AzgaR 0 Опубликовано: 2015-09-01 06:29:49 Share Опубликовано: 2015-09-01 06:29:49 День добрый всем! Помогите советом. Сегодня ночью по какой то причине выключился сервак log stargazera пишет root@billing:~ # tail -f /var/log/stargazer.log 2015-09-01 11:46:50 -- Traffcounter started successfully. 2015-09-01 11:46:50 -- Module: 'Stg configurator v.0.08'. Start successfull. 2015-09-01 11:46:50 -- Module: 'Always Online authorizator v.1.0'. Start successfull. 2015-09-01 11:46:50 -- Module: 'InetAccess authorization plugin v.1.4'. Start successfull. 2015-09-01 11:46:50 -- Module: 'CAP_NF v. 0.4'. Start successfull. 2015-09-01 11:46:50 -- Stg started successfully. 2015-09-01 11:46:50 -- +++++++++++++++++++++++++++++++++++++++++++++ 2015-09-01 11:49:31 -- DOTCONF++: file 'status/stargazer.conf': realpath('status/stargazer.conf') failed: No such file or directory 2015-09-01 11:49:31 -- ReadSettings error. Cannot read file status/stargazer.conf Кто такой status/stargazer.conf понять не могу в web Unable to connect to database server! Warning: Cannot modify header information - headers already sent by (output started at /usr/local/www/apache22/data/billing/api/libs/api.mysql.php:72) in /usr/local/www/apache22/data/billing/index.php on line 38 Warning: Cannot modify header information - headers already sent by (output started at /usr/local/www/apache22/data/billing/api/libs/api.mysql.php:72) in /usr/local/www/apache22/data/billing/index.php on line 39 Warning: Cannot modify header information - headers already sent by (output started at /usr/local/www/apache22/data/billing/api/libs/api.mysql.php:72) in /usr/local/www/apache22/data/billing/index.php on line 40 Warning: Cannot modify header information - headers already sent by (output started at /usr/local/www/apache22/data/billing/api/libs/api.mysql.php:72) in /usr/local/www/apache22/data/billing/index.php on line 41 wrong data input: SELECT COUNT(`id`) from `ticketing` WHERE `to` IS NULL AND `replyid` IS NULL AND `status`='0' ORDER BY `date` DESC хотя к базам с паролем подцепиться удается Ссылка на сообщение Поделиться на других сайтах
felixio_01 8 Опубликовано: 2015-09-01 06:49:55 Share Опубликовано: 2015-09-01 06:49:55 (изменено) Файл stargazer.conf по идее должен находиться в /etc/stargazer/ во всяком случае в Debian. Ошибки web скорее всего потому что нет конфиг файла (или данные в нём не корректны, или не получается его прочитать) в котором прописаны данные для подключения к базе. (mysql.ini) Изменено 2015-09-01 06:50:35 пользователем felixio_01 Ссылка на сообщение Поделиться на других сайтах
felixio_01 8 Опубликовано: 2015-09-01 06:57:42 Share Опубликовано: 2015-09-01 06:57:42 У Вас жёсткий диск случаем не сыпется? Ссылка на сообщение Поделиться на других сайтах
AzgaR 0 Опубликовано: 2015-09-01 07:09:31 Автор Share Опубликовано: 2015-09-01 07:09:31 разобрался, всем спасибо. ломанули походу биллинг ночью( Ссылка на сообщение Поделиться на других сайтах
skybetik 134 Опубликовано: 2015-09-01 10:21:15 Share Опубликовано: 2015-09-01 10:21:15 Ссылка на сообщение Поделиться на других сайтах
SVD 6 Опубликовано: 2015-09-01 11:09:37 Share Опубликовано: 2015-09-01 11:09:37 разобрался, всем спасибо. ломанули походу биллинг ночью( Интересно кудой и как ? Может поделитесь для опыта? Ссылка на сообщение Поделиться на других сайтах
nightfly 1 253 Опубликовано: 2015-09-01 11:48:49 Share Опубликовано: 2015-09-01 11:48:49 Ссылка на сообщение Поделиться на других сайтах
