Куплю салазки extreme x670
By marshal
Добрый день, купили 2 Extreme x670 и не можем сбросить - стандартная команда :
BootRom > config none
Configuration selected: none
BootRom > boot
не доступна!
Вот меню какое есть у нас в Bootrom:
BootRom > help
Boot and Load
pboot boot
oload load memory from hostport
load load file
boot boot an image
Misc
loader Sets which BootLoader BootStrap will boot
call call function
devls list devices
reboot Reboot system (hard reset)
flash program flash memory
show display information
Debugger
cpu select cpuinfo
c continue execution
t trace (single step)
to trace (step over)
db delete break point(s)
b set break point(s)
g start execution (go)
sym define symbol
ls list symbols
r display/set register
l list (disassemble) memory
bt stack backtrace
Shell
h on-line help
help on-line help
? on-line help
sh command shell
vers print version info
eval evaluate and print result
stty set tty options
plvl Set the debug print level
hi display command history
about about PMON2000
Network
ifaddr Configure Network Interface
defflash Program DEFAULT BootLoader image from Compact Flash or Ethernet
altflash Program ALTERNATE BootStrap image from Compact Flash or Ethernet
ping ping remote host
Memory
map show memory map
m modify memory
d display memory
compare compare memory to memory
copy copy memory to memory
fill fill memory
search search memory
mt tests all available memory up to 2GB using 64 bit physical addresses
Device
update Update Boot Flash Code
Environment
env display variable
set display/set variable
unset unset variable(s)
eset edit variable
Compact Flash
cfopen open a file on the CF
cfclose close a file on the CF
cfread read <n> bytes from CF file
dir list contents of CF directory
cd change working CF directory
pwd print working CF directory
Download
configip configure the bootloader ip address
download download an image
CF
By franchuk1982
Нужно 4 салазки 3.5 к HP DL 180 G6 срочно (можно и к G7), рассмотрю все варианты.
актуально две недели
жду предложений
