Помогите настроить L2TP/IPsec VPN на pfSense 2.3.2
Здравствуйте!
Помогите настроить L2TP/IPsec VPN на pfSense.
Есть свежеустановленная тестовая машина с pfSense:
2.3.2-RELEASE (i386)
 built on Tue Jul 19 13:09:39 CDT 2016
FreeBSD 10.3-RELEASE-p5
WAN IP:
62.216.xx.xx
LAN IP (DHCP - disabled):
192.168.1.5
Настраивал по мануалу
Логи pfsense:
Oct 1 02:03:13  charon   10[NET] <13> received packet: from 89.252.xx.xx[500] to 62.216.xx.xx[500] (408 bytes)
Oct 1 02:03:13  charon   10[ENC] <13> parsed ID_PROT request 0 [ SA V V V V V V V V ]
Oct 1 02:03:13  charon   10[ENC] <13> received unknown vendor ID: 01:52:8b:bb:c0:06:96:12:18:49:ab:9a:1c:5b:2a:51:00:00:00:01
Oct 1 02:03:13  charon   10[IKE] <13> received MS NT5 ISAKMPOAKLEY vendor ID
Oct 1 02:03:13  charon   10[IKE] <13> received NAT-T (RFC 3947) vendor ID
Oct 1 02:03:13  charon   10[IKE] <13> received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
Oct 1 02:03:13  charon   10[IKE] <13> received FRAGMENTATION vendor ID
Oct 1 02:03:13  charon   10[ENC] <13> received unknown vendor ID: fb:1d:e3:cd:f3:41:b7:ea:16:b7:e5:be:08:55:f1:20
Oct 1 02:03:13  charon   10[ENC] <13> received unknown vendor ID: 26:24:4d:38:ed:db:61:b3:17:2a:36:e3:d0:cf:b8:19
Oct 1 02:03:13  charon   10[ENC] <13> received unknown vendor ID: e3:a5:96:6a:76:37:9f:e7:07:22:82:31:e5:ce:86:52
Oct 1 02:03:13  charon   10[IKE] <13> 89.252.xx.xx is initiating a Main Mode IKE_SA
Oct 1 02:03:13  charon   10[ENC] <13> generating ID_PROT response 0 [ SA V V V V ]
Oct 1 02:03:13  charon   10[NET] <13> sending packet: from 62.216.xx.xx[500] to 89.252.xx.xx[500] (160 bytes)
Oct 1 02:03:13  charon   10[NET] <13> received packet: from 89.252.xx.xx[500] to 62.216.xx.xx[500] (388 bytes)
Oct 1 02:03:13  charon   10[ENC] <13> parsed ID_PROT request 0 [ KE No NAT-D NAT-D ]
Oct 1 02:03:13  charon   10[IKE] <13> remote host is behind NAT
Oct 1 02:03:13  charon   10[ENC] <13> generating ID_PROT response 0 [ KE No NAT-D NAT-D ]
Oct 1 02:03:13  charon   10[NET] <13> sending packet: from 62.216.xx.xx[500] to 89.252.xx.xx[500] (372 bytes)
Oct 1 02:03:13  charon   10[NET] <13> received packet: from 89.252.xx.xx[4500] to 62.216.xx.xx[4500] (76 bytes)
Oct 1 02:03:13  charon   10[ENC] <13> parsed ID_PROT request 0 [ ID HASH ]
Oct 1 02:03:13  charon   10[CFG] <13> looking for pre-shared key peer configs matching 62.216.xx.xx...89.252.xx.xx[192.168.5.104]
Oct 1 02:03:13  charon   10[CFG] <13> selected peer config "con1"
Oct 1 02:03:13  charon   10[IKE] <con1|13> IKE_SA con1[13] established between 62.216.xx.xx[62.216.xx.xx]...89.252.xx.xx[192.168.5.104]
Oct 1 02:03:13  charon   10[IKE] <con1|13> scheduling reauthentication in 28143s
Oct 1 02:03:13  charon   10[IKE] <con1|13> maximum IKE_SA lifetime 28683s
Oct 1 02:03:13  charon   10[IKE] <con1|13> DPD not supported by peer, disabled
Oct 1 02:03:13  charon   10[ENC] <con1|13> generating ID_PROT response 0 [ ID HASH ]
Oct 1 02:03:13  charon   10[NET] <con1|13> sending packet: from 62.216.xx.xx[4500] to 89.252.xx.xx[4500] (76 bytes)
