BDCOM P3616 перестаёт регистрировать ONU
XNeo
BDCOM(tm) P3616-2TE Software, Version 10.1.0F Build 74816
Активных ONU до 400.
В какой-то момент OLT перестаёт регистрировать ONU.
В логах такая вот штука:
07:42:38	Switch	local7	warning	%EPON-ONUDEREG	ONU 7830.3b01.c1fc is deregistered on EPON0/4:5.
07:42:38	Switch	local7	info	%EPON-ONUREG	ONU 7830.3b01.c1fc is registered on EPON0/4:5.
07:42:38	Switch	local7	info	%EPON-ONUAUTHEN	ONU 7830.3b01.c1fc is authenticated on EPON0/4:5.
07:42:39	Switch	local7	info	%OLT	Interface EPON0/4:5's OAM Operational Status: Operational
07:50:14	Switch	local7	warning		Alarm CRITICAL from ONU 7830.3b01.c1fc port EPON0/4:5
07:50:14	Switch	local7	warning		Alarm DYING_GASP from ONU 7830.3b01.c1fc port EPON0/4:5
07:52:36	Switch	local7	warning		Alarm CRITICAL from ONU 7830.3b01.c1fc port EPON0/4:5
07:52:36	Switch	local7	warning		Alarm DYING_GASP from ONU 7830.3b01.c1fc port EPON0/4:5
08:04:43	Switch	local7	warning		Alarm DYING_GASP from OLT 0x03000303 port EPON0/5
08:05:44	Switch	local7	crit		%SYS-2-MSGQ:945e0 Send message failed, msgq full qid 321df30, sys tid 2ddf0e0
08:05:44	Switch	local7	info		%SYS-6-MSGQ_INFO:945e0 Messages are 00000002 00000000 09f38d58 00000000
08:05:44	Switch	local7	warning	ctcstack_oam_receive_handler(718)	sys_msgq_send failed, rv=3997698
08:05:54	Switch	local7	warning	ctcstack_oam_receive_handler(718)	sys_msgq_send failed, rv=3997698
08:05:56	Switch	local7	warning	ctcstack_oam_receive_handler(718)	sys_msgq_send failed, rv=3997698
08:07:30	Switch	local7	warning	ctcstack_oam_receive_handler(718)	sys_msgq_send failed, rv=3997698
08:07:31	Switch	local7	warning	ctcstack_oam_receive_handler(718)	sys_msgq_send failed, rv=3997698
08:07:36	Switch	local7	warning	ctcstack_oam_receive_handler(718)	sys_msgq_send failed, rv=3997698
08:07:37	Switch	local7	warning	ctcstack_oam_receive_handler(718)	sys_msgq_send failed, rv=3997698
08:08:17	Switch	local7	warning		Alarm CRITICAL from ONU fcfa.f716.1ba0 port EPON0/5:35
08:08:17	Switch	local7	warning		Alarm DYING_GASP from ONU fcfa.f716.1ba0 port EPON0/5:35
08:09:49	Switch	local7	warning		Alarm DYING_GASP from ONU e067.b3f9.4ee4 port EPON0/9:11
08:10:51	Switch	local7	warning		Alarm CRITICAL from ONU 8479.7399.851c port EPON0/3:17
08:10:51	Switch	local7	warning		Alarm DYING_GASP from ONU 8479.7399.851c port EPON0/3:17
08:12:49	Switch	local7	warning	ctcstack_oam_receive_handler(718)	sys_msgq_send failed, rv=3997698
08:12:50	Switch	local7	warning	ctcstack_oam_receive_handler(718)	sys_msgq_send failed, rv=3997698
Может кто в курсе с чем может быть связано?
1 минуту назад, XNeo сказал:
какой конфиг получают ОНУ?
3 минуты назад, a_n_h сказал:
interface EPON0/6:8
  epon onu port 1 ctc vlan mode tag 3333 priority 0
  epon onu port 1 loopback detect
  epon onu port 1 ip access-group access_list_6:8
Standard IP access list access_list_6:8
 Index          Rule content
     1          permit 10.22.22.22 255.255.255.255
     2          deny   any
23 минуты назад, XNeo сказал:
Настораживают вот эти строки с ошибкой отсылки сообщения в какую-то очередь. Судя из мониторинга именно в этот момент OLT перестаёт регистрировать ONU.
Но что за очередь?
У нас настроен SysLog. Может это он падает?
1 час назад, XNeo сказал:
Вы имеете в виду шейпинг?
Если да, то шейпим на сервере.
