By Alina1989
Overview
The Focuscom FS3124BE is a next-generation XGSPON optical terminal access device designed for high-end home and enterprise FTTX deployments. Integrating the latest WiFi 7 (BE3600) technology, it provides symmetrical 10Gbps upstream and downstream fiber access, delivering a robust solution for ultra-bandwidth applications.
Key Features & High-Speed Connectivity
Next-Gen XGSPON Speed: Supports symmetrical transmission rates of 10Gbps (Upstream/Downstream) using XGSPON technology.
WiFi 7 Performance: Delivers up to 3600Mbps total air speed (688Mbps on 2.4GHz and 2882Mbps on 5GHz).
Versatile Wired Ports: Equipped with one 2.5GE port for high-speed wired devices and three Gigabit Ethernet (GE) ports for standard networking.
Advanced Wireless Tech: Features $2\times2$ MIMO and Multi-Link Operation (MLO) across 2.4G and 5G bands to ensure lower latency and higher reliability.
Powerful Signal: High-gain 5dBi antennas provide excellent penetration, capable of passing through reinforced concrete or brick walls.
Comprehensive Functionality
Voice over IP (VoIP): Includes one RJ11 port supporting G.711, G.729, and G.722 standards for crystal-clear voice services and fax modes.
USB 3.0 Integration: A built-in USB 3.0 port allows for fast local file sharing and storage expansion.
Enterprise-Grade Security: Supports WPA3-SAE, WPA2-PSK, and robust firewall features to keep your network secure.
Smart Management: Easy configuration and maintenance via Web UI, OMCI, TR069, and CLI (Telnet/SSH).
Technical Specifications
By BatoSan
Продам останки fob4-16 5шт. Під адаптери по 200 грн
Fob03-08 під адаптери. 5 шт. По150 грн
1#8 split sc-upc 10 шт. По 80 грн.
Усе разом за 2300грн