mgo 20 Опубликовано: 2015-09-01 11:54:34 Share Опубликовано: 2015-09-01 11:54:34 у мене права на файлах злітали і таблички крашились в мускулі коли кондюри подулися в БЖ теж думав ламанули xD)) перепаяв кондюри, полагодив таблички і права поправив уже третій рік сапає дальше Ссылка на сообщение Поделиться на других сайтах
nightfly 1 253 Опубликовано: 2015-09-01 12:04:41 Share Опубликовано: 2015-09-01 12:04:41 таблички крашились в мускулі коли кондюри подулися в БЖ Внєзапні хакєри с паяльнікакамі! Ссылка на сообщение Поделиться на других сайтах
Scrol 1 Опубликовано: 2015-09-06 10:44:08 Share Опубликовано: 2015-09-06 10:44:08 День добрый. Переношу биллинг на другое железо. После установки ос, самого биллинга, загрузки дампа рабочей базы, stargazer не запускается - пишет в логах: 1. Не могу прочитать тариф хххх 2.не могу прочитать тариф хххх. parameter period 3. не могу прочитать пользователя уууу. тариф ззз не существует и под конец:.USERS: Error: Cannot read users! само собой база рабочая Ссылка на сообщение Поделиться на других сайтах
l1ght 377 Опубликовано: 2015-09-06 11:40:45 Share Опубликовано: 2015-09-06 11:40:45 (изменено) всё просто, используется более новая версия старгейзера, который ожидает увидеть в тарифах период месяц или день добавте колонку Period и значение поставте ей monthпросто тупо редактором откройте ваш дамп и добавте Изменено 2015-09-06 11:42:32 пользователем L1ght Ссылка на сообщение Поделиться на других сайтах
madf 279 Опубликовано: 2015-09-07 05:16:07 Share Опубликовано: 2015-09-07 05:16:07 День добрый. Переношу биллинг на другое железо. После установки ос, самого биллинга, загрузки дампа рабочей базы, stargazer не запускается - пишет в логах: 1. Не могу прочитать тариф хххх 2.не могу прочитать тариф хххх. parameter period 3. не могу прочитать пользователя уууу. тариф ззз не существует и под конец:.USERS: Error: Cannot read users! само собой база рабочая Что за база? Ссылка на сообщение Поделиться на других сайтах
Scrol 1 Опубликовано: 2015-09-07 05:49:14 Share Опубликовано: 2015-09-07 05:49:14 День добрый. Переношу биллинг на другое железо. После установки ос, самого биллинга, загрузки дампа рабочей базы, stargazer не запускается - пишет в логах: 1. Не могу прочитать тариф хххх 2.не могу прочитать тариф хххх. parameter period 3. не могу прочитать пользователя уууу. тариф ззз не существует и под конец:.USERS: Error: Cannot read users! само собой база рабочая Что за база? Дамп базы Ubilling - сори не указал Ссылка на сообщение Поделиться на других сайтах
l1ght 377 Опубликовано: 2015-09-07 07:49:31 Share Опубликовано: 2015-09-07 07:49:31 ну я больше чем увренн, что раньше был 2.408 а щас в /var/log/stargazer.log можно обнаружить -- Stg v. 2.409 Ссылка на сообщение Поделиться на других сайтах
Scrol 1 Опубликовано: 2015-09-07 19:34:56 Share Опубликовано: 2015-09-07 19:34:56 (изменено) ну я больше чем увренн, что раньше был 2.408 а щас в /var/log/stargazer.log можно обнаружить -- Stg v. 2.409 Да спасибо за подсказку все именно так и обстоит. Ввел в SQL консоли в ubilling-e: ALTER TABLE tariffs ADD `period` varchar(32) NOT NULL DEFAULT 'month', перед запуском старгейзера и он стартонул. Изменено 2015-09-07 20:37:01 пользователем Scrol Ссылка на сообщение Поделиться на других сайтах