нет, имеется ввиду разделение полосы ПОН ветки между онушками. Если суммарно выделение на все ОНУ превысит 1ГБт то регистрироваться тоже не будет.
47 минут назад, a_n_h сказал:
Там суммарная полоса на весь OLT в час пик где-то 800мбит. На каждую ветку вообще ерунда выходит. При чём глюк срабатывал дважды и оба раза в 6-8 утра, когда трафик мизерный.
26 минут назад, melvin сказал:
Киньте настройки epon onu-config-template
epon onu-config-template client
 cmd-sequence 001 epon onu all-port ctc vlan mode tag 3333
 cmd-sequence 002 epon onu all-port loopback detect
Пример конфига аплинка / ветки
interface GigaEthernet0/8
 switchport trunk vlan-allowed 111,3333
 switchport trunk vlan-untagged none
 switchport mode trunk
  dhcp snooping trust
interface EPON0/1
 epon onu-authen-method mac
 epon pre-config-template client binded-onu-llid 1-64
 epon onu-always-laser-on disable
 epon bind-onu mac ххххххххххххх 1
 epon bind-onu mac ххххххххххххх 62
 switchport trunk vlan-allowed 3333
 no switchport protected
 epon inner-onu-switch
Добавлю, что на OLTе используется:
- ACL
- DHCP-Snooping
- NTP
- SysLog
4 часа назад, XNeo сказал:
опять не то, очевидно вы этого вообще не делаете, вполне возможно, что проблема в этом.
epon onu-config-template client cmd-sequence 001
epon onu all-port ctc vlan mode tag 3333 cmd-sequence 002
здесь нарезки полосы нет, посмотрите как в вашем ОЛТ это делается и добавьте. Как я помню на 3310 это строки:
 cmd-sequence 4 epon sla upstream pir 131072 cir 16384
 cmd-sequence 5 epon sla downstream pir 131072 cir 16384
8 минут назад, a_n_h сказав:
у мене на bdcom p3310c також немає нарізки і там автоматично виставляється 100мбіт. хоча в шаблоні нічого не прописано!
9 минут назад, Інет.укр сказал:
с p3310c не работал, а на p3310b без нарезки скорость у абонов  могла упасть да 1МБт.
Только что, Інет.укр сказал:
Скорость в 100 мбит выставляется на езернет порту. На пон порту гиг.
10 часов назад, a_n_h сказал:
Это не правда и полный бред.  Куча олтов bdcom стоит в том числе и 3310b и 3310 c.
На всех олтах bdcom скорость на портах ону по-умолчанию  100 Мбит/с
9 часов назад, cetim сказал:
Скорость как раз выставляется на пон порту онушки точно так же и как и применяются команды шторм контроля и лупбэк детекта если грубо говорить.
15 часов назад, XNeo сказал:
- ACL
- DHCP-Snooping
- NTP
- SysLog
Пробуйте отключить acl или dhcp snooping и проверьте.
Я уверен, что проблема не в tcam таблице, а в прошивке, но проверить нужно.
Был похожий прикол на 3616-2TE, не регалось больше 50 онушек на одном из пон портов, меняли и модуль и танцевали с бубном пока не сменили прошивку самого олт.
12 минут назад, melvin сказал:
сам ты бред! Конкретно у меня так было!!! В основном у всех все  было "в порядке" и скорость была до 100 МБт, но скорость могла упасть совершенно не зависимо ни от каких факторов. Глюк выловили абоны любители мерить скорость, а уже затем смог увидеть и я.
12 часов назад, cetim сказав:
Так ви би змінили свій туполінк 740 на гіговий роутер то на езеру було би 1гбіт.
  • Haha 1
3 часа назад, a_n_h сказал:
Было на самой первой Б-шке. Вылечилось новой версией прошивки...
42 минуты назад, Інет.укр сказал:
Даёшь Тенду в массы!:lol:
  • Haha 1
    • Від tadesky
      Вітаю,
      Маємо в наявності б/в OLT:
      BDCOM  P3310 С-2АС - 1 шт. = 8000 грн
      BDCOM  P3310 С - 1 шт. = 8000 грн
      BDCOM P3616-2 TE - 3 шт. = 38000 грн
      Всі OLT з запасними БЖ 220V (купляли на всяк випадок). Працювали весь час у серверних, робочі та без проблем.
      За потреби можемо укомплектувати модулями Picotel EPON SFP PX++ = 800 грн/шт.
      Питання та пропозиції прохання в особисті повідомлення.
      Дякую.