Oct 1 02:03:13  charon   15[NET] <con1|13> received packet: from 89.252.xx.xx[4500] to 62.216.xx.xx[4500] (332 bytes)
Oct 1 02:03:13  charon   15[ENC] <con1|13> parsed QUICK_MODE request 1 [ HASH SA No ID ID NAT-OA NAT-OA ]
Oct 1 02:03:13  charon   15[IKE] <con1|13> received 250000000 lifebytes, configured 0
Oct 1 02:03:13  charon   15[ENC] <con1|13> generating QUICK_MODE response 1 [ HASH SA No ID ID NAT-OA NAT-OA ]
Oct 1 02:03:13  charon   15[NET] <con1|13> sending packet: from 62.216.xx.xx[4500] to 89.252.xx.xx[4500] (204 bytes)
Oct 1 02:03:13  charon   15[NET] <con1|13> received packet: from 89.252.xx.xx[4500] to 62.216.xx.xx[4500] (60 bytes)
Oct 1 02:03:13  charon   15[ENC] <con1|13> parsed QUICK_MODE request 1 [ HASH ]
Oct 1 02:03:13  charon   15[IKE] <con1|13> CHILD_SA con1{6} established with SPIs c1421d55_i a0ce5dca_o and TS 62.216.xx.xx/32|/0[udp/l2f] === 89.252.xx.xx/32|/0[udp/l2f]
Oct 1 02:03:48  charon   15[NET] <con1|13> received packet: from 89.252.xx.xx[4500] to 62.216.xx.xx[4500] (76 bytes)
Oct 1 02:03:48  charon   15[ENC] <con1|13> parsed INFORMATIONAL_V1 request 4256905100 [ HASH D ]
Oct 1 02:03:48  charon   15[IKE] <con1|13> received DELETE for ESP CHILD_SA with SPI a0ce5dca
Oct 1 02:03:48  charon   15[IKE] <con1|13> closing CHILD_SA con1{6} with SPIs c1421d55_i (756 bytes) a0ce5dca_o (0 bytes) and TS 62.216.xx.xx/32|/0[udp/l2f] === 89.252.xx.xx/32|/0[udp/l2f]
Oct 1 02:03:48  charon   05[NET] <con1|13> received packet: from 89.252.xx.xx[4500] to 62.216.xx.xx[4500] (92 bytes)
Oct 1 02:03:48  charon   05[ENC] <con1|13> parsed INFORMATIONAL_V1 request 3672929147 [ HASH D ]
Oct 1 02:03:48  charon   05[IKE] <con1|13> received DELETE for IKE_SA con1[13]
Oct 1 02:03:48  charon   05[IKE] <con1|13> deleting IKE_SA con1[13] between 62.216.xx.xx[62.216.xx.xx]...89.252.xx.xx[192.168.5.104]
В винде при подключении ошибка:
Не удалось установить связь по сети между компьютером и ВПН-сервером,
так как удаленный сервер не отвечает. Возможная причина: одно из сетевых устройств не настроено для
разрешения ВПН подключений...
Роутер перед клиентским ноутбуком 100% пропускает ВПН трафик, так как успешно подключается к другому L2TP/IPsec VPN-серверу.
Подскажите в чем может быть проблема?
    • By petoner
      Подскажите пожалуйста vpn провайдеров который позволяют сканировать ip диапозони ?
      В теории это может даже быть vps провайдер.
      И также пока работаю над тем что бы поправить скорость соединения через openvpn очень скорость режет
      как вариант можна использовать WireGuard но не факт что это что то даст если огранице есть на стороне текущего провайдера
    • By SBogdan
      Вітаю.
      Запрошуємо скористатися нашими віртуальними серверами в Нідерландах. Розміщені в Нідерландах, в місті Меппель в Дата Центрі Serverius та працюємо виключно на базі власного обладнання. Будемо раді допомогти вам з розміщенням ваших сайтій та біллінгів, для забезпечення їх безпебійної роботи. Всі тарифи включають базовий захист від DDOS атак та можливе розширення пакету захисту по запиту.
