealTek 8139C+/8169/8169S/8110S
device		 rl			 # RealTek 8129/8139
device		 sf			 # Adaptec AIC-6915 (``Starfire'')
device		 sis			 # Silicon Integrated Systems SiS 900/SiS 7016
device		 sk			 # SysKonnect SK-984x & SK-982x gigabit Ethernet
device		 ste			 # Sundance ST201 (D-Link DFE-550TX)
device		 stge		 # Sundance/Tamarack TC9021 gigabit Ethernet
device		 ti			 # Alteon Networks Tigon I/II gigabit Ethernet
device		 tl			 # Texas Instruments ThunderLAN
device		 tx			 # SMC EtherPower II (83c170 ``EPIC'')
device		 vge			 # VIA VT612x gigabit Ethernet
device		 vr			 # VIA Rhine, Rhine II
device		 wb			 # Winbond W89C840F
device		 xl			 # 3Com 3c90x (``Boomerang'', ``Cyclone'')
# ISA Ethernet NICs. pccard NICs included.
device		 cs			 # Crystal Semiconductor CS89x0 NIC
# 'device ed' requires 'device miibus'
device		 ed			 # NE[12]000, SMC Ultra, 3c503, DS8390 cards
device		 ex			 # Intel EtherExpress Pro/10 and Pro/10+
device		 ep			 # Etherlink III based cards
device		 fe			 # Fujitsu MB8696x based cards
device		 ie			 # EtherExpress 8/16, 3C507, StarLAN 10 etc.
device		 sn			 # SMC's 9000 series of Ethernet chips
device		 xe			 # Xircom pccard Ethernet
# Wireless NIC cards
device		 wlan		 # 802.11 support
device		 wlan_wep	 # 802.11 WEP support
device		 wlan_ccmp	 # 802.11 CCMP support
device		 wlan_tkip	 # 802.11 TKIP support
device		 wlan_amrr	 # AMRR transmit rate control algorithm
device		 wlan_scan_ap # 802.11 AP mode scanning
device		 wlan_scan_sta # 802.11 STA mode scanning
device		 an			 # Aironet 4500/4800 802.11 wireless NICs.
device		 ath			 # Atheros pci/cardbus NIC's
device		 ath_hal		 # Atheros HAL (Hardware Access Layer)
options		 AH_SUPPORT_AR5416	 # enable AR5416 tx/rx descriptors
device		 ath_rate_sample # SampleRate tx rate control for ath
device		 awi			 # BayStack 660 and others
device		 ral			 # Ralink Technology RT2500 wireless NICs.
device		 wi			 # WaveLAN/Intersil/Symbol 802.11 wireless NICs.
#device		 wl			 # Older non 802.11 Wavelan wireless NIC.
# Pseudo devices.
device		 loop		 # Network loopback
device		 random		 # Entropy device
device		 ether		 # Ethernet support
device		 vlan		 # 802.1Q VLAN support
device		 sl			 # Kernel SLIP
device		 ppp			 # Kernel PPP
device		 tun			 # Packet tunnel.
device		 pty			 # Pseudo-ttys (telnet etc)
device		 md			 # Memory "disks"
device		 gif			 # IPv6 and IPv4 tunneling
device		 faith		 # IPv6-to-IPv4 relaying (translation)