Endr93 0 Опубликовано: 2016-09-08 17:49:50 Share Опубликовано: 2016-09-08 17:49:50 (изменено) Здравствуйте, проблема такого характера.. ..немного предыстории..вчера запустили вновь биллинг (на сервере nas материнка полетела, временно с биллинга брали железо), сходу снял бекап, бекап был полный, ( на данный момент 148 Mb, но не суть), сегодня, после корректировки балансов абонентов, так как дней 5 не учитывалось, снял актуальный бекап с "поправками балансов" и на мое удивление файл был крошечный, каких-то 784 b, после прочтения данной темы, проверил ... /var/log/stargazer.log .....на всей протяжении жизни было Stg v. 2.409 , в терминале в процессах (ps aux) нечего похожего на него не видно (не в курсе как выглядит процесс stargazer'a), в интерфейсе ошибок нет.как можно починить? root@Ubilling:~ # ps aux USER PID %CPU %MEM VSZ RSS TT STAT STARTED TIME COMMAND root 11 198.8 0.0 0 16 ?? RL 11:01PM 5:04.35 [idle] root 1221 1.1 0.9 35656 19388 ?? S 11:04PM 0:00.14 /usr/local/bin/php root 1063 0.2 0.5 35320 9480 ?? Ss 11:02PM 0:01.07 /usr/sbin/stargazer root 0 0.0 0.0 0 88 ?? DLs 11:01PM 0:00.89 [kernel] ... или похоже запущен, но не работает адекватно.., как исправить??... заранее спасибо Изменено 2016-09-08 18:30:52 пользователем Endr93 Ссылка на сообщение Поделиться на других сайтах
madf 279 Опубликовано: 2016-09-08 18:48:03 Share Опубликовано: 2016-09-08 18:48:03 или похоже запущен, но не работает адекватно.., как исправить??... заранее спасибоЕсли честно, из вашего объяснения ничего не понял. Какой бекап, что маленькое, при чем тут лог, почему вы пишете что в списке процессов ничего не видно хотя в приведеном вами листинге процесс есть, и почему вы считаете что stg у вас работает неадекватно? Ссылка на сообщение Поделиться на других сайтах
Endr93 0 Опубликовано: 2016-09-08 19:03:49 Share Опубликовано: 2016-09-08 19:03:49 (изменено) Если честно, из вашего объяснения ничего не понял. Какой бекап, что маленькое, при чем тут лог, почему вы пишете что в списке процессов ничего не видно хотя в приведеном вами листинге процесс есть, и почему вы считаете что stg у вас работает неадекватно? действительно работает значит.., сначало так подкмал, не сразу заметил процесс его , бекап не делается, файл бекапа ничтожно мал, отсутствуют таблички.. -- MySQL dump 10.13 Distrib 5.1.73, for portbld-freebsd9.3 (i386) -- -- Host: localhost Database: stg -- ------------------------------------------------------ -- Server version 5.1.73 /*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */; /*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */; /*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */; /*!40101 SET NAMES utf8 */; /*!40103 SET @OLD_TIME_ZONE=@@TIME_ZONE */; /*!40103 SET TIME_ZONE='+00:00' */; /*!40014 SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0 */; /*!40014 SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0 */; /*!40101 SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='NO_AUTO_VALUE_ON_ZERO' */; /*!40111 SET @OLD_SQL_NOTES=@@SQL_NOTES, SQL_NOTES=0 */; и все Изменено 2016-09-08 19:12:29 пользователем Endr93 Ссылка на сообщение Поделиться на других сайтах
zaza12 2 Опубликовано: 2016-09-08 21:22:32 Share Опубликовано: 2016-09-08 21:22:32 (изменено) mysql -u root -p stg -e "SHOW TABLES" ??? Изменено 2016-09-08 21:28:54 пользователем zaza12 Ссылка на сообщение Поделиться на других сайтах
Endr93 0 Опубликовано: 2016-09-09 08:07:22 Share Опубликовано: 2016-09-09 08:07:22 mysql -u root -p stg -e "SHOW TABLES" ??? Решено уже, вроде. Ссылка на сообщение Поделиться на других сайтах
