kvirtu 315 Опубликовано: 2016-09-04 14:40:59 Share Опубликовано: 2016-09-04 14:40:59 (изменено) Появилась необходимость смотреть остаток на счету на модеме Е1550.Все что нашел это скрипт под фрю: #!/usr/bin/perluse Getopt::Std;# defaults$opt_i = "/dev/cuaU0.1";my $USAGE = <<__EOU;Usage: $0 [-i input_port] [-o output_port] [-n] [-h] [-v] ussd_msgDescription:Send and receive 7-bit PDU-encoded USSD messages.Written and tested to work for (just mine) Huawei E1550 GSM/UMTS USB modem.Options:-i port Port to send and receive data from. Default: $opt_i-n Do not send any data to port. Useful with -v.-h Print this help.-v Be verbose.__EOUsub HELP_MESSAGE {print "$USAGE\n"; exit;}sub VERSION_MESSAGE {};getopts ('i:hnv');HELP_MESSAGE() and exit if (! $ARGV[0]) or defined($opt);print "USSD MSG: $ARGV[0]\n" if $opt_v;my $ussd_req = encode_text($ARGV[0]);print "PDU ENCODED: $ussd_req\n" if $opt_v;my $ussd_reply;if (! $opt_n) {open (PORT, '+<', $opt_i) or die "Can't open '$opt_o': $!\n";print PORT 'AT+CUSD=1,',$ussd_req,",15\r\n";print "Waiting for USSD reply...\n" if $opt_v;while (<PORT>) {chomp;die "USSD ERROR\n" if $_ eq "+CUSD: 2";if (/^\+CUSD: 0,\"([A-F0-9]+)\"/) {$ussd_reply = $1;print "PDU USSD REPLY: $ussd_reply\n" if $opt_v;last;}print "Got unknown USSD message: $_\n" if /^\+CUSD:/ and $opt_v;}close(PORT);}if ($ussd_reply) {$decoded_ussd_reply = decode_text($ussd_reply);print STDOUT "USSD REPLY: $decoded_ussd_reply\n";}else {print "No USSD reply!\n";}sub encode_text {my $text = shift;my $i;my @a = split(//,unpack("b*",$text));for ($i=7; $i < $#a; $i+=8) {$a[$i]="";}my $return = uc(unpack("H*", pack("b*", join("", @a))));return $return;}sub decode_text {my $text = shift;my $i;my @a = split(//,unpack("b*", pack("H*",$text)));for ($i=6; $i < $#a; $i+=7) {$a[$i].="0";}my $return = pack("b*", join("", @a));return $return;} Но скрипт не пашет как надо: ./test.pl -v "*111#" USSD MSG: *111#PDU ENCODED: AA582C3602Waiting for USSD reply...No USSD reply! Изменено 2016-09-05 12:04:37 пользователем kvirtu Ссылка на сообщение Поделиться на других сайтах
N.Leiten 89 Опубликовано: 2016-09-04 21:30:37 Share Опубликовано: 2016-09-04 21:30:37 Скрипт кривой. Большинство модемов нормально принимает 8битовые стандартные ASCII кодировки, а вот возвращать могут уже или в ASCII или в спец. кодировке. Последнее сделано для поддержки интернационализации (ту же кирилицу выводить, хотя часто наши всё-равно транслитом пишут). Попробуй для начала выполнить AT-команду в терминале и посмотреть выхлоп. AT+CUSD=1,*111#,15 Ссылка на сообщение Поделиться на других сайтах
Ajar 94 Опубликовано: 2016-09-05 04:26:28 Share Опубликовано: 2016-09-05 04:26:28 а команда AT+CSCS= влияет формат текстовых сообщений? Ссылка на сообщение Поделиться на других сайтах
kvirtu 315 Опубликовано: 2016-09-05 07:14:04 Автор Share Опубликовано: 2016-09-05 07:14:04 Скрипт кривой. Большинство модемов нормально принимает 8битовые стандартные ASCII кодировки, а вот возвращать могут уже или в ASCII или в спец. кодировке. Последнее сделано для поддержки интернационализации (ту же кирилицу выводить, хотя часто наши всё-равно транслитом пишут). Попробуй для начала выполнить AT-команду в терминале и посмотреть выхлоп. AT+CUSD=1,*111#,15 входил в терминал через SSH , командой cu -l /dev/cuaU0.0 . Не смог ввести в нем ни одной команды и выйти не смог. Пришлось тушить USB-порт, потом заново его включать, что бы передернуть модем. Ссылка на сообщение Поделиться на других сайтах