device		 firmware	 # firmware assist module
# The `bpf' device enables the Berkeley Packet Filter.
# Be aware of the administrative consequences of enabling this!
# Note that 'bpf' is required for DHCP.
device		 bpf			 # Berkeley packet filter
# USB support
device		 uhci		 # UHCI PCI->USB interface
device		 ohci		 # OHCI PCI->USB interface
device		 ehci		 # EHCI PCI->USB interface (USB 2.0)
device		 usb			 # USB Bus (required)
#device		 udbp		 # USB Double Bulk Pipe devices
device		 ugen		 # Generic
device		 uhid		 # "Human Interface Devices"
device		 ukbd		 # Keyboard
device		 ulpt		 # Printer
device		 umass		 # Disks/Mass storage - Requires scbus and da
device		 ums			 # Mouse
device		 urio		 # Diamond Rio 500 MP3 player
device		 uscanner	 # Scanners
# USB Serial devices
device		 ucom		 # Generic com ttys
device		 uark		 # Technologies ARK3116 based serial adapters
device		 ubsa		 # Belkin F5U103 and compatible serial adapters
device		 ubser		 # BWCT console serial adapters
device		 uftdi		 # For FTDI usb serial adapters
device		 uipaq		 # Some WinCE based devices
device		 uplcom		 # Prolific PL-2303 serial adapters
device		 uslcom		 # SI Labs CP2101/CP2102 serial adapters
device		 uvisor		 # Visor and Palm devices
device		 uvscom		 # USB serial support for DDI pocket's PHS
# USB Ethernet, requires miibus
device		 aue			 # ADMtek USB Ethernet
device		 axe			 # ASIX Electronics USB Ethernet
device		 cdce		 # Generic USB over Ethernet
device		 cue			 # CATC USB Ethernet
device		 kue			 # Kawasaki LSI USB Ethernet
device		 rue			 # RealTek RTL8150 USB Ethernet
# USB Wireless
device		 rum			 # Ralink Technology RT2501USB wireless NICs
device		 ural		 # Ralink Technology RT2500USB wireless NICs
# FireWire support
device		 firewire	 # FireWire bus code
device		 sbp			 # SCSI over FireWire (Requires scbus and da)
device		 fwe			 # Ethernet over FireWire (non-standard!)
device		 fwip		 # IP over FireWire (RFC 2734,3146)
device		 dcons		 # Dumb console driver
device		 dcons_crom	 # Configuration ROM for dcons
options		 HZ=1000
options		 IPFIREWALL
options		 IPFIREWALL_FORWARD
options		 IPDIVERT
options		 DUMMYNET
#options	 IPFIREWALL_NAT
#options	 LIBALIAS
options		 ROUTETABLES=4
options		 SCHED_ULE
device		 pf
device		 pflog
device		 pfsync
options		 ALTQ
options		 ALTQ_CBQ	 # Class Bases Queuing (CBQ)
options		 ALTQ_RED	 # Random Early Detection (RED)
options		 ALTQ_RIO	 # RED In/Out
options		 ALTQ_HFSC	 # Hierarchical Packet Scheduler (HFSC)
options		 ALTQ_PRIQ	 # Priority Queuing (PRIQ)
options		 ALTQ_NOPCC	 # Required for SMP build
options		 GEOM_MIRROR			 # Disk mirroring.
options		 GEOM_JOURNAL		 # Journaling.
# netgraph(4). Enable the base netgraph code with the NETGRAPH option.
options		 NETGRAPH			 # netgraph(4) system
options		 NETGRAPH_BPF
#options		 NETGRAPH_BRIDGE
#options		 NETGRAPH_CAR
options		 NETGRAPH_ETHER
options		 NETGRAPH_IFACE
options		 NETGRAPH_IPFW
options		 NETGRAPH_KSOCKET
#options	 NETGRAPH_MPPC_COMPRESSION
#options		 NETGRAPH_MPPC_ENCRYPTION
#options		 NETGRAPH_NETFLOW
#options		 NETGRAPH_NAT
options		 NETGRAPH_ONE2MANY
options		 NETGRAPH_PPP
options		 NETGRAPH_PPPOE
options		 NETGRAPH_PPTPGRE
options		 NETGRAPH_SOCKET
options		 NETGRAPH_SPLIT
options		 NETGRAPH_TCPMSS
options		 NETGRAPH_TEE
options		 NETGRAPH_VJC
Напишу все подробности какие надо.
