BDCOM 3310 не загружается.
voxlv
Коллеги подскажите куда копать. Стоял себе OLT работал ни кого не трогал и вдруг решил что хватит. При включении горит power и мигает sys.
Подключился UART увидел следующее.
validate buffer 0x00002000 len 0x00076000
flash id: 0xffffffff
flash type not supported or flash not available
eth boot
ftp: err 2
image crc32 or len wrong
!!!failed. r�validate buffer 0x00002000 len 0x00076000
eth boot
image crc f64d5cce len 98f94
running image at 10000
SRAM Test Size 0x00200000 Start 0x000a8f48
SRAM Test Size Check Passed.
SRAM Test 8 Bit Byte R/W Passed.
SRAM Test 16 Bit Half-Word R/W Passed.
SRAM Test 32 Bit Word R/W Passed.
SRAM Test Passed.
to call post_stage3
DDR Test Started.
DDR Test Passed.
olt_aal_thread created
dba_thread created
olt_appl_thread created
olt_shell_thread created
logger thread created
Flash CTC OUI: 0x11 0x11 0x11
iROS OLT 3.10.28.33 Sep 29 2013 15:10:17
cmds:
  h                     - show help
  v                     - show version and iros information
  v t                   - show threads debug info
  v module test_number  - asic verification
  v aal                 - aal unit test
  d m     addr len      - dump memory
  d e     addr len      - dump eeprom
  d p     pool_id [0|1] - dump memory pool info.
                          flag 0 for all blocks. 1 for corrupted blocks only
  d c                   - dump cpuload info.
  b                     - dump/set by bytes
  w                     - dump/set by words
  s m     addr val      - set memory to value
  s dis_mode            - set mpcp discovery mode
  s crc_mode            - set mpcp crc8 mode
  s f     dst_port      - set epon forwarding port
  g addr                - start execution at addr
  p cpu                 - show cpu port
  p onu                 - show onu status
  p stats               - show stats
  p thread info         - show thread info
  p thread count        - show thread count
  p mdio device addr    - show mdio
  c stats               - clear stats
  c onu                 - clear onu
  t arp   port [bypass] - transmit arp frame
  t oam   port llid     - transimit oam packet
  t dereg port llid     - deregister onu
  m [level [mod]] - set logging level, default 7 for critical
  k 0|1           - software watchdog timer enable 1; disable 0
olt->eeprom modes_and_oam_version = 0x0
Test bank 0xba3 row 0x0fff col 0x000 - 0x004
Write Pattern 0x55aa55aa
Verify Passed
Write Pattern 0xaa55aa55
Verify Passed
oam_isp_init g_isp_idx = 0
0000000b:7:19 cpuload calibration 855512
0000009d:7:18 EVENT: send control frame 0x172cb0
00000101:7:18 event_tx_start change the event Dest MAC
protocol=7, direction=2, action=1, forward_port=0x00000000
protocol=7, direction=1, action=1, forward_port=0x00000000
protocol=5, direction=2, action=7, forward_port=0x00000000
protocol=4, direction=2, action=7, forward_port=0x00000000
protocol=15, direction=2, action=3, forward_port=0x00000000
И все дальше ни чего. Не реагирует на клавиатуру даже.
А еще подскажите правильные настройки под UART.
У меня такие 38400 8N1
В 15.03.2023 в 11:08, voxlv сказал:
eth boot
ftp: err 2
eth boot
SRAM Test Passed.
to call post_stage3
DDR Test Started.
DDR Test Passed.
dba_thread created
cmds:
  h                     - show help
  c onu                 - clear onu
Verify Passed
Verify Passed
Если буквы видно, то со скоростью угадали, если на клавиатуру не реагирует попробуйте поиграться с программным/аппаратным управлением потока.
    • Автор: Інет.укр
      Продам huawei olt 5608t
      Комплект
      2x MCUD Control Card
      1x GPFD Service Board
      1x MPWD Power module
      16x GPON SFP C++
    • Автор: ikoko
      Продам OLTи BDCOM б.у.
    • Автор: sergeyko
    • Автор: Туйон
      У продажу OLT V-SOL V1600D, стан прекрасний, у заводскій коробці, без проблем, глюків та ремонтів, працював десь півроку, потім був встановлений 8-портовий.
      Нормальний веб-інтерфейс, коректно працював з усіма онушками. Була встановлена остання прошивка десь півроку назад.
      Зібраний гарно, є фото внутрішностей (один раз відкрив, думав може пилюка попала, але чистий, та і було цікаво глянути який він там).
      Детальні характеристики та опис почитайте ТУТ
      З головних плюсів у порівнянні з класикою BDCOM 3310 на мій погляд - порти 10Г та як мені здалося, трохі меньше жре електрики, веб інтерфейс кращій.
      Ціна 8000 грн (половина від ціни нового).
      Можлива продаж за USDT за домовленостю.
      Всі питання у особисті повідомлення.
    • Автор: x-net
      Продам вживаний EPON OLT C-Data (Stels) FD1208S-R2-DAP + DAC 1m + 8 EPON SFP, вуха та рідна коробка. Прошу 20 тис.
