Продам APC Smart-UPS RT 5000VA RM RM 230V
Продам источник бесперебойного питания
RM 230V. Куплен в 2008г. Цена 10000грн Киев. т.0664715392,0967722044
Output
Output Power Capacity 4000 Watts / 5000 VA
Max Configurable Power 4000 Watts / 5000 VA
Nominal Output Voltage 120V/208V
Output Voltage Note Configurable for 208 or 240 nominal output voltage
Efficiency at Full Load 90.00%
Output Voltage Distortion Less than 5%
Output Frequency (sync to mains) 50/60 Hz +/- 3 Hz user adjustable +/- 0.1
Crest Factor 3 : 1
Waveform Type Sine wave
Output Connections
Input
Bypass Internal Bypass (Automatic and Manual)
Nominal Input Voltage 208V
Input Frequency 50/60 Hz +/- 5 Hz (auto sensing)
Input Connections conn_L6-30P_sm.gifNEMA L6-30P
Cord Length 10 feet (3.05 meters)
Input voltage range for main operations 156 - 236V
Input voltage adjustable range for mains operation 86 - 154V
Other Input Voltages 240
Batteries & Runtime
Battery Type Maintenance-free sealed Lead-Acid battery with suspended electrolyte : leakproof
Included Battery Modules 2
Typical recharge time 2.50 hour (s)
Replacement battery cartridge RBC44 RBC™ Quantity 1
Typical Backup Time at Half Load 15.1 minutes (2000 Watts)
Typical Backup Time at Full Load 4.8 minutes (4000 Watts)
Runtime Chart Smart-UPS RT
Extended Run Options APC Smart-UPS RT 5000VA RM 208V to 208/120V
Communications & Management
Interface Port(s) Smart-Slot
Pre-Installed SmartSlot™ Cards AP9616
Control panel LED status display with load and battery bar-graphs and On Line : On Battery : Replace Battery : Overload and Bypass Indicators
Audible Alarm Alarm when on battery : distinctive low battery alarm : overload continuous tone alarm
Emergency Power Off (EPO) Yes
Surge Protection and Filtering
Surge energy rating 365 Joules
Filtering Full time multi-pole noise filtering : 0.3% IEEE surge let-through : zero clamping response time : meets UL 1449
Physical
Maximum Height 5.10 inches (130 mm)
Maximum Width 17.00 inches (432 mm)
Maximum Depth 26.00 inches (660 mm)
Net Weight 127.73 lbs. (58.06 kg)
Shipping Weight 158.66 lbs. (72.12 kg)
Shipping Height 13.68 inches (347 mm)
Shipping Width 23.73 inches (603 mm)
Shipping Depth 38.60 inches (980 mm)
Color Black
Units per Pallet 6.00
Rack Height 3U
Environmental
Operating Environment 32 - 104°F (0 - 40°C)
Operating Relative Humidity 0 - 95%
Operating Elevation 0-10000 feet (0-3000 meters)
Storage Temperature 5 - 113°F (-15 - 45°C)
Storage Relative Humidity 0 - 95%
Storage Elevation 0-50000 feet (0-15000 meters)
Audible noise at 1 meter from surface of unit 55.00 dBA
Online Thermal Dissipation 1589.00 BTU/hr
Conformance
Regulatory Approvals CSA,FCC Part 15 Class A,UL 1778
Standard Warranty 2 years repair or replace
Edited by apcburito
  • bot locked this topic
Guest
    • By bossCNNP
      Куплю блок расширения SURT192XLBP для APC SURT6000XLI без батарей.
      Предложение в личку.
    • By ГрозаИнтернета
    • By artkorum
      Куплю датчики APC: затопления (NBES0301), дыма (NBES0307);
      NBES0301:
      NBES0307:
      0671281487 Артём (телеграм)
    • By Henleys
      Всім привіт, придбав б\у упс BX650CI-RS по хорошій ціні, і вирішив придбати для нього нову батарею UGC 12V 9Ah.
      Після цього вирішив провести калібровку і протестувати на працездатність. Софтом не зміг відкалібрувати його, тому вирішив його розрядити до повного виключення, і залишити на зарядці сутку.
      Після такої маніпуляції, були проведено заміри і тест роботи від батареї:
      1. Показники після механічного калібрування:
      Напруга на батареї при підключеному ДБЖ до мережі: 14.17 В
      Напруга на батареї при вимкненому ДБЖ: 13.49 В
      2. Тест на ККД:
      Вхідна потужність (від мережі): 230 Вт.
      Вихідна потужність (на навантаження): 213 Вт.
      ККД ДБЖ: 92.6%
      3. Час роботи від батареї при навантаженні 213 Вт: 3 хвилини 15 секунд (До калібрування було 3 хвилини 5 секунд)
      4. Напруга на батареї після повного вимкнення ДБЖ: 12.7 В
      Подивившись інформацію в інтернеті і запитавши в чата ДЖПТ, я зрозумів, що час повинен бути мінімум 6хв.
      Виникло таке питання, чи це низькоякісна батарея? Чи сам Упс погано відкалібрований і не просажує батарею до її мінімума?
      Хотів би почути вашу думку, хто в цьому розбирається. Дякую!
    • By fikuronima
      ДБЖ APC Smart-UPS 1500VA USB (SUA1500I)
      Діапазон вхідної напруги під час роботи від мережі  -  160-286 В.
      Потужність  -  1500 ВА
      Імпульсний захист, Дж.  -  480 Дж
      Тип архітектуриЛ  -  інійно-інтерактивні (line-interactive).
      Без акумуляторів. 4500 грн.