top-SHIP думаю не успею потому что два раза в день не синхронно делает)
00050 allow tcp from any to me dst-port 22
00051 allow tcp from me 22 to any
00110 allow ip from any to any via lo0
00120 skipto 1000 ip from me to any
00130 deny icmp from any to any in icmptypes 5,9,13,14,15,16,17
00160 skipto 2000 ip from any to me
00200 skipto 700 ip from any to any via bge0
00280 fwd 127.0.0.1,8081 tcp from table(35) to not me dst-port 80 in
00290 fwd 127.0.0.1,8082 tcp from not table(0) to not me dst-port 80 in
00350 skipto 4500 ip from any to any in
00400 skipto 450 ip from any to any recv bge0
00520 tee 1 ip from any to any
00550 tee 2 ip from any to any
00590 allow ip from any to any
00700 skipto 32500 ip from any to any in
00710 tee 1 ip from any to any
00740 allow ip from any to any
01000 allow udp from any 53,7723 to any
01010 allow tcp from any to any setup keep-state
01020 allow udp from any to any keep-state
01100 allow ip from any to any
02000 check-state
02010 allow icmp from any to any
02020 allow tcp from any to any dst-port 80,443
02050 deny ip from any to any via bge0
02100 allow udp from any to any dst-port 53,7723
02110 allow tcp from any to any dst-port 1194
02200 deny ip from any to any
05000 deny ip from not table(0) to any
05001 skipto 5010 ip from table(127) to table(126)
05002 skipto 5030 ip from any to not table(2)
05003 deny ip from any to not table(1)
05004 pipe tablearg ip from table(21) to any
05005 deny ip from any to any
05010 pipe tablearg ip from table(127) to any
05030 deny tcp from table(15) to any dst-port 25
05400 pipe tablearg ip from table(11) to any
32000 deny ip from any to any
32490 deny ip from any to any
33000 pipe tablearg ip from table(126) to table(127)
33001 skipto 33010 ip from not table(2) to any
33002 pipe tablearg ip from any to table(20)
33003 deny ip from any to any
33400 pipe tablearg ip from any to table(10)
65535 deny ip from any to any
http://www.opennet.r...lution.txt.html Не ваша ситуация?
перед падением в messages только ето
Dec 14 14:01:28 tr_bnet kernel: Fatal trap 12: page fault while in kernel mode
Dec 14 14:01:28 tr_bnet kernel: cpuid = 1; apic id = 01
Dec 14 14:01:28 tr_bnet kernel: fault virtual address<->= 0xc
Dec 14 14:01:28 tr_bnet kernel: fault code<----><------>= supervisor read, page not present
Dec 14 14:01:28 tr_bnet kernel: instruction pointer<--->= 0x20:0xc089f816
Dec 14 14:01:28 tr_bnet kernel: stack pointer<->	    = 0x28:0xc6ed7a84
Dec 14 14:01:28 tr_bnet kernel: frame pointer<->	    = 0x28:0xc6ed7ab0
Dec 14 14:01:28 tr_bnet kernel:.
Dec 14 14:01:28 tr_bnet kernel: code segment<--><------>= base.
Dec 14 14:01:28 tr_bnet kernel: 0x0, limi
Dec 14 14:01:28 tr_bnet kernel: t 0xffff
Dec 14 14:01:28 tr_bnet kernel: f, type 0
Dec 14 14:01:28 tr_bnet kernel: x1b
Dec 14 14:01:28 tr_bnet kernel: = DPL 0,.
Dec 14 14:01:28 tr_bnet kernel: pres 1,.
Dec 14 14:01:28 tr_bnet kernel: def32 1,
Dec 14 14:01:28 tr_bnet kernel: gran 1
Dec 14 14:01:28 tr_bnet kernel: processor eflag
Dec 14 14:01:28 tr_bnet kernel: s<----->= inte
Dec 14 14:01:28 tr_bnet kernel: rrupt e
Dec 14 14:01:28 tr_bnet kernel: nabled,.
Dec 14 14:01:28 tr_bnet kernel: resume,.
Dec 14 14:01:28 tr_bnet kernel: IOPL = 0
Да это еще шикарно 2 раза в день, у нас 1 раз в два-пять дней NASы ребутились, ставил ping localhost, и постоянно наблюдал и как только начинались дропы снимал статистику, пробывал тут же на лету увеличивать буферы и т.д. ни чего не помогало и через пару-тройку минут NAS уходил в ребут.
Freebsd 9, пробывал откатываться на 8. MPD5.6, pptp, ipfw nat, ospf, карты broadcom. Ребуты происходили не зависимо от нагрузки, кол-ва тунелей и времени суток. Причем если в момент падения сервера выключить нат, то его работа сразу же стабилизировалась. В итоге перешли на pf.
Сервер маршрутизации с биллингом NoDeny. Устанавливалось с коробки
Может проблема с винтами? Стоит RAID 5. Можно ли их проверить удалённо?
