ZTE C320
BARVIT
Подскажите, как отключть NetBIOS на данной голове если это возможно?
И та же история в длинках, как зарубить этот протокол чтоб юзера друг друга в сетевом окружении не видели?
Відредаговано BARVIT
Имхо курить мануал насчет ACL
Configuring Standard ACL
Short Description Perform this procedure to configure standard ACL and apply it to
port.
Prerequisites � Make sure that the network device works normally.
� Log in to the ZXA10 through HyperTerminal or Telnet.
Context In a standard ACL, rules are defined on the basis of source IP
address only.
To configure the standard ACL, perform the following steps:
Steps 1. Use the configure terminal command to enter global configuration
mode.
2. Use the time-range command to configure ACL time range.
3. Use the acl standard command to configure standard ACL.
The standard ACL number range: 1 – 99.
4. Use the rule command to configure ACL rule.
Note:
� Each standard ACL supports maximum 127 rules.
� The time range must be configured before it is applied in a
rule. If time-range is not configured, the rule always takes
effect.
5. Use the interface command to enter interface configuration
mode.
6. Use the ip access-group command to apply ACL to port.
END OF STEPS
Example Configure a standard ACL on uplink port 0/14/1.
� Time range: 9:00 - 17:00, working day.
� Deny packets from source IP address: 168.1.1.1 0.0.0.255.
ZXAN#configure terminal
Enter configuration commands, one per line. End with CTRL/Z.
ZXAN(config)#time-range worktime 09:00:00 to 17:00:00 working-day
ZXAN(config)#acl standard number 3
ZXAN(config-std-acl)#rule 1 deny 168.1.1.1 0.0.0.255 time-range worktime
ZXAN(config-std-acl)#rule 2 permit any
ZXAN(config-std-acl)#exit
ZXAN(config)#interface gei_0/14/1
ZXAN(config-if)#ip access-group 3 in
Configuring Extended ACL
Short Description Perform this procedure to configure extended ACL and apply it to
port.
Context In an extended ACL, rules are defined on the basis of the following:
� Source IP address
� Destination IP address
� IP protocol type
� Source TCP port number
� Destination TCP port number
� Source UDP port number
Destination UDP port number
� ICMP types
� DSCP
� ICMP code
� ToS precedence
To configure the extended ACL, perform the following steps:
mode.
3. Use the acl extended command to configure extended ACL.
Note:
The extended ACL number range: 100 – 199.
Note:
� Each extended ACL supports maximum 127 rules.
effect.
mode.
END OF STEPS
Example Configure an extended ACL on uplink port 0/14/1:
Deny TCP packets from source IP address 168.1.1.1 0.0.0.255 and
source port 23 (Telnet).
ZXAN(config)#acl extend number 101
ZXAN(config-ext-acl)#rule 1 deny tcp 192.168.1.0 0.0.0.255 eq telnet any
ZXAN(config-ext-acl)#rule 2 permit any
ZXAN(config-ext-acl)#exit
ZXAN(config-if)#ip access-group 101 in
Насчет блокирования 137, 138, 139 порта ...
Ну или "заворачивать" каждого абона в отдельный Vlan, что ИМХО - правильней будет
ЗЫ: Это если я вообще правильно понял постановку вопроса ...
    • Від prototip
      Продам б/в у гарному стані OLT ZTE C320 + PRAM +SMXA/3 (10g).
      Ціна девайсу - 1200 уе.
      Можливо щось добавити і щось прибрати з шассі за бажанням з відповідною корекцією ціни.
    • Від meritonis
      Hi everyone, I hope you are well.
      I need some OID and Mibs for these parameters like in this photo?
      If anyone has them, if possible, please send them to me, even if there is any OID for ZTE OLT?
      Thanks for all.
    • Від AcNSX
      Кто-то включал с C600 серии другой ОЛТ? Как можно настроить qinq на xgei портах?
    • Від ubiquiti2024
      Продам Блок живлення ZTE PSU-AC 48V 30A
      Підходить для C300 ,C320,C220
      Стан новий.
      ціна 11000 грн.
    • Від agizor
      Вітаю.
      Стикнувся з проблемою з шасі zte c620, а самі з платою EFTL.
      Проблема - онушки реєструються але нет не біжить, і маків не бачить, і якось дивно бо через одну, одна працює, а друга ні, хоча моделі одинакові.
      з ZTE раніше не працював, інфи в інтернеті мало.
      Був б дуже вдячний якщо б хтось поділився конфігом для реєстрації і налаштування терміналів під EPON.
