проблема с работой шаблона на BDCOM 3608
_ivan_
Добрый день такая проблема на онушки не прописывается конфиг с темплейта. при перезагрузке темплейта командой epon template-apply all бывает применяется но частично. если комманды писать жестко на интерфейсе ону все работает. подскажите куда копать?
олт
Device TypeP3608-2TE
BIOS Version0.4.5
Firmware Version10.1.0E Build 60793
пару ону BDCOM 1501D1
ONU Vender ID : BDCM
ONU MODEL ID : 6001
Hardware Version : A0
Software Version : 10.0.26A.1015
ONU MODEL ID : 6001
Software Version : 10.0.26A.1014
логи
Jul 29 09:18:24 %HAL-ONU: Command "epon onu port 1 loopback detect" failed on EPON0/8:1(rv=-5, onu_rv=0)
Jul 29 09:18:24 %HAL-ONU: Command "epon onu port 1 loopback detect" failed on EPON0/8:2(rv=-5, onu_rv=0)
Jul 29 09:18:14 ONU-4-PRECFG: Parsing "epon sla downstream pir 960000 cir 960000" error. Please check "cmd-sequence 4" in preconfig template "vlan_240". (ifindex: 20)
Jul 29 09:18:14 total bandwidth of pon port is more than the max bandwidth it can support
Jul 29 09:18:14 ONU-4-PRECFG: Parsing "epon sla upstream pir 960000 cir 960000" error. Please check "cmd-sequence 3" in preconfig template "vlan_240". (ifindex: 20)
Jul 29 09:18:14 ONU-4-PRECFG: Parsing "epon sla downstream pir 960000 cir 960000" error. Please check "cmd-sequence 4" in preconfig template "vlan_240". (ifindex: 21)
Jul 29 09:18:14 ONU-4-PRECFG: Parsing "epon sla upstream pir 960000 cir 960000" error. Please check "cmd-sequence 3" in preconfig template "vlan_240". (ifindex: 21)
Jul 29 09:18:13 %OLT: Interface EPON0/8:1's CTC OAM extension negotiated successfully!
Jul 29 09:18:13 %OLT: Interface EPON0/8:2's CTC OAM extension negotiated successfully!
Jul 29 09:18:11 timestamp 0, window 0, threshold 0, value 0
Jul 29 09:18:11 Alarm LASER_ALWAYS_ON from OLT 0x03000303 port EPON0/8 pon_diID 19
Jul 29 09:18:10 %EPON-ONUAUTHEN: ONU 8479.73c5.b4bc is authenticated on EPON0/8:1.
Jul 29 09:18:10 %OLT: Interface EPON0/8:1's OAM Operational Status: Operational
Jul 29 09:18:10 %OLT: Interface EPON0/8:2's OAM Operational Status: Operational
Jul 29 09:18:10 %EPON-ONUAUTHEN: ONU 8479.73c5.b158 is authenticated on EPON0/8:2.
Jul 29 09:18:10 %EPON-ONUREG: ONU 8479.73c5.b4bc is registered on EPON0/8:1.
Jul 29 09:18:10 %EPON-ONUREG: ONU 8479.73c5.b158 is registered on EPON0/8:2.
Jul 29 09:18:10 %LINEPROTO-5-UPDOWN: Line protocol on Interface EPON0/8, changed state to up
Jul 29 09:18:10 %LINE-5-UPDOWN: Line on Interface EPON0/8, changed state to up
Jul 29 09:17:32 %EPON-ONUDEREG: ONU 8479.73c5.b4bc is deregistered on EPON0/8:1.
Jul 29 09:17:32 %HAL-ONU: Command "epon onu port 1 loopback detect" failed on EPON0/8:1(rv=-7, onu_rv=0)
Jul 29 09:17:32 %LINEPROTO-5-UPDOWN: Line protocol on Interface EPON0/8, changed state to down
Jul 29 09:17:32 %LINE-5-UPDOWN: Line on Interface EPON0/8, changed state to down
Jul 29 09:17:32 %EPON-ONUDEREG: ONU 8479.73c5.b158 is deregistered on EPON0/8:2.
Jul 29 09:17:31 %HAL-ONU: Command "epon onu port 1 loopback detect" failed on EPON0/8:2(rv=-7, onu_rv=0)
Jul 29 09:17:28 %OLT: Config ONU on interface EPON0/8:1 failed for 3 times, must reboot it!
Jul 29 09:17:28 ONU-4-PRECFG: Parsing "epon sla upstream pir 960000 cir 960000" error. Please check "cmd-sequence 3" in preconfig template "vlan_240". (ifindex: 20)
Jul 29 09:17:28 total bandwidth of pon port is more than the max bandwidth it can support
Jul 29 09:17:27 %OLT: Config ONU on interface EPON0/8:2 failed for 3 times, must reboot it!
Jul 29 09:17:27 ONU-4-PRECFG: Parsing "epon sla upstream pir 960000 cir 960000" error. Please check "cmd-sequence 3" in preconfig template "vlan_240". (ifindex: 21)
Jul 29 09:17:27 total bandwidth of pon port is more than the max bandwidth it can support
Jul 29 09:17:27 %OLT: Interface EPON0/8:1's CTC OAM extension negotiated successfully!
Jul 29 09:17:27 %OLT: Interface EPON0/8:2's CTC OAM extension negotiated successfully!