Попробуйте перейти на pf, у вас ядро собрано с его поддержкой, делов две минуты пользователи даже ничего не заметят.
ну с коробки по доке всё на pf, кроме того что он в ядре
set limit states 128000
set optimization aggressive
nat pass on bge0 from 172.21.0.0/16 to any -> bge0
Попробуйте обновится до 9 версии, вырубите я ядре inet6, отключите проверку контрольных сумм на интерфейсе, dummynet заменить на ng_car если биллинг позволяет. MPD какой у Вас?
mpd нету, привязка по IP+MAC выдаеться DHCP сервером клиентам
была такая ситуация! тоже биллинг ноудени
Решил:
Ядро 64 бит
С ядра все лишнее убрано!
+ сетевую поставил em0
А просто сетевую поставить не помогло?
Решил:
Ядро 64 бит
Не экспериментировал когда сервер начал пару раз в день перегружаться - сразу на тестовом компе настроил заново систему с теми параметрами что выше написал, переставил винты и работаем дальше!
Дабы не стартовать новую тему:
Сегодня отпала на роутере сетевая которая смотрит в сторону биллинга, может кто подскажет в чем беда,
в логах такое:
Jan 3 12:02:45 bras1 syslogd: kernel boot file is /boot/kernel/kernel
Jan 3 12:02:45 bras1 kernel: Copyright © 1992-2011 The FreeBSD Project.
Jan 3 12:02:45 bras1 kernel: Copyright © 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Jan 3 12:02:45 bras1 kernel: The Regents of the University of California. All rights reserved.
Jan 3 12:02:45 bras1 kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Jan 3 12:02:45 bras1 kernel: FreeBSD 8.2-STABLE #0 r226362: Fri Oct 14 21:53:34 EEST 2011
Jan 3 12:02:45 bras1 kernel: smail@bras1.galaxy:/usr/obj/usr/src/sys/BRAS111014 amd64
Jan 3 12:02:45 bras1 kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Jan 3 12:02:45 bras1 kernel: CPU: Intel® Core i3 CPU 550 @ 3.20GHz (3211.20-MHz K8-class CPU)
Jan 3 12:02:45 bras1 kernel: Origin = "GenuineIntel" Id = 0x20655 Family = 6 Model = 25 Stepping = 5
Jan 3 12:02:45 bras1 kernel: Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,
Jan 3 12:02:45 bras1 kernel: Features2=0x9ae3bd<SSE3,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,POPCNT>
Jan 3 12:02:45 bras1 kernel: AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
Jan 3 12:02:45 bras1 kernel: AMD Features2=0x1<LAHF>
Jan 3 12:02:45 bras1 kernel: TSC: P-state invariant
Jan 3 12:02:45 bras1 kernel: real memory = 2147483648 (2048 MB)
Jan 3 12:02:45 bras1 kernel: avail memory = 2046537728 (1951 MB)
Jan 3 12:02:45 bras1 kernel: ACPI APIC Table: <070810 APIC1518>
Jan 3 12:02:45 bras1 kernel: FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
Jan 3 12:02:45 bras1 kernel: FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 SMT threads
Jan 3 12:02:45 bras1 kernel: cpu0 (BSP): APIC ID: 0
Jan 3 12:02:45 bras1 kernel: cpu1 (AP): APIC ID: 1
Jan 3 12:02:45 bras1 kernel: cpu2 (AP): APIC ID: 4
Jan 3 12:02:45 bras1 kernel: cpu3 (AP): APIC ID: 5
Jan 3 12:02:45 bras1 kernel: ioapic0: Changing APIC ID to 6
Jan 3 12:02:45 bras1 kernel: ioapic0 <Version 2.0> irqs 0-23 on motherboard
Jan 3 12:02:45 bras1 kernel: kbd1 at kbdmux0
Jan 3 12:02:45 bras1 kernel: acpi0: <070810 XSDT1518> on motherboard
Jan 3 12:02:45 bras1 kernel: acpi0: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: acpi0: Power Button (fixed)