N.Leiten 89 Опубликовано: 2016-09-05 08:48:45 Share Опубликовано: 2016-09-05 08:48:45 Скрипт кривой. Большинство модемов нормально принимает 8битовые стандартные ASCII кодировки, а вот возвращать могут уже или в ASCII или в спец. кодировке. Последнее сделано для поддержки интернационализации (ту же кирилицу выводить, хотя часто наши всё-равно транслитом пишут). Попробуй для начала выполнить AT-команду в терминале и посмотреть выхлоп. AT+CUSD=1,*111#,15 входил в терминал через SSH , командой cu -l /dev/cuaU0.0 . Не смог ввести в нем ни одной команды и выйти не смог. Пришлось тушить USB-порт, потом заново его включать, что бы передернуть модем. А в /dev/ только один COM-порт появляется? Обычно 3G модемы в системе три интерфейса выводят, один для данных, один для управления AT-командами и ещё один служебный. Не знаю, как во FreeBSD, но в линухах именно так. Поэтому приходится ещё играться с номером интерфейса (подбирать его). Ссылка на сообщение Поделиться на других сайтах
kvirtu 315 Опубликовано: 2016-09-05 09:11:01 Автор Share Опубликовано: 2016-09-05 09:11:01 Скрипт кривой. Большинство модемов нормально принимает 8битовые стандартные ASCII кодировки, а вот возвращать могут уже или в ASCII или в спец. кодировке. Последнее сделано для поддержки интернационализации (ту же кирилицу выводить, хотя часто наши всё-равно транслитом пишут). Попробуй для начала выполнить AT-команду в терминале и посмотреть выхлоп. AT+CUSD=1,*111#,15 входил в терминал через SSH , командой cu -l /dev/cuaU0.0 . Не смог ввести в нем ни одной команды и выйти не смог. Пришлось тушить USB-порт, потом заново его включать, что бы передернуть модем. А в /dev/ только один COM-порт появляется? Обычно 3G модемы в системе три интерфейса выводят, один для данных, один для управления AT-командами и ещё один служебный. Не знаю, как во FreeBSD, но в линухах именно так. Поэтому приходится ещё играться с номером интерфейса (подбирать его). спс, буду пробовать , 3 порта есть. Ссылка на сообщение Поделиться на других сайтах
hellion 4 Опубликовано: 2016-09-05 10:11:59 Share Опубликовано: 2016-09-05 10:11:59 Я например смотрел в личном кабинете оператора. Ссылка на сообщение Поделиться на других сайтах
KaYot 3 740 Опубликовано: 2016-09-05 10:27:06 Share Опубликовано: 2016-09-05 10:27:06 Я например смотрел в личном кабинете оператора. +1. Я помню тоже решал-решал подобную задачу, потом достал симку, воткнул в телефон, зарегистрировал за минуту личный кабинет и вуаля. Ссылка на сообщение Поделиться на других сайтах
kvirtu 315 Опубликовано: 2016-09-05 11:11:36 Автор Share Опубликовано: 2016-09-05 11:11:36 Скрипт кривой. Большинство модемов нормально принимает 8битовые стандартные ASCII кодировки, а вот возвращать могут уже или в ASCII или в спец. кодировке. Последнее сделано для поддержки интернационализации (ту же кирилицу выводить, хотя часто наши всё-равно транслитом пишут). Попробуй для начала выполнить AT-команду в терминале и посмотреть выхлоп. AT+CUSD=1,*111#,15 входил в терминал через SSH , командой cu -l /dev/cuaU0.0 . Не смог ввести в нем ни одной команды и выйти не смог. Пришлось тушить USB-порт, потом заново его включать, что бы передернуть модем. А в /dev/ только один COM-порт появляется? Обычно 3G модемы в системе три интерфейса выводят, один для данных, один для управления AT-командами и ещё один служебный. Не знаю, как во FreeBSD, но в линухах именно так. Поэтому приходится ещё играться с номером интерфейса (подбирать его). Спасибо , попробовал порт /dev/cuaU0.1 - все получилось через скрипт, что в моем первом посте. Ссылка на сообщение Поделиться на других сайтах
