XGPON ONU For Faster Speed FTTH FTTR
The FX3124X is an XGPON Optical Network Unit (ONU) designed as a comprehensive solution for operators seeking high-speed fiber optic connectivity. With a blazing AX3000Mbps speed, this device offers unparalleled integration with dual-frequency Wi-Fi6, making it an ideal choice for modern digital households.
3200UAH/pcs
Spoiler
Key Features:
- XGPON Optical Terminal Access Device: Enables ultra-bandwidth access through advanced XGPON upstream technology.
- Dual-Frequency Wi-Fi6: Provides users with cutting-edge wireless connectivity for seamless internet access across multiple devices.
- Basic Wi-Fi Functions: Equipped with essential Wi-Fi capabilities to ensure reliable wireless connectivity.
- Routing: Offers routing functionalities to manage network traffic efficiently.
- Gigabit Ethernet Functions: Supports gigabit Ethernet connections for high-speed data transmission.
- Versatile Connectivity: Features multiple downstream user ports, including four GE electrical ports, one USB port, one VOIP port, and AX3000 WiFi6 WLAN ports.
Production Function Highlights:
- ITU-T Standards Compliance: Conforms to ITU-T G.987.3, G.988, and G.989 standards for interoperability and compatibility.
- TCONT and GEM Ports: Supports up to 15 TCONTs and 256 GEM ports, ensuring flexible configuration options.
- Egress Queues: Provides a minimum of 8 egress queues per TCONT, enhancing traffic management capabilities.
- VLAN/Priority/VEIP Gem Mapping: Supports various mapping modes for efficient data transmission.
- Authentication Options: Offers multiple authentication methods, including SN (Serial Number), LOID (Logical ONT ID), SN + Password authentication for enhanced security.
- Performance Monitoring: Enables performance monitoring for Ethernet and GEM ports to optimize network performance.
- Dying Gasp: Includes dying gasp functionality to provide crucial information in the event of a power failure or device malfunction.
Viber me for better price: +86 18086327779
    • By Bulet
      Продам
      Finmark 2 волокна діелектрична конструкція FTTH002-SM-01 Flex White Код 276860 біла оболонка, 1000м(упаковка - на котушці в картонній коробці)
      1шт
      1700 грн
      Finmark 1 волокно діелектрична конструкція FTTH001-SM-01 Flex Код 279604 чорна оболонка, 1000м(упаковка - на котушці в картонній коробці)
      1шт
      1500 грн
      NG OPTICS FTTH-00x-SM, G.657A2 волоконно-оптичний плоский абонентський кабель
      2шт
      1500 грн
      Київ, відправка НП, Делівери, Укрпошта
      https://t.me/artkomplekt_kyiv
    • By Emanon
    • By Prodazha
      Наявність 230 шт.
      ціна 250 грн за одиницю
    • By x-net
    • By Alina1989