Jan 3 12:02:45 bras1 kernel: acpi0: reservation of fee00000, 1000 (3) failed
Jan 3 12:02:45 bras1 kernel: acpi0: reservation of 0, a0000 (3) failed
Jan 3 12:02:45 bras1 kernel: acpi0: reservation of 100000, 7ff00000 (3) failed
Jan 3 12:02:45 bras1 kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
Jan 3 12:02:45 bras1 kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
Jan 3 12:02:45 bras1 kernel: cpu0: <ACPI CPU> on acpi0
Jan 3 12:02:45 bras1 kernel: ACPI Warning: Incorrect checksum in table [OEMB] - 0x2E, should be 0x2D (20101013/tbutils-354)
Jan 3 12:02:45 bras1 kernel: cpu1: <ACPI CPU> on acpi0
Jan 3 12:02:45 bras1 kernel: cpu2: <ACPI CPU> on acpi0
Jan 3 12:02:45 bras1 kernel: cpu3: <ACPI CPU> on acpi0
Jan 3 12:02:45 bras1 kernel: pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Jan 3 12:02:45 bras1 kernel: pci0: <ACPI PCI bus> on pcib0
Jan 3 12:02:45 bras1 kernel: pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
Jan 3 12:02:45 bras1 kernel: pci1: <ACPI PCI bus> on pcib1
Jan 3 12:02:45 bras1 kernel: vgapci0: <VGA-compatible display> mem 0xf6000000-0xf6ffffff,0xe0000000-0xefffffff,0xf5000000-0xf5ffffff irq 16 at device 0.0 on
Jan 3 12:02:45 bras1 kernel: ehci0: <Intel PCH USB 2.0 controller USB-B> mem 0xf4ffe000-0xf4ffe3ff irq 16 at device 26.0 on pci0
Jan 3 12:02:45 bras1 kernel: ehci0: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: usbus0: EHCI version 1.0
Jan 3 12:02:45 bras1 kernel: usbus0: <Intel PCH USB 2.0 controller USB-B> on ehci0
Jan 3 12:02:45 bras1 kernel: pci0: <multimedia, HDA> at device 27.0 (no driver attached)
Jan 3 12:02:45 bras1 kernel: pcib2: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0
Jan 3 12:02:45 bras1 kernel: pci6: <ACPI PCI bus> on pcib2
Jan 3 12:02:45 bras1 kernel: pcib3: <ACPI PCI-PCI bridge> irq 17 at device 28.4 on pci0
Jan 3 12:02:45 bras1 kernel: pci5: <ACPI PCI bus> on pcib3
Jan 3 12:02:45 bras1 kernel: pcib4: <ACPI PCI-PCI bridge> irq 16 at device 28.5 on pci0
Jan 3 12:02:45 bras1 kernel: pci4: <ACPI PCI bus> on pcib4
Jan 3 12:02:45 bras1 kernel: pcib5: <ACPI PCI-PCI bridge> irq 18 at device 28.6 on pci0
Jan 3 12:02:45 bras1 kernel: pci3: <ACPI PCI bus> on pcib5
Jan 3 12:02:45 bras1 kernel: atapci0: <VIA ATA controller> port 0xdc00-0xdc07,0xd880-0xd883,0xd800-0xd807,0xd480-0xd483,0xd400-0xd40f irq 18 at device 0.0 o
Jan 3 12:02:45 bras1 kernel: atapci0: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: ata2: <ATA channel 0> on atapci0
Jan 3 12:02:45 bras1 kernel: ata2: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: ata3: <ATA channel 1> on atapci0
Jan 3 12:02:45 bras1 kernel: ata3: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: pcib6: <ACPI PCI-PCI bridge> irq 19 at device 28.7 on pci0
Jan 3 12:02:45 bras1 kernel: pci2: <ACPI PCI bus> on pcib6
Jan 3 12:02:45 bras1 kernel: re0: <RealTek 8168/8111 B/C/CP/D/DP/E PCIe Gigabit Ethernet> port 0xc800-0xc8ff mem 0xf3fff000-0xf3ffffff,0xf3ff8000-0xf3ffbfff
Jan 3 12:02:45 bras1 kernel: re0: Using 1 MSI-X message
Jan 3 12:02:45 bras1 kernel: re0: Chip rev. 0x28000000
Jan 3 12:02:45 bras1 kernel: re0: MAC rev. 0x00000000
Jan 3 12:02:45 bras1 kernel: miibus0: <MII bus> on re0
Jan 3 12:02:45 bras1 kernel: rgephy0: <RTL8169S/8110S/8211B media interface> PHY 1 on miibus0