Jul 29 09:17:24 %OLT: Interface EPON0/8:1's OAM Operational Status: Operational
Jul 29 09:17:24 %OLT: Interface EPON0/8:2's OAM Opera
111
1 час назад, _ivan_ сказал:
Чиво??? где ж вы такие беретесь.
Пы.сы. опоздал. Уже подсказали
3 часа назад, nedoinet сказал:
я понял в чем косяк )
Відредаговано _ivan_
    • Від Mykola_
    • Від ppv
      та
    • Від LIKO
      Продам оптичний лінійний термінал (OLT) BDCOM P3600-16E-2AC , повна комплектація, можливий продаж з модулями BDCOM OLT-GSFP-20+++
      Ціна 85500 грн.
    • Від legenda vols
      Начнём.
      для новичков.
      bash
      set_olt_oids() {
          # Общие для EPON (BDCOM)
          fi
          # Общие для GPON
          fi
          case "$1" in
              # EPON модели
              P3310 | P3310B)
              IEP3310)
              # GPON модели
                  return 1
          esac
          return 0
      EPON GEPON
      1- OID_GET_MAC="1.3.6.1.4.1.3320.101.10.4.1.1" на бдкомах епон
          mac10=$(echo "$snmp_response" | awk '{    # Переводим в mac10 дада способов есть миллиард.
              for (i=1; i<=length; i+=2) {
              print ""
      2 - OID_VENDOR_ONU="1.3.6.1.4.1.3320.101.10.1.1.1"
      SNMPv2-SMI::enterprises.3320.101.10.1.1.1.97 = STRING: "XPON"   если укажем параметр -Oqv  или -Ouqv получим просто "XPON" и надо будет лишь сделать | tr -d ' " '    что бы удалить лапки.
      3 - OID_MODEL_ONU="1.3.6.1.4.1.3320.101.10.1.1.2" аналогично вендорам, получаем модель.
      4- OID_TEMP_ONU="1.3.6.1.4.1.3320.101.10.5.1.2"  - температура ону делим на / 256
      5 - OID_AUNT_ONU_STATUS="1.3.6.1.4.1.3320.101.10.1.1.26"
          case "$onuAunt_type" in
              4) onuAunt_type_txt="lost" ;;
          esac
      6 - OID_UPTIME_ONU="1.3.6.1.4.1.3320.101.10.1.1.80" uptime
      timetick
      7 - OID_DIST="1.3.6.1.4.1.3320.101.10.1.1.27"
      на епоне в метрах  на гпоне делим на 10
      8 - OID_IF_MAC10="1.3.6.1.4.1.3320.101.11.1.1.3"
      SNMPv2-SMI::enterprises.3320.101.11.1.1.3      .14-PORTINDEX     60.21.18.8.130.175  - MAC10                = Hex-STRING: MAC HEX
      9- OID_IFindexmac10="1.3.6.1.4.1.3320.101.11.1.1.1"
      10 - LASTREG_DATE="1.3.6.1.4.1.3320.101.11.1.1.9"
      if [[ -n "$date_hex" ]]; then
              local month=${data[2]}
              local day=${data[3]}
              local hour=${data[4]}
              local minute=${data[5]}
              local second=${data[6]}
      10 - LASTDEREG_DATE="1.3.6.1.4.1.3320.101.11.1.1.10"
      аналогично 9му оиду.
      11 - LASTDEREG_REASON="1.3.6.1.4.1.3320.101.11.1.1.11"
          case "$DEREG_STATUS" in
          esac
      есть прикол если онушка autoconfig статус 3 / authenticated статус 0
      там инвертируються 7 и 8  может и от моделей ону зависеть....
      это уже тестами )
      12  -  OID_ONU_ETH="1.3.6.1.4.1.3320.101.12.1.1.8" статус езернет ничего не обычного кроме того что может верно отдать данные с 2-3го раза )
      2 down 1 up
      там же есть прикол с authenticated autoconfig инвертируется...
              [[ "$ETH_STATUS" =~ ^[0-9]+$ ]] || continue  # Проверяем, что ETH_STATUS - это число
              else
              fi
      14 - OID_GEPORT_COUNT="1.3.6.1.4.1.3320.101.10.1.1.12"   гигабит езернет порты на онушках (кол-во)
      15 - OID_FEPORT_COUNT="1.3.6.1.4.1.3320.101.10.1.1.14"   ФастЕзернет 100мбит аналогично.
      INTEGER
      16 - OID_REBOOT_ONU="1.3.6.1.4.1.3320.101.10.1.1.29" # snmpset -v2c -c RW IP OID.onuIndex i 0                                  reboot REBOOT ONU epon snmp
      17 - delete onu epon  удалить ону бдком снмп
      $snmp5 "$IP" "$OID_DEL_ONU.$ifID.$mac10" i 0 > /dev/null 2>&1    oid.PORTINDEX.mac10 i 0
      все везде одинаково
      $snmp2 "$IP" "$OID_RX_OLT.$INDEX" 2>/dev/null | awk '{print $NF / 10}')   результат делим на 10.
    • Від Amigo
      Продам GEPON ОЛТи BDCOM
      1. BDCOM P3310B (Вживаний) - 6000 грн.
      2. BDCOM P3310C (Вживаний) - 7500 грн.
      3. BDCOM P3310C (Вживаний без вух) - 7000 грн.
      4. BDCOM P3608-2TE (Вживаний) - 20000 грн.
      5. BDCOM P3608-2TE  (Вживаний) - 19000 грн.
