LEAF Linux вопрос по vlan
День добрый!
На тестовом стенде установил LEAF.
Поднять  vlan не получается.
/etc/networks/interfaces:
# /etc/network/interfaces -- configuration file for LEAF network
# this file was generated by interfaces.cgi
# Loopback interface.
auto lo
iface lo inet loopback
# eth1 / Fixed IP
auto eth1
iface eth1 inet static
        address 172.16.0.3
        netmask 255.255.252.0
        gateway 172.16.0.1
# eth2 / Fixed IP
auto eth2
iface eth2 inet static
        address 10.172.16.3
        netmask 255.255.255.0
# vlan2
auto eth1.2
iface eth1.2 inet static
        address 10.172.10.3
        broadcast 10.172.10.255
        vlan_raw_device eth1
        set_name_type VLAN_PLUS_VID_NO_PAD
# end of generated interface file
Достучаться до eth1.2 - невозможно.
Секцию eth1 -  ремил - не влияет на результат
Версия сборки 5.2.3 x64
Может кто-то обяснит причину?
gw2# ip -d link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 promiscuity 0 addrgenm ode eui64
2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN mode DEFAULT group d efault
link/ether 26:da:44:9e:15:e5 brd ff:ff:ff:ff:ff:ff promiscuity 0
dummy addrgenmode eui64
3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 00:13:8f:d9:2d:a0 brd ff:ff:ff:ff:ff:ff promiscuity 0 addrgenmode eui64
4: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAU LT group default qlen 1000
link/ether 00:10:18:0a:d9:c2 brd ff:ff:ff:ff:ff:ff promiscuity 0 addrgenmode eui64
5: eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode D EFAULT group default qlen 1000
link/ether 00:10:18:0a:d9:c3 brd ff:ff:ff:ff:ff:ff promiscuity 0 addrgenmode eui64
6: ifb0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN mode DEFAULT group def ault qlen 32
link/ether 66:59:fb:09:db:ff brd ff:ff:ff:ff:ff:ff promiscuity 0
ifb addrgenmode eui64
7: ifb1: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN mode DEFAULT group def ault qlen 32
link/ether 0a:d2:8e:1a:5f:1a brd ff:ff:ff:ff:ff:ff promiscuity 0
8: eth1.2@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast stat e UP mode DEFAULT group default qlen 1000
vlan protocol 802.1Q id 2 <REORDER_HDR> addrgenmode eui64
gw2# ip -d addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default
dummy
3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
4: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
inet 172.16.0.3/22 scope global eth1
inet6 2002:5beb:e1be:b:210:18ff:fe0a:d9c2/64 scope global mngtmpaddr dynamic
valid_lft 2591749sec preferred_lft 604549sec
inet6 2002:5beb:e128:b:210:18ff:fe0a:d9c2/64 scope global mngtmpaddr dynamic
valid_lft 2585631sec preferred_lft 598431sec
inet6 fec0::b:210:18ff:fe0a:d9c2/64 scope site mngtmpaddr dynamic
inet6 fe80::210:18ff:fe0a:d9c2/64 scope link
5: eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
inet 10.172.16.3/24 scope global eth2
inet6 2002:5beb:e128:b:210:18ff:fe0a:d9c3/64 scope global mngtmpaddr dynamic
valid_lft 2580810sec preferred_lft 593610sec
inet6 fec0::b:210:18ff:fe0a:d9c3/64 scope site mngtmpaddr dynamic
inet6 fe80::210:18ff:fe0a:d9c3/64 scope link
6: ifb0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 32
ifb
7: ifb1: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 32
ifb
8: eth1.2@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
inet 10.172.10.3/24 brd 10.172.10.255 scope global eth1.2
ну вот он....
на комутаторе или что там перед ним все настроено верно ?
На коммутаторе порт гибридный, 2 влан тегом на нем.
Любой другой свитч или сервак работает нормально
ну хз....   что за сетевая ?
Можно не указывать при конструкции iface eth0.2 ... дебиан/убунта и т.п. сами умеют поднимать.
по сути вопроса - арпы в данном вилане видны?
есть подозрение что сетевуха/дрова тупо не умеет виланы.
для начала подкиньте сетевуху которая уммет виланы.
п.с. есть 2 вида сетевух - Интел и все остальное.
Edited by BUM
Броадком двухголовый, кстати с eth2  тоже нормально не работает, может проблемма в действительно в сетевухе?
с бродкомом могут быть проблемы с фирмварем
там не только вланы не будут бегать - там просто карточка нормально не функционирует
Edited by Lynx100
Что-то я про сетевки броадком с нерабочим фирмварем слышал, был недавно такой факап у производителей серверов. Обновите, там ничего сложного.
подгрузил:
gw2# lshw | grep tg
 configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.137 duplex=full firmware=5704-v3.19 ip=172.16.0.3 latency=32 link=yes mingnt=64 multicast=yes port=twisted pair speed=100Mbit/s
 configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.137 firmware=5704-v3.19 ip=10.172.16.3 latency=32 link=no mingnt=64 multicast=yes port=twisted pair
судя из driverversion=3.137 - подгружены последние драйвера, новее даже на сайте нет.
eth1.2    Link encap:Ethernet  HWaddr 00:10:18:0A:D9:C2
          inet addr:10.172.10.3  Bcast:10.172.10.255  Mask:255.255.255.0
          inet6 addr: fe80::210:18ff:fe0a:d9c2/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:290 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:13608 (13.2 KiB)  TX bytes:648 (648.0
вывод по ip -d addr:
вывод по ip -d link:
8: eth1.2@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
а все то-же:
gw2# ping 10.172.10.1
PING 10.172.10.1 (10.172.10.1): 56 data bytes
ping: sendto: Operation not permitted
придется менять сетевую
    • By Чучундра
      Добрий день.
    • By olapchuk
      Вечір добрий
      як влан створити, видалити і переімінувати розібрався через snmp, якщо комусь цікаво тут написано https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/45080-vlans.html, якщо треба приклади скину
      але проблема в наступному, в ціско всі знають є таке штука яка interface vlan **id**
      interface Vlan3**
        no shutdown
        ip address 192.168.***.***/27
    • By ibrokeit
      Вітаю!
      Зіштовхнулися з проблемою із вланами на ZTE C300 (2.1.0) GTGHK.
      Загалом все працює нормально, але в окремих вланах просто перестає бігати трафіг, на ону відстутні мак-адреси, хоча статус порта full-1000.
      Якщо із таким же конфігом перевести ону в інший влан — все починає працювати (до певного часу). Виглядає так, що спрацьовує якесь блокування по номеру влану на рівні spanning-tree або детектора кілець (перше відключено, інше, якщо відключати — ситуацію не міняє).
      Чи може хтось підказати в якому напрямі копати рішення проблеми?
      Дякую
    • By Georgianairlink
    • By subhan
      У нас есть сервер Ubilling. к которому соединены 5 брасов. Каждый Nas работает по отдельному влану. В вланах браса в определенное время мы видим пустой трафик который поднимается. Например в норме если 200мб то 500мб. В влане котором видится пустое поднятие трафика, также и поднимается трафик во всех портах свитча. Это исправляется на время только при ребуте определенного Nas. Проблема раньше была только в одном Nas-э, щас и на других Nas-ах тоже данная проблема. Это проблема только наблюдается во вланах которые подключены в Ubilling.
      Можете пожалуйста, помочь в данной проблеме.