Jan 3 12:02:45 bras1 kernel: rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-mast
Jan 3 12:02:45 bras1 kernel: re0: Ethernet address: 20:cf:30:cd:43:c6
Jan 3 12:02:45 bras1 kernel: re0: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: ehci1: <Intel PCH USB 2.0 controller USB-A> mem 0xf4ffd000-0xf4ffd3ff irq 23 at device 29.0 on pci0
Jan 3 12:02:45 bras1 kernel: ehci1: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: usbus1: EHCI version 1.0
Jan 3 12:02:45 bras1 kernel: usbus1: <Intel PCH USB 2.0 controller USB-A> on ehci1
Jan 3 12:02:45 bras1 kernel: pcib7: <ACPI PCI-PCI bridge> at device 30.0 on pci0
Jan 3 12:02:45 bras1 kernel: pci7: <ACPI PCI bus> on pcib7
Jan 3 12:02:45 bras1 kernel: em0: <Intel® PRO/1000 Legacy Network Connection 1.0.3> port 0xec00-0xec3f mem 0xf7fe0000-0xf7ffffff,0xf7fc0000-0xf7fdffff irq
Jan 3 12:02:45 bras1 kernel: em0: [FILTER]
Jan 3 12:02:45 bras1 kernel: em0: Ethernet address: 00:1b:21:6e:a6:55
Jan 3 12:02:45 bras1 kernel: em1: <Intel® PRO/1000 Legacy Network Connection 1.0.3> port 0xe880-0xe8bf mem 0xf7f80000-0xf7f9ffff,0xf7f60000-0xf7f7ffff irq
Jan 3 12:02:45 bras1 kernel: em1: [FILTER]
Jan 3 12:02:45 bras1 kernel: em1: Ethernet address: 00:1b:21:6e:a6:41
Jan 3 12:02:45 bras1 kernel: isab0: <PCI-ISA bridge> at device 31.0 on pci0
Jan 3 12:02:45 bras1 kernel: isa0: <ISA bus> on isab0
Jan 3 12:02:45 bras1 kernel: atapci1: <Intel 5 Series/3400 Series PCH SATA300 controller> port 0xac00-0xac07,0xa880-0xa883,0xa800-0xa807,0xa480-0xa483,0xa40
Jan 3 12:02:45 bras1 kernel: atapci1: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: ata4: <ATA channel 0> on atapci1
Jan 3 12:02:45 bras1 kernel: ata4: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: ata5: <ATA channel 1> on atapci1
Jan 3 12:02:45 bras1 kernel: ata5: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
Jan 3 12:02:45 bras1 kernel: atapci2: <Intel 5 Series/3400 Series PCH SATA300 controller> port 0xbc00-0xbc07,0xb880-0xb883,0xb800-0xb807,0xb480-0xb483,0xb40
Jan 3 12:02:45 bras1 kernel: atapci2: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: ata6: <ATA channel 0> on atapci2
Jan 3 12:02:45 bras1 kernel: ata6: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: ata7: <ATA channel 1> on atapci2
Jan 3 12:02:45 bras1 kernel: ata7: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: acpi_button0: <Power Button> on acpi0
Jan 3 12:02:45 bras1 kernel: atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Jan 3 12:02:45 bras1 kernel: acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Jan 3 12:02:45 bras1 kernel: Timecounter "HPET" frequency 14318180 Hz quality 900
Jan 3 12:02:45 bras1 kernel: uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
Jan 3 12:02:45 bras1 kernel: uart0: [FILTER]
Jan 3 12:02:45 bras1 kernel: atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
Jan 3 12:02:45 bras1 kernel: atkbd0: <AT Keyboard> irq 1 on atkbdc0
Jan 3 12:02:45 bras1 kernel: kbd0 at atkbd0
Jan 3 12:02:45 bras1 kernel: atkbd0: [GIANT-LOCKED]
Jan 3 12:02:45 bras1 kernel: atkbd0: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: psm0: <PS/2 Mouse> irq 12 on atkbdc0
Jan 3 12:02:45 bras1 kernel: psm0: [GIANT-LOCKED]
Jan 3 12:02:45 bras1 kernel: psm0: [iTHREAD]
