By kolorom
Вітаю, взяв на свою голову з Китаю, хочу завести його у КС, підтримка каже тільки виклик майстра, але маю сумнів, що майстер зможе.
Тепер граюсь, але безрезультатно.
display deviceInfo
*************** device information ***************
Manufacturer = Huawei Technologies Co., Ltd
ManufacturerOUI = 00259E
ModelName = EG8145X6
Description = EG8145X6 GPON Terminal (CLASS B+/PRODUCT ID:2150083448AGJ2898254)
ManufactureInfo = 2150083448AGJ2898254.C402
ProductClass = EG8145X6
SpecVersion = 1.0
ProvisioningCode =
UpTime = 0 day(s) 01:05:16
ReleaseTime = 2022-09-02_23:26:14
UpPort mode = 1
DeviceAlias =
TotalMemory = 512 Mbytes
TotalFlash = 256 Mbytes
HardwareInfo = GPON 4*GE + 2.4G(2X2 11ax)/5G(2X2 11ax) Wi-Fi + 1USB
display optic
LinkStatus : ok
Voltage : 3376 (mV)
Bias : 9 (mA)
Temperature : 44 (C)
RxPower : -23.28 (dBm)
TxPower : 1.98 (dBm)
RfRxPower : -- (dBm)
RfOutputPower: -- (dBmV)
VendorName : HUAWEI
VendorSN : 2133T002613XX
VendorRev :
VendorPN : HW-BOB-0008
DateCode : 210916
display lanmac
lan mac = E8:68:19:19:62:XX
display version
hardware version = 22AD.A
main software version = V5R021C10S225
standby software version = V5R021C00S050
uboot version = 2020.01
ONT Registration Status: Successfully registered the ONT with the OLT.
OLT Service Configuration Status Failed to obtain the status because the OLT version does not match.
EMS Configuration Status: No XML configurations applied.
Huawei ONT is used with an OLT and NMS of a required version. If the versions are not the required ones, the ONT may not work.
If required, contact your internet service provider to obtain the correct ONT firmware or software.
Може хтось може допомогти бо в інтернеті пишуть як на нього лити olt але який і звідки його взяти і що всі питання до провайдера)))
Дякую!
By Alina1989
Overview
The Focuscom FS3124BE is a next-generation XGSPON optical terminal access device designed for high-end home and enterprise FTTX deployments. Integrating the latest WiFi 7 (BE3600) technology, it provides symmetrical 10Gbps upstream and downstream fiber access, delivering a robust solution for ultra-bandwidth applications.
Key Features & High-Speed Connectivity
Next-Gen XGSPON Speed: Supports symmetrical transmission rates of 10Gbps (Upstream/Downstream) using XGSPON technology.
WiFi 7 Performance: Delivers up to 3600Mbps total air speed (688Mbps on 2.4GHz and 2882Mbps on 5GHz).
Versatile Wired Ports: Equipped with one 2.5GE port for high-speed wired devices and three Gigabit Ethernet (GE) ports for standard networking.
Advanced Wireless Tech: Features $2\times2$ MIMO and Multi-Link Operation (MLO) across 2.4G and 5G bands to ensure lower latency and higher reliability.
Powerful Signal: High-gain 5dBi antennas provide excellent penetration, capable of passing through reinforced concrete or brick walls.
Comprehensive Functionality
Voice over IP (VoIP): Includes one RJ11 port supporting G.711, G.729, and G.722 standards for crystal-clear voice services and fax modes.
USB 3.0 Integration: A built-in USB 3.0 port allows for fast local file sharing and storage expansion.
Enterprise-Grade Security: Supports WPA3-SAE, WPA2-PSK, and robust firewall features to keep your network secure.
Smart Management: Easy configuration and maintenance via Web UI, OMCI, TR069, and CLI (Telnet/SSH).
Technical Specifications