Digital_storm 68 Опубликовано: 2016-09-05 11:48:02 Share Опубликовано: 2016-09-05 11:48:02 $opt_i = "/dev/cuaU0.2"; U0.1 було? Ссылка на сообщение Поделиться на других сайтах
kvirtu 315 Опубликовано: 2016-09-05 12:04:27 Автор Share Опубликовано: 2016-09-05 12:04:27 $opt_i = "/dev/cuaU0.2"; U0.1 було? не, у меня 0.0 - порт как модем. 0.1 - для управления. щас в скрипте подправлю на 0.1 Ссылка на сообщение Поделиться на других сайтах
fet4 46 Опубликовано: 2016-09-05 16:44:30 Share Опубликовано: 2016-09-05 16:44:30 Извиняюсь за оффтоп А как на практике эти модемы работают? Какая слышимость? Стабильность? Я так понял под астерикс их держите? Ссылка на сообщение Поделиться на других сайтах
kvirtu 315 Опубликовано: 2016-09-05 18:04:49 Автор Share Опубликовано: 2016-09-05 18:04:49 Извиняюсь за оффтоп А как на практике эти модемы работают? Какая слышимость? Стабильность? Я так понял под астерикс их держите? я использую только для оповещения Ссылка на сообщение Поделиться на других сайтах
Digital_storm 68 Опубликовано: 2016-09-06 05:51:01 Share Опубликовано: 2016-09-06 05:51:01 Извиняюсь за оффтоп А как на практике эти модемы работают? Какая слышимость? Стабильность? Я так понял под астерикс их держите? Добре працюють. Хоча багато чого залежить выд прошивки. Ссылка на сообщение Поделиться на других сайтах
xspirit 15 Опубликовано: 2016-09-06 07:37:30 Share Опубликовано: 2016-09-06 07:37:30 Извиняюсь за оффтоп А как на практике эти модемы работают? Какая слышимость? Стабильность? Я так понял под астерикс их держите? под asterisk отлично работают, проблем никаких нет. Ссылка на сообщение Поделиться на других сайтах
fet4 46 Опубликовано: 2016-09-06 10:45:55 Share Опубликовано: 2016-09-06 10:45:55 Спасибо за ответы. Просто собираюсь поднять бюджетную телефонию для сети, не хотелось бы зря покупать не работающие вещи. А симки лочат под ними ? Ссылка на сообщение Поделиться на других сайтах
xspirit 15 Опубликовано: 2016-09-06 10:50:44 Share Опубликовано: 2016-09-06 10:50:44 У меня лет 6 стоят с симками КС с ними проблем нет, а вот люди в инете пишут что лайф очень быстро лочит, максимум месяца 3 симка держится, но и это не проблема можно на мопед накатить IMEI своей старенькой Nokia думаю прокатит. Ссылка на сообщение Поделиться на других сайтах
hailnora 128 Опубликовано: 2016-09-06 13:15:29 Share Опубликовано: 2016-09-06 13:15:29 У меня лет 6 стоят с симками КС с ними проблем нет, а вот люди в инете пишут что лайф очень быстро лочит, максимум месяца 3 симка держится, но и это не проблема можно на мопед накатить IMEI своей старенькой Nokia думаю прокатит. Не забудьте поделиться этой идеей с правоохранительным органами Ссылка на сообщение Поделиться на других сайтах
John_Doe 301 Опубликовано: 2016-09-06 17:22:20 Share Опубликовано: 2016-09-06 17:22:20 У меня лет 6 стоят с симками КС с ними проблем нет, а вот люди в инете пишут что лайф очень быстро лочит, максимум месяца 3 симка держится, но и это не проблема можно на мопед накатить IMEI своей старенькой Nokia думаю прокатит. Не забудьте поделиться этой идеей с правоохранительным органами И скаких пор это страшный грех которым должны заниматься органы? В любом gsm шлюзе эта возможность есть от производителя и че пересажать теперь всех владельцев шлюзов нужно? Ссылка на сообщение Поделиться на других сайтах