Jan 3 12:02:45 bras1 kernel: psm0: model IntelliMouse Explorer, device ID 4
Jan 3 12:02:45 bras1 kernel: orm0: <ISA Option ROMs> at iomem 0xc0000-0xcefff,0xcf000-0xcffff,0xd0000-0xd0fff on isa0
Jan 3 12:02:45 bras1 kernel: sc0: <System console> at flags 0x100 on isa0
Jan 3 12:02:45 bras1 kernel: sc0: VGA <16 virtual consoles, flags=0x300>
Jan 3 12:02:45 bras1 kernel: vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Jan 3 12:02:45 bras1 kernel: est0: <Enhanced SpeedStep Frequency Control> on cpu0
Jan 3 12:02:45 bras1 kernel: p4tcc0: <CPU Frequency Thermal Control> on cpu0
Jan 3 12:02:45 bras1 kernel: est1: <Enhanced SpeedStep Frequency Control> on cpu1
Jan 3 12:02:45 bras1 kernel: p4tcc1: <CPU Frequency Thermal Control> on cpu1
Jan 3 12:02:45 bras1 kernel: est2: <Enhanced SpeedStep Frequency Control> on cpu2
Jan 3 12:02:45 bras1 kernel: p4tcc2: <CPU Frequency Thermal Control> on cpu2
Jan 3 12:02:45 bras1 kernel: est3: <Enhanced SpeedStep Frequency Control> on cpu3
Jan 3 12:02:45 bras1 kernel: p4tcc3: <CPU Frequency Thermal Control> on cpu3
Jan 3 12:02:45 bras1 kernel: Timecounters tick every 1.000 msec
Jan 3 12:02:45 bras1 kernel: ipfw2 initialized, divert loadable, nat loadable, rule-based forwarding enabled, default to deny, logging disabled
Jan 3 12:02:45 bras1 kernel: usbus0: 480Mbps High Speed USB v2.0
Jan 3 12:02:45 bras1 kernel: usbus1: 480Mbps High Speed USB v2.0
Jan 3 12:02:45 bras1 kernel: ad8: 114497MB <SAMSUNG SP1213C SV100-30> at ata4-master UDMA100 SATA 1.5Gb/s
Jan 3 12:02:45 bras1 kernel: ugen0.1: <Intel> at usbus0
Jan 3 12:02:45 bras1 kernel: uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
Jan 3 12:02:45 bras1 kernel: ugen1.1: <Intel> at usbus1
Jan 3 12:02:45 bras1 kernel: uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Jan 3 12:02:45 bras1 kernel: SMP: AP CPU #1 Launched!
Jan 3 12:02:45 bras1 kernel: SMP: AP CPU #2 Launched!
Jan 3 12:02:45 bras1 kernel: SMP: AP CPU #3 Launched!
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal 3140362783: ad8s1a contains data.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal 3140362783: ad8s1a contains journal.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal ad8s1a consistent.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal 2597746777: ad8s1d contains data.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal 2597746777: ad8s1d contains journal.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal ad8s1d consistent.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal 2136003222: ad8s1e contains data.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal 2136003222: ad8s1e contains journal.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal ad8s1e consistent.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal 2852105731: ad8s1f contains data.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal 2852105731: ad8s1f contains journal.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal ad8s1f consistent.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal 2006152971: ad8s1g contains data.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal 2006152971: ad8s1g contains journal.
Jan 3 12:02:45 bras1 kernel: GEOM_JOURNAL: Journal ad8s1g consistent.
