Ubling на VB
Добрый вечер.
Не получилось поставить на KVM. поставил на VB, ось 10.2, Ubilling + NAS на одной машинке.
Установил стандартно  UBinstallerом. Далее перешел к FreeRadius http://wiki.ubilling.net.ua/doku.php?id=freeradius
На пункте Как проверить все ли хорошо? все плохо.
В отладочном режиме проверка на тест пользователя
Sending Access-Request of id 175 to 127.0.0.1 port 1812
        User-Name = "testlogin"
        User-Password = "testpassword"
        NAS-IP-Address = 127.0.0.1
        NAS-Port = 0
        Message-Authenticator = 0x00000000000000000000000000000000
rad_recv: Access-Reject packet from host 127.0.0.1 port 1812, id=175, length=20
Listening on authentication address * port 1812
Listening on accounting address * port 1813
Listening on command file /var/run/radiusd/radiusd.sock
Listening on authentication address 127.0.0.1 port 18120 as server inner-tunnel
Listening on proxy address * port 1814
Ready to process requests.
rad_recv: Access-Request packet from host 127.0.0.1 port 10071, id=200, length=79
        NAS-Port = 0
        Message-Authenticator = 0xb4d3efa2edb7f854ced1b269796704c6
# Executing section authorize from file /usr/local/etc/raddb/sites-enabled/default
+group authorize {
++[preprocess] = ok
++[chap] = noop
++[mschap] = noop
++[digest] = noop
[eap] No EAP-Message, not doing EAP
++[eap] = noop
[sql]   expand: %{User-Name} -> testlogin
[sql] sql_set_user escaped user --> 'testlogin'
rlm_sql (sql): Reserving sql socket id: 3
[sql]   expand: SELECT (@cnt := @cnt + 1) AS `id`, `UserName`, `Attribute`, `Value`, `op`           FROM `radius_check`           CROSS JOIN (SELECT @cnt := 0) AS `dummy`           WHERE `UserName` = '%{SQL-User-Name}'           ORDER BY `id` -> SELECT (@cnt := @cnt + 1) AS `id`, `UserName`, `Attribute`, `Value`, `op`           FROM `radius_check`           CROSS JOIN (SELECT @cnt := 0) AS `dummy`           WHERE `UserName` = 'testlogin'           ORDER BY `id`
[sql]   expand: SELECT `GroupName`           FROM `radius_usergroup`           WHERE `UserName` = '%{SQL-User-Name}'           ORDER BY `priority` -> SELECT `GroupName`           FROM `radius_usergroup`           WHERE `UserName` = 'testlogin'           ORDER BY `priority`
rlm_sql (sql): Released sql socket id: 3
[sql] User testlogin not found
++[sql] = notfound
++[expiration] = noop
++[logintime] = noop
[pap] WARNING! No "known good" password found for the user.  Authentication may fail because of this.
++[pap] = noop
+} # group authorize = ok
ERROR: No authenticate method (Auth-Type) found for the request: Rejecting the user
Failed to authenticate the user.
Login incorrect: [testlogin/testpassword] (from client Local NAS port 0)
Using Post-Auth-Type Reject
# Executing group from file /usr/local/etc/raddb/sites-enabled/default
+group REJECT {
[attr_filter.access_reject]     expand: %{User-Name} -> testlogin
attr_filter: Matched entry DEFAULT at line 11
++[attr_filter.access_reject] = updated
+} # group REJECT = updated
Delaying reject of request 0 for 1 seconds
Going to the next request
Waking up in 0.9 seconds.
Sending delayed reject for request 0
Sending Access-Reject of id 200 to 127.0.0.1 port 10071
Waking up in 4.9 seconds.
Cleaning up request 0 ID 200 with timestamp +4
Все по инструкции, не отступал ни на шаг. В чем косяк?
Проверьте порты. На каком слушает и на какой стучитесь. А вообще ошибка логина или пароля
Відредаговано Golthana
Очевидно не все.  Там все вообще работает из коробки и строиться за 10 минут.
по Вашему видео завел, спс
по документации тестовый пользователь не работает
    • Від camchatix
      Добрий день,
    • Від grach_witch_cheese
      Вітаю, колеги!
      Маю наступну схему:
      Питання:
    • Від nightfly
      Зміни в структурі БД. alter.ini: нова опція FASTPROFITCALC_ENABLED, що вмикає швидкий підрахунок прибутку. alter.ini: нова необов'язкова опція KARMA_IN_PROFILE що вмикає показ карми в профілі користувача. alter.ini: нова опція SWITCHES_AUTH_ENABLED, що вмикає довідник даних авторизації пристроїв. alter.ini: нова опція PON_SCRIPTS_ENABLED, що вмикає підтримку скриптів OLT в ПОНізаторі. alter.ini: нова опція PON_ONU_FDB_SELFFILTER, що вмикає фільтр MAC-ів при відображенні FDB за ONU. alter.ini: нова опція USERBYIP_ENABLED, що вмикає виклик userbyip в RemoteAPI. alter.ini: пачка нових опцій PB_FASTURL_*, що керують поведінкою модулю відсилання коротких посилань на оплату. Модуль PONizer: виправлена помилка зникнення PON інтерфейсів при опиті BDCOM GP3600 Модуль “Профіль користувача”: для опису плагінів профілю та оверлеїв на кшталт “чорної магії” тепер опційно можливо вказувати link_target. Модуль “Панель задач”: для опису елементів панелі задач, тепер опційно можна вказувати LINK_TARGET. Модуль Записи телефонних розмов: вирішено проблеми швидкодії, при перегляді списку записів дзвінків. Модуль “Записи телефонних розмов”: більше не призводить до вичерпання пам'яті процесу, при перегляді великих архівів дзвінків. Модуль “Записи телефонних розмов”: новий аудіо-плеєр для прослуховування записів з візуалізацією аудіо-хвилі. Модуль “Пошук оплат”: реалізовано можливість швиденького підрахунку прибутку по обраних чекбоксами платежах. Модуль УКВ: реалізовано можливість швиденького підрахунку прибутку по обраних чекбоксами платежах. Модулі Мапа обладнання та користувачів: трішки вичищено код. Ліпше не стало. Модуль “Мапа будинків”: поле пошуку при розташуванні будинку, тепер попередньо заповнено локацією, при переході за посиланням “розташувати на мапі”. Модуль “Панель задач”: опція TB_QUICKSEARCH_INLINE змінила свою поведінку, та може тепер приймати значення 0|1|2. Модуль “Звіт по трафіку”: виправлено проблему відображення графіків OphanimFlow для NAS на роздільних здатностях менше ніж FullHD. Кабінет користувача: в модулі “Відеоспостереження” відображення попереднього перегляду каналів користувача, стало трішки притомнішим. Сховище зображень: трішки покращено поведінку форми завантаження. RemoteAPI: новий виклик onusigcompressor, що радикально стискає розпухаючі дані історії сигналів ONU. RemoteAPI: новий виклик pbxmonrefill, що оновлює кеш записів телефонних розмов. RemoteAPI: новий виклик userbyip, що повертає дані про користувача за його IP. OpenPayz: в бекенді та фронтенді platon виправлено проблему диких заокруглень, при вказанні зовнішньої комісії.
      Повний чейнджлог
      Оновлена демка
    • Від ppv
      та
    • Від mac
      olt - bdcom gepon.