hailnora 128 Опубликовано: 2016-09-08 08:18:35 Share Опубликовано: 2016-09-08 08:18:35 У меня лет 6 стоят с симками КС с ними проблем нет, а вот люди в инете пишут что лайф очень быстро лочит, максимум месяца 3 симка держится, но и это не проблема можно на мопед накатить IMEI своей старенькой Nokia думаю прокатит. Не забудьте поделиться этой идеей с правоохранительным органами И скаких пор это страшный грех которым должны заниматься органы? В любом gsm шлюзе эта возможность есть от производителя и че пересажать теперь всех владельцев шлюзов нужно? Человек хочет обойти один из фильтров антифрода ОПСоСа, поменяв IMEI устройства, который может находится в черном списке ОПСоСа. Через время оператор всё же вычислит GSM-шлюз и обидится из-за упущенной прибыли, продавая услугу по тарифам предоплаты, а не контракта. В лучшем случае просто заблокируют СИМку, в худшем -- заява в органы. Далее к Вам приходят и аккуратно кладут лицом в пол. Вряд ли будут разбираться, кто что умеет: экономическое преступление и подозрение на "втручання у дияльнисть мереж" -- в лучшем случае, в худшем -- пособничество в терроризме. И Вам хорошо, и показатели раскрываемости увеличились. p.s. Шапочка из фольги на месте Ссылка на сообщение Поделиться на других сайтах
xspirit 15 Опубликовано: 2016-09-08 08:28:28 Share Опубликовано: 2016-09-08 08:28:28 можно на мопед накатить IMEI своей старенькой Nokia У вас паранойя какой черный список? Это будет волне себе валидный IMEI и никто никого лицом в пол ложить не будет, я использую его в личных целях а не терминирую забугорный голосовой трафик. Ссылка на сообщение Поделиться на других сайтах
John_Doe 301 Опубликовано: 2016-09-08 11:06:13 Share Опубликовано: 2016-09-08 11:06:13 p.s. Шапочка из фольги на месте Шапочка то на месте, похоже то что должно быть под шапочкой отсутствует Ссылка на сообщение Поделиться на других сайтах
fet4 46 Опубликовано: 2016-09-08 12:43:30 Share Опубликовано: 2016-09-08 12:43:30 А лочат по мотивам борьбы с терминацией голосового трафика? Не могу просто понять где они видят нарушение в использовании шлюза, какая разница клиент звонит на мобилу или на шлюз. Или я звоню с мобилы или со шлюза, все равно одна то линия. Ссылка на сообщение Поделиться на других сайтах
netstriker 19 Опубликовано: 2016-09-08 13:02:59 Share Опубликовано: 2016-09-08 13:02:59 У лайфа есть спец тариф для GSM шлюзов, подключил себе 1,5 года назад и не парюсь. Ссылка на сообщение Поделиться на других сайтах
xspirit 15 Опубликовано: 2016-09-16 13:03:36 Share Опубликовано: 2016-09-16 13:03:36 (изменено) Вот сегодня как-раз лайф подогнал подарок. 2016-09-16 15:50:48,5, LIFE: Signal Strength Indicator: (17,99) -79 dBm (Good) 2016-09-16 15:50:48,7, LIFE: -> AT+CREG? 2016-09-16 15:50:48,7, LIFE: Command is sent, waiting for the answer 2016-09-16 15:50:48,7, LIFE: <- +CREG: 2,3,76d9,51d9 OK 2016-09-16 15:50:48,3, LIFE: Error: registration is denied. 2016-09-16 15:50:48,2, LIFE: Modem handler 0 terminated abnormally. PID: 78276. Изменено 2016-09-16 13:03:48 пользователем xspirit Ссылка на сообщение Поделиться на других сайтах