      Тарифні плани на віртуальні сервери в Netherlands, Meppel
      NLSV-1 | 1x CPU / 1GB RAM / 50 GB SSD NVMe / До 1 Гбіт/c / 1 IPv4 / Linux only = 5.2$/мес. [Замовити]
      NLSV-2 | 2x CPU / 2GB RAM / 80 GB SSD NVMe / До 1 Гбіт/c / 1 IPv4 / Linux only = 5.7$/мес. [Замовити]
      NLSV-3 | 2x CPU  / 4GB RAM / 120 GB SSD NVMe / До 1 Гбіт/c / 1 IPv4 / Linux&Windows = 9.1$/мес. [Замовити]
      NLSV-4 | 4x CPU / 6GB RAM / 140 GB SSD NVMe / До 1 Гбіт/c / 1 IPv4 / Linux&Windows = 13.5$/мес. [Замовити]
      NLSV-5 | 4x CPU / 8GB RAM / 180 GB SSD NVMe / До 1 Гбіт/c / 1 IPv4 / Linux&Windows = 15.7$/мес. [Замовити]
      NLSV-6 | 6x CPU / 10GB RAM / 200 GB SSD NVMe / До 1 Гбіт/c / 1 IPv4 / Linux&Windows = 24.5$/мес. [Замовити]
      + Встановлення серверу через 2-15 хв. після оплати;
      + Можливість заключити договор (за потреби);
      + Працюємо виключно з власним обладнанням;
      + Сервери працюють виключно на наших мережах;
      + Досвід роботи з 2012 року;
      + Широкий спектр можливих варіантів оплати;
      Наш сайт https://uaunit.com/virtual_servers.html
      Наші контакти:  sales@uaunit.com ||| TG https://telegram.me/salesconsultanthere
      Промо код для форумчан (-25%) : local25%october
    • By hellion1986
      Допоможіть організувати локальні мережі найбільш оптимальним способом. Маємо двох провайдерів, один з яких надає дінамічну, а другий, відповідно, статичну IP-адреси. Також є локальна мережа користувацьких машин та окрема мережа для серверів. В якості файєрволла та маршрутизатора стоїть pfSense з 4-ма інтерфейсами. На даний час все побудовано по схемі, наведеній на малюнку, та поки що працює наступним чином - трафік від USERS LAN йде на wan_dhcp, а від SERV LAN відповідно на wan_static. Трафік між USERS LAN та SERV LAN регулюється відповідними правилами
      Питання наступне. Чи є така схема в данному випадку найоптимальнішою? Чи слід так робити, або, якщо ні, то як би ви порадили зробити?
    • By OstJoker
      Новий міні-ПК, в заводській упаковці. В наявності 2 шт. Фото актуального товару.
      Повністю пасивне охолодження через металевий корпус. Чудовий варіант для побудови роутера, фаєрвола, сервера IoT і т.д. Помірне споживання електроенергії.
      Короткі характеристики:
      Процесор: 4 ядра  Intel® Atom® processor E3940 (9.5W, 4C)
      Оперативна память:  Up to 8GB Unbuffered non-ECC SO-DIMM, DDR3L-1866MHz, in 1 DIMM socket (опції нижче)
      SSD: 1 SATA 3.0 for 7mm 2.5" SATA SSD OR1 M.2 B-Key 2242 for SATA SSD (опції нижче)
      Мережа: 5 LAN with Intel® Ethernet Controller I210-IT RJ45 Gigabit Ethernet
      Інше: 2xHDMI, Audio, 2xUSB2.0, 2xUSB3.0, COM, TPM, M.2
      Зовнішній БЖ в комплекті 40W 12V 3.33A, AC to DC lockable power adapter.
      Детальна специфікація, фото, даташит на офіційному сайті супермікро:
      https://www.supermicro.com/en/products/system/Box_PC/SYS-E50-9AP-N5.cfm
      Ціна: 4440 грн.
      Додаткові опції:
      1. Новий ССД Samsung PM883 240GB SATA3 - 770 грн.
      2. Б.в. оперативна пам"ять 2Gb PC3L-12800s (1.35В 1600Мгц) - 60 грн.
      3. Б.в. оперативна пам"ять 4Gb PC3L-12800s (1.35В 1600Мгц) - 120 грн.
    • By r_28
      Потрібен фахівець для віддаленої допомоги/консультування щодо поглибленого налаштування ПО PFSENSE.
      Тема  BGP,DualWAN,NAT та інш.
      Не безкоштовно.
      Подробиці у приват.