Jan 3 12:02:45 bras1 kernel: Root mount waiting for: usbus1 usbus0
Jan 3 12:02:45 bras1 kernel: uhub0: 2 ports with 2 removable, self powered
Jan 3 12:02:45 bras1 kernel: uhub1: 2 ports with 2 removable, self powered
Jan 3 12:02:45 bras1 kernel: ugen0.2: <vendor 0x8087> at usbus0
Jan 3 12:02:45 bras1 kernel: uhub2: <vendor 0x8087 product 0x0020, class 9/0, rev 2.00/0.00, addr 2> on usbus0
Jan 3 12:02:45 bras1 kernel: ugen1.2: <vendor 0x8087> at usbus1
Jan 3 12:02:45 bras1 kernel: uhub3: <vendor 0x8087 product 0x0020, class 9/0, rev 2.00/0.00, addr 2> on usbus1
Jan 3 12:02:45 bras1 kernel: uhub2: 6 ports with 6 removable, self powered
Jan 3 12:02:45 bras1 kernel: uhub3: 8 ports with 8 removable, self powered
Jan 3 12:02:45 bras1 kernel: ugen1.3: <POWERCOM Co.,LTD> at usbus1
Jan 3 12:02:45 bras1 kernel: uhid0: <POWERCOM Co.,LTD HID UPS Battery, class 0/0, rev 1.10/0.01, addr 3> on usbus1
Jan 3 12:02:45 bras1 kernel: Trying to mount root from ufs:/dev/ufs/br1root
Jan 3 12:02:45 bras1 kernel: WARNING: / was not properly dismounted
Jan 3 12:02:47 bras1 kernel: em0: link state changed to UP
Jan 3 12:02:47 bras1 kernel: em1: link state changed to UP
Jan 3 12:02:47 bras1 kernel: vlan17: link state changed to UP
Jan 3 12:02:47 bras1 kernel: vlan16: link state changed to UP
Jan 3 12:02:47 bras1 kernel: vlan19: link state changed to UP
Jan 3 12:02:47 bras1 kernel: vlan18: link state changed to UP
Jan 3 12:02:47 bras1 kernel: vlan0: link state changed to UP
Jan 3 12:02:47 bras1 kernel: vlan1: link state changed to UP
Jan 3 12:02:47 bras1 kernel: vlan15: link state changed to UP
Jan 3 12:02:48 bras1 dhcpd:
Jan 3 12:02:48 bras1 kernel: 12
Jan 3 12:02:48 bras1 dhcpd: No subnet declaration for vlan1 (10.10.0.254).
Jan 3 12:02:48 bras1 dhcpd: ** Ignoring requests on vlan1. If this is not what
Jan 3 12:02:48 bras1 dhcpd: you want, please write a subnet declaration
Jan 3 12:02:48 bras1 dhcpd: in your dhcpd.conf file for the network segment
Jan 3 12:02:48 bras1 dhcpd: to which interface vlan1 is attached. **
Jan 3 12:02:48 bras1 dhcpd: No subnet declaration for em1 (no IPv4 addresses).
Jan 3 12:02:48 bras1 dhcpd: ** Ignoring requests on em1. If this is not what
Jan 3 12:02:48 bras1 dhcpd: to which interface em1 is attached. **
Jan 3 12:02:48 bras1 dhcpd: No subnet declaration for em0 (10.100.100.1).
Jan 3 12:02:48 bras1 dhcpd: ** Ignoring requests on em0. If this is not what
Jan 3 12:02:48 bras1 dhcpd: to which interface em0 is attached. **
Еще в логах начали появляться такие сообщения:
Jan 2 12:18:38 bras1 kernel: Limiting icmp ping response from 4624 to 200 packets/sec
Jan 2 12:26:37 bras1 kernel: Limiting icmp ping response from 224 to 200 packets/sec
Jan 2 12:26:40 bras1 kernel: Limiting icmp ping response from 301 to 200 packets/sec
Jan 2 12:26:44 bras1 kernel: Limiting icmp ping response from 1001 to 200 packets/sec
Jan 2 12:26:45 bras1 kernel: Limiting icmp ping response from 4545 to 200 packets/sec
Jan 2 12:26:46 bras1 kernel: Limiting icmp ping response from 4329 to 200 packets/sec
Jan 2 12:26:47 bras1 kernel: Limiting icmp ping response from 4684 to 200 packets/sec
Jan 2 12:26:48 bras1 kernel: Limiting icmp ping response from 3863 to 200 packets/sec
Jan 2 12:26:54 bras1 kernel: Limiting icmp ping response from 2575 to 200 packets/sec
Jan 2 12:26:55 bras1 kernel: Limiting icmp ping response from 4302 to 200 packets/sec
Jan 2 12:26:56 bras1 kernel: Limiting icmp ping response from 4552 to 200 packets/sec
Кто то балуется с сети?