    • Від Mykola_
    • Від ppv
      та
    • Від LIKO
      Продам оптичний лінійний термінал (OLT) BDCOM P3600-16E-2AC , повна комплектація, можливий продаж з модулями BDCOM OLT-GSFP-20+++
      Ціна 85500 грн.
    • Від legenda vols
      Начнём.
      для новичков.
      bash
      set_olt_oids() {
          # Общие для EPON (BDCOM)
          fi
          # Общие для GPON
          fi
          case "$1" in
              # EPON модели
              P3310 | P3310B)
              IEP3310)
              # GPON модели
                  return 1
          esac
          return 0
      EPON GEPON
      1- OID_GET_MAC="1.3.6.1.4.1.3320.101.10.4.1.1" на бдкомах епон
          mac10=$(echo "$snmp_response" | awk '{    # Переводим в mac10 дада способов есть миллиард.
              for (i=1; i<=length; i+=2) {
              print ""
      2 - OID_VENDOR_ONU="1.3.6.1.4.1.3320.101.10.1.1.1"
      SNMPv2-SMI::enterprises.3320.101.10.1.1.1.97 = STRING: "XPON"   если укажем параметр -Oqv  или -Ouqv получим просто "XPON" и надо будет лишь сделать | tr -d ' " '    что бы удалить лапки.
      3 - OID_MODEL_ONU="1.3.6.1.4.1.3320.101.10.1.1.2" аналогично вендорам, получаем модель.
      4- OID_TEMP_ONU="1.3.6.1.4.1.3320.101.10.5.1.2"  - температура ону делим на / 256
      5 - OID_AUNT_ONU_STATUS="1.3.6.1.4.1.3320.101.10.1.1.26"
          case "$onuAunt_type" in
              4) onuAunt_type_txt="lost" ;;
          esac
      6 - OID_UPTIME_ONU="1.3.6.1.4.1.3320.101.10.1.1.80" uptime
      timetick
      7 - OID_DIST="1.3.6.1.4.1.3320.101.10.1.1.27"
      на епоне в метрах  на гпоне делим на 10
      8 - OID_IF_MAC10="1.3.6.1.4.1.3320.101.11.1.1.3"
      SNMPv2-SMI::enterprises.3320.101.11.1.1.3      .14-PORTINDEX     60.21.18.8.130.175  - MAC10                = Hex-STRING: MAC HEX
      9- OID_IFindexmac10="1.3.6.1.4.1.3320.101.11.1.1.1"
      10 - LASTREG_DATE="1.3.6.1.4.1.3320.101.11.1.1.9"
      if [[ -n "$date_hex" ]]; then
              local month=${data[2]}
              local day=${data[3]}
              local hour=${data[4]}
              local minute=${data[5]}
              local second=${data[6]}
      10 - LASTDEREG_DATE="1.3.6.1.4.1.3320.101.11.1.1.10"
      аналогично 9му оиду.
      11 - LASTDEREG_REASON="1.3.6.1.4.1.3320.101.11.1.1.11"
          case "$DEREG_STATUS" in
          esac
      есть прикол если онушка autoconfig статус 3 / authenticated статус 0
      там инвертируються 7 и 8  может и от моделей ону зависеть....
      это уже тестами )
      12  -  OID_ONU_ETH="1.3.6.1.4.1.3320.101.12.1.1.8" статус езернет ничего не обычного кроме того что может верно отдать данные с 2-3го раза )
      2 down 1 up
      там же есть прикол с authenticated autoconfig инвертируется...
              [[ "$ETH_STATUS" =~ ^[0-9]+$ ]] || continue  # Проверяем, что ETH_STATUS - это число
              else
              fi
      14 - OID_GEPORT_COUNT="1.3.6.1.4.1.3320.101.10.1.1.12"   гигабит езернет порты на онушках (кол-во)
      15 - OID_FEPORT_COUNT="1.3.6.1.4.1.3320.101.10.1.1.14"   ФастЕзернет 100мбит аналогично.
      INTEGER
      16 - OID_REBOOT_ONU="1.3.6.1.4.1.3320.101.10.1.1.29" # snmpset -v2c -c RW IP OID.onuIndex i 0                                  reboot REBOOT ONU epon snmp
      17 - delete onu epon  удалить ону бдком снмп
      $snmp5 "$IP" "$OID_DEL_ONU.$ifID.$mac10" i 0 > /dev/null 2>&1    oid.PORTINDEX.mac10 i 0
      все везде одинаково
      $snmp2 "$IP" "$OID_RX_OLT.$INDEX" 2>/dev/null | awk '{print $NF / 10}')   результат делим на 10.
